Old 09-28-2008, 09:33 PM   #8131
Trips's Avatar
Trader Rating: 16 (100%+)
Originally Posted by metalracer2 View Post
if it was me i would not dremel the car. i would just buy the prs adapter it's only $20. i got my 17.5 to work with a 104 spur with runner tires
Or, you can dremel the motor... Not my first choice, but with the Tekin Redline being a few mm longer and no taper at the endbell I couldn't get even close... Even dremeling the inner pin mount wasn't enough... by the time I got enough material off the pin mount to fit a 118/53, there wasn't enough left of it to hold the ball in place...
The Xcelorin and Trinity motors I had in the car were both shaped just fine and required no dremeling to get a 118/53 in the car, but my Xcelorin is a 10.5, and the 17.5 Trinity that I borrowed from Alex last time out was busy in his Speedmerchant today... so with no prs adapter handy, this is the result...
warning: it might be a good idea to check for ROAR legality (or whatever rules are in place where you race)
MARSHAL!!
Trips is offline   Reply With Quote
Old 09-28-2008, 10:01 PM   #8132
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
damn
well you got it to work
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 09-29-2008, 06:59 AM   #8133
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
I'm looking to change my thrust bearing in my losi type r
what is the difference between the losa3018 and losa 3098
http://www.losipartshouse.com/servle...Bearing/Detail
http://www.losipartshouse.com/servle...-Thrust/Detail
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 09-29-2008, 07:23 AM   #8134
MikeXray's Avatar
Trader Rating: 73 (100%+)
The first one is the stock one, which I think sucks, the cage always explodes. I've used the 2nd, but didn't like it either. If your looking for a losi one, this set is good
but not caged, for caged I have been using the ones that Axiom has, the hold up well.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-29-2008, 07:35 AM   #8135
J@UNE's Avatar
Max, Please change the diff balls as well... Xray diff bals fits even if they are metric... and I beleive H2K have them in stock
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 09-29-2008, 07:49 AM   #8136
yeah, I will change the balls for sure I think I still have some new 3/32 at home somewhere.
Maxime Beauvais
Old 09-29-2008, 12:31 PM   #8137
mojoman's Avatar
The mcmaster thrust bearings work great. I've been running mine since last year and they are in tip top shape. p/n 7806k53 Link
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 09-29-2008, 05:11 PM   #8138
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
run the 2.4's, you get a smoother diff...
Try our new ceramic ball captured thrusts, way smooth!
dgullickson is offline   Reply With Quote
Old 09-29-2008, 05:45 PM   #8139
RedRocketRacing's Avatar
Dave you gonna be at the NWIC race in Salem in a coouple of weeks? Does Ron have all there diff balls and thrust kits?
RedRocket
Anders Hagen
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 09-29-2008, 05:48 PM   #8140
Company Representative
SweepRacingUSA's Avatar
you mean this? http://www.axiommotors.com/24mm-cera...2pk-p-509.html
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 09-30-2008, 05:01 AM   #8141
Mike Haynes's Avatar
I always use the losa3018 for the diff, and they seem fine, the trick is not to over tighten them and they will last.
As for motor clearance, i just shave out the pivot block with a sandpaper wheel, and it has plenty of clearance to get the motor all the way back in the mount.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-30-2008, 12:11 PM   #8142
Originally Posted by da_John_wee View Post
That be the one
Old 09-30-2008, 04:58 PM   #8143
Mike-
Did you run the steering rack foreward on the top deck? was it for battery connector clearance or for the ackerman change? I have to run them foreward for connector clearence with the TrakPower Lipo's. What kind of change will I expect from the foreward and back positions of the rack on the top deck? I would imagine and little quicker and sharper steering running it foreward? Where do you run the rack for both foam and rubber? This setting is not on the setup sheets.
RedRocket
Anders Hagen
NWIC 2008/09
Old 09-30-2008, 06:13 PM   #8144
I always run the steering rack foward, yes it does make the steering more responsive.
Old 09-30-2008, 06:38 PM   #8145
thanks Mike.
RedRocket
Anders Hagen
NWIC 2008/09
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
