Old 10-07-2008, 10:55 AM   #8206
MikeXray's Avatar
Trader Rating: 72 (100%+)
Here they are
Team Losi JRXS Type-R-reedy-setup.jpg   Team Losi JRXS Type-R-schreff-jackson.jpg   Team Losi JRXS Type-R-jrxs-type-r-rubber-iic-2008.gif
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-07-2008, 11:05 AM   #8207
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i will never buy a new set of RP 30's i have two sets of the old rp 30's left.
mike thanks for finding the setup sheets for me
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 10-07-2008, 04:03 PM   #8208
Trips's Avatar
Trader Rating: 16 (100%+)
Just thought I'd post a quick heads-up here...
A few pages back in this thread I asked if anyone knew of a PDF reader that would allow us to change the setup sheets and save the changes... Adobe reader doesn't save changes, and their Acrobat software is a bit pricey at $299... Mike Haynes made the suggestion to fill in the form using Adobe Reader, and then using the snapshot tool to save the completed setup sheet as a "gif" file. That works, but it's tedious to edit the gif if you make minor changes...
I've found a freeware pdf reader called Foxit reader which allows you to make changes to the pdf forms and save and/or print the changes. I downloaded it from Tucows...http://www.tucows.com
Just wanted to mention it here in case it could be useful for anyone else.
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-07-2008, 09:23 PM   #8209
adamge's Avatar
Trips, foxit reader is my preferred pdf reader. Direct link to their site:
http://www.foxitsoftware.com/
When you save the alterred sheet, does it put red text saying 'trial version' on the sheet?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-07-2008, 10:29 PM   #8210
cclifton's Avatar
Send a message via MSN to cclifton
Default Gearing Question
Hi there,
What is everyone running for gearing with a 17.5 and rubber tires. All the reading I have been doing people are usually running 3-4 FDR. This looks to be a possible issue unless someone has a suggestion. The largest pinion I can get locally is a 47 and the smallest spur I have seen for the losi is a 118 which only give a FDR of 4.59. Any suggestions?
Chris
cclifton is offline   Reply With Quote
Old 10-07-2008, 11:13 PM   #8211
Originally Posted by cclifton View Post
Hi there,
Chris
yeah get the prs spur adapter to run a smaller spur i use a 104 and a pinion in the mid 50's
http://www.precisionracingsystems.com/products/18
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 10-07-2008, 11:13 PM   #8212
I just started running 17.5 rubber. I'm used to running 13.5 foam. I'm running a 4.2 fdr on our track. 66x43 carpet track. Running 112/48 to get the ratio. Using a prs spur gear and the prs adapter.
JoelV is offline   Reply With Quote
Old 10-07-2008, 11:38 PM   #8213
RedRocketRacing's Avatar
what are guys running for fans? The book say 20 x 20. Where are people finding them? Need some info asap. Need to get some ordered.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 10-08-2008, 12:04 AM   #8214
Matt Howard's Avatar
RedRocket
AE used to sell a fan kit for their TC4, I used those fans since they were already wired up with a connector and ready to go
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-08-2008, 12:08 AM   #8215
Do you know if they were 20x20's or 25x25's? Thanks for the tip Matt.
RedRocket
NWIC 2008/09
Old 10-08-2008, 12:14 AM   #8216
RedRocket
I don't know what the size was but they are the "right" size (they screw into the bulkheads fine)
RCTech #361
Old 10-08-2008, 06:57 AM   #8217
Mike Haynes's Avatar
25mm is the right size, the novak, much more, or speed passion (25mm) fit right on.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-08-2008, 07:57 AM   #8218
Brazilct's Avatar
whats up mike H ? save me a spot for Sunday if you don't mine
BROOKLYN HOBBIES...
SERPENT AMERICA...
JP Racing...
MAXY's PRO RACING FUEL & MODIFIED MOTORS
Brazilct is offline   Reply With Quote
Old 10-08-2008, 08:27 AM   #8219
Trips's Avatar
No, I didn't notice anything like that...
MARSHAL!!
Old 10-08-2008, 02:07 PM   #8220
racingboy14's Avatar
Trader Rating: 25 (96%+)
does anyone know what a good gear ratio is for a 17.5 with foam tires on a high bite track. I was told to gear it around 4.2-4.6 fdr but i dont really know how to calculate that.
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
