Old 09-22-2008, 09:05 AM   #8071
Originally Posted by Ramyuras View Post
I got a new chassis for my Type R and I find out that the holes for the pivot in the rear is wider than the original chassis I have is this a mistake or did they make adjustment?
Any one with answer to my question.. now with the adjustment they made on the chassis the rear pivot block is much closer than the original chassis to the motor, I use the 13.5 Trinity with the cut out on the back of the motor and the fit is so tight, I am now looking for the spur adaptor, with the original chassis I had enough space so I didn't need the spur adaptor.
Ramyuras is offline   Reply With Quote
Old 09-22-2008, 09:19 AM   #8072
MikeXray's Avatar
Trader Rating: 72 (100%+)
Thats interesting, even with my original chassis (car from the first batch) I need to grind down that pivot block to get more than a 51t pinion and the original orion, the novak fit a 52 I think. I did replace that chassis, I'll check the spacing, I wonder if you might have gotten one that was just out of spec.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-22-2008, 09:27 AM   #8073
Brazilct's Avatar
I'll like to say thanks to Mike Haynes ,Joe ,Mike and Jerry ball cup ririri . I appreciate all the help. Mike H. thanks for the awesome setup. thanks guys, see you next weeking ..
BROOKLYN HOBBIES...
SERPENT AMERICA...
JP Racing...
MAXY's PRO RACING FUEL & MODIFIED MOTORS
Brazilct is offline   Reply With Quote
Old 09-22-2008, 10:47 AM   #8074
Mike Haynes's Avatar
You possibly just switched to that motor and never noticed it was a different shape? Some of the bl motors have a "square" corner and you need to shave some off the block, others have a bevel and dont need it.
Renato, np man...now you just need laps
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-22-2008, 11:12 AM   #8075
I had to to some grinding too when I use my Losi or Hacker motor but with the Trinity motor there was more than enough space because the Trinity motor have the cutout in the rear of the motor.
Old 09-22-2008, 11:16 AM   #8076
I did notice the difference when I put the two chassis together the pivot blocks near to the motor was up by about 3mm, even shaving the block to almost hitting the threads, the chassis is off.
Old 09-22-2008, 01:35 PM   #8077
tim fry's Avatar
Originally Posted by tim fry View Post
Hi all
I'm running 10.5 and 13.5 this coming winter and was wondering what is the best spur to use for 13.5? I'm using the standard 90t 48dp for 10.5 and I have purchased a PRS spur gear adaptor so I can run a smaller spur for 13.5 as I need to get to 4.5 FDR just wondered which size/sizes would be optimum.
Tim
Anyone?
tim fry is offline   Reply With Quote
Old 09-22-2008, 01:40 PM   #8078
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Anyone?
I use a 116 or a 118 64p spur for rubber tires on asphalt
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 09-22-2008, 02:13 PM   #8079
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
Anyone?
im runnig a 118 rite now. works well. gonna try a 116 soon tho
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 09-22-2008, 02:17 PM   #8080
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
I am going to ask this cause I never got the answer I was really looking at. Can someone tell me which orion Lipos fit the JRX-S Type R chasis without modification.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 09-22-2008, 02:46 PM   #8081
MikeXray's Avatar
None worth running 4800 and 3200 and guaranteed fit, I think their new one is the same dimensions as the 4800, but generally the orion cells are down on average voltage vs the checkpoint, core, SMC and trackpower. It's worth the little extra work to make the other packs fit, only the SMC 5000 requires dremeling of the bulkhead because it's tall, the others are a little wide, so you widen the pulleys.
Old 09-22-2008, 03:56 PM   #8082
dfiantii's Avatar
MikeXray,
Thanks for the response. I also heard the Checkpoint 5400 fits as well. This purchase will be my intro into the Lipo world so I am ok starting off at the 3200 and getting 2 or 3 lipos to include a 4800 and the 5400. The price pushes me away a little but it is the way our hobby is.
Old 09-22-2008, 07:22 PM   #8083
MikeXray's Avatar
I checked all 3 chassis I have and they are all in the same location.
Old 09-23-2008, 06:54 AM   #8084
Good for you, I call Horizon and they said to send it in and they will replace it, it's just a pain to package it up and then sending it, now a $70.00 chassis is now $80.00 + and I have to wait for another 2 weeks to get my chassis.
Old 09-23-2008, 10:14 AM   #8085
Jerry P's Avatar
Trader Rating: 44 (100%+)
Any time bro. Just make sure you keep sitting at the Losi table because all the hater's are no fun. now get a second losi so you can run foam too.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
