Team Losi JRXS Type-R
#8251
Anyone wanna see why losi is ahead of their time. XRay just basically copied the lcds exactly, 4 years after there were patented. The only difference is the set screws instead of the shrink wrap. And personally I like the shrink wrap better. I have never had shrink wrap come loose and back out like a setscrew. Im just waiting for the 009 type r next. First it was the Eight now the LCDs. Losi must be doing something right.
http://www.teamxray.com/teamxray/new...863c1d9fb4aaba
#8252
Company Representative
I think Hudy didnt use shrink wrap cause they don't want to get sued by Losi, but he know shrink wrap is way~ better in inside of his heart
#8256
The JR link makes the front of the car roll less, which makes it more stable. It also makes it more lazy which will remove some of that initial turn-in that you get with the standard links. The largest item with the JR link is that it virtually removes all camber gain from the front of the car. That, alone, takes away a lot of steering with the Type R. The car is very sensitive to camber link changes.
#8257
just fitting my prs spur gear adaptor an have found that the drive pin for the standard spur is too long should I have got a shorter one with the PRS?
#8260
#8262
Anybody have a rollout for foam tires on carpet, small, tight track. I am at 40.22mm, 44/108 and 57.5mm two stages. Anybody else have any experiences or suggestions. Car feels pretty good just getting pulled down the stragiht a bit. Running the Losi 13.5 and speedo.
RedRocket
RedRocket
#8264
RedRocket
#8265
Hello everyone i just got a jrxs and I would like to know what the best motor and speeder are for it it would be a stock brushless for my local carpet track not too expensive
thanks, Bob
thanks, Bob
