Old 10-05-2008, 04:18 PM   #8176
sportpak's Avatar
Trader Rating: 26 (100%+)
You could soften the rear spring a touch. I run a 15lb front / 10.5lb rear in similar conditions. No sways unless I need a little push.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 10-05-2008, 04:49 PM   #8177
Mike Haynes's Avatar
Jon, I would stiffen up the back of the car to a 17 spring, and also use the .05 sway bar.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-05-2008, 04:59 PM   #8178
Trips's Avatar
Trader Rating: 16 (100%+)
I had a similar loose condition on corner exit whoch went away when I loosened the rear diff. Don't loosen it enough to let the diff slip under power, you want it to not slip, but not much tighter than that.
I fought with the loose exit thing for weeks until I got the diff set right.
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-05-2008, 07:24 PM   #8179
Juan Valdez's Avatar
Default Losi lipo question
Since some of the guys here mentioned they've used the Losi lipo packs, I was hoping someone could answer a question on them. What type of connector is used for the balancing lead? I check Losi and Horizon and neither tell you. I'm looking to buy one, so if someone could answer that, I would appreciate it. Thanks in advance!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 10-05-2008, 07:38 PM   #8180
Cory B's Avatar
I believe it is a Losi plug. I had to use a "Blinky" with the losi adapter to balance the pack.
Wild Bill's R/C Hobbies - Knoxville, Ia
Velocity R/C www.velocityrc.net
VWings
AFX Fab
Lancebuilt Hobbies
Cory B is offline   Reply With Quote
Old 10-05-2008, 08:45 PM   #8181
J@UNE's Avatar
Is it because the rear is too soft? Should I run the .050 front and rear? My track doesn't have that much traction, should I go softer all around?
Thanks again.
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 10-05-2008, 08:53 PM   #8182
rocketron's Avatar
the balance connector is the same as on Thunder Power lipos
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 10-06-2008, 01:45 AM   #8183
PDM
Originally Posted by [email protected] View Post
Guys, I'm having issues with the rear of my car (rubber). Its loose at corner exit, Not much but when I go strait, the rear wants to go too far. Im on carpet but the grip isn't that high.
I tried different wheels hex... I end up running the wide up front and the .195 in the rear.
Front high and rear low roll center. I tried with the long rear link, It almost fixed it but the car didn't react fast enough in the sweepers.
Tried flat and anti dive in the front, with anti-dive, it felt like the car had less off power steering at the corner entry and pretty much the same at exit.
running .030 sway bar front and rear 17.5F, 15R springs. when I ran the .040, I tried removing the rear sway but suprisily it was worst.
I played with the droop but didn't fixed it either
Now What I'm thinking to do ... (Let me know if you have other ideas or feedback)
- 40W oil in the rear (currently 35)
- Rear kickup (.030 shim underfront block)
- Maybe try the Jr Link
- diff height?
Thanks in advance
Besides the other things if you are using a spool check if it is loose
PDM is offline   Reply With Quote
Old 10-06-2008, 04:09 AM   #8184
Thanks again.
Most of the time on rubber carpet going stiffer on the setup will make it have more grip. I always run .05 bars front and rear....however my little brother likes to have his car a bit more planted, so i have a rear .06 in his.
Old 10-06-2008, 05:23 PM   #8185
J@UNE's Avatar
thanks a bunch for the info! I will start with stiffer sway bars!! I just though that they were too stiff for rubber
Jon Gagnon
DirtTrax - Team FLR
Old 10-06-2008, 06:12 PM   #8186
MikeyLTD's Avatar
Hey everyone,
Im starting out in the on-road scene and im curious as to what a good set up is for asphault with decent traction would be. I am running sorex 32r's. I am running the rs-pro 17.5 combo with the tekin lipo aswell.
Thanks,
Mikey Bustamante
Kyoso, Tekin, AKA, Airtronics, TEAM BAHLZ, Dialed inc., 818 Designs
MikeyLTD is offline   Reply With Quote
Old 10-06-2008, 06:21 PM   #8187
MikeXray's Avatar
Trader Rating: 73 (100%+)
I've been running Mike's setups this year and one week we ran at a regular parking lot track, with no compound the setup still worked very well. (for some reason compound hurt traction)
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-06-2008, 06:45 PM   #8188
Sean Powers's Avatar
my little brother likes to have his car a bit more planted, so i have a rear .06 in his.[/QUOTE]
Thats right, his lil bro....there are two of them! look out his brother is getting faster all the time
Sean Powers is offline   Reply With Quote
Old 10-06-2008, 06:55 PM   #8189
HAHA Sean your right...if only he was more interested, most race days he would rather stay home and play GTA.
Old 10-06-2008, 07:00 PM   #8190
the next francis brothers....First we had Matt and Mark Francis now Mike and Chris Haynes....LOL
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
