Old 10-06-2008, 07:10 PM   #8191
Jeff Crosson's Avatar
So if you stiffen the whole car you get more overall traction? Or if I stiffen the rear I'll have more rear traction? Is this on low, med, or high traction? I'm just wondering, because contradicts everything I've read and heard on spring weights and traction?
Jeff Crosson is offline   Reply With Quote
Old 10-06-2008, 07:20 PM   #8192
Matt Howard's Avatar
This proves again that you never listened to me.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-06-2008, 08:06 PM   #8193
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
I'm a little confused also i always thought if u soften the car up u get more traction so whats the deal
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 10-06-2008, 08:16 PM   #8194
Cory B's Avatar
use heavier oil and springs when traction is high
use thinner oil and softer springs when traction is low
its all about how your car "rolls" into the corners. you want more roll when traction is low, which is why you soften the suspension.
you want less roll when traction is high, so you stiffen the suspension.
(this is how I understand it anyway)
i suggest everyone read XXXMain's book on how to set-up a touring car. It will be the best $20 you ever spent!
Wild Bill's R/C Hobbies - Knoxville, Ia
Velocity R/C www.velocityrc.net
VWings
AFX Fab
Lancebuilt Hobbies
Cory B is offline   Reply With Quote
Old 10-06-2008, 09:17 PM   #8195
that's what i thought but other people are saying it backwards
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 10-07-2008, 07:14 AM   #8196
mojoman's Avatar
Taking a stab at it here. The Losi car is different than most touring cars as all the weight is distributed evenly and all down the center of the car. As you stiffen up the car it allows for the weight to be utilized in a more efficient way than a car that needs to roll. The balance between soft and stiff is finite but I think Mike is right and as Jason posted a few months back the stiffer you can get the car the better. Weight transfer is a totally different theory which is defined by springs, shock oil and bars. There is the finite line. Just because the car "rolls" doesn't mean you'll have traction. And just because the car is stiff doesn't mean the setup will be loose.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 10-07-2008, 07:30 AM   #8197
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
The rear end of this car rolls a good bit. If you run too soft of a spring the rear end will roll way more than the front end casuing the car to feel loose and unbalanced. thats why I never run anything under a 15lb spring on the rear end.
Also with the car a little stiffer it will push the tire into the racing surface rather than be abosorbed by the suspension. And as Mojo said this is a very fine line.
With a few small changes I can get my car to push or spin out on asphalt. Rear springs being one of these changes.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 10-07-2008, 07:42 AM   #8198
MikeXray's Avatar
Trader Rating: 73 (100%+)
On your reedy setup sheet you have 1.5mm in the uptravel field, is that something you use all the time or only when traction is very high?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-07-2008, 07:44 AM   #8199
ok... you guys have me all confused
i run my car in parking lot and it is usualy pretty loose. so what would you guys sugest for a front and rear spring and oil?
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 10-07-2008, 07:49 AM   #8200
mojoman's Avatar
I would start with 15 lb springs in the rear and 30 weight oil, 17.5 lbs in the front and 35 weight oil. The car might push in that case go to a softer spring in the front. If it's loose make only minor adjustments with bars or oil.
Casey Castleman
Old 10-07-2008, 07:55 AM   #8201
MikeXray's Avatar
What setup do you have on the car? if you are running the kit setup with a few changes, I recommend going through either one of mike's, larry's or schref's asphalt setups and run the WHOLE setup, I have learned through much trial and error, more error that you can't take just take a few parts of it.
Like I said before I've races mike's setup on a parking lot track and the car worked very well.
Old 10-07-2008, 08:04 AM   #8202
i have one of Tods Hodg's setups on it right now. but i do think i changed the springs
i need a setup that will work on a realy loose asphalt track
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 10-07-2008, 09:17 AM   #8203
Abosolutley no offense to Todd at all but that setup was developed before the car was even released so its not exactly current. I tried it early on when I was running the car last year and it didnt work on any track around here.
Try one of our setups from this year and put it on Exactly and let me know how it works.
Also what tires are you running?
Old 10-07-2008, 09:48 AM   #8204
I run sorex 36r's or rp 30's but most of the time it's sorex 36r's
If you could give me a link to a page where I can find a setup I would appreciate it
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 10-07-2008, 09:54 AM   #8205
There are a couple setups posted back on this thread. I dont have any links you just have to search.
If your track is low bite 36's will not work. And if they are new RP30s throw em away. I would try Sorex/Speedmind 32's or 28s.
I have run almost every tire known to man this summer and found Sorex's to be the best.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
