Old 09-17-2008, 12:54 PM   #8041
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
rcracingkid
Thanks for the fast reponse. I appreciate it. I will be buying this and probably one more Lipo to race my Type R. I am almost finished with the build. Are there any other lipos that fit without modification so I can put them on my list.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 09-17-2008, 01:13 PM   #8042
RaceAce701's Avatar
Trader Rating: 83 (99%+)
checkpoint 5400 fits
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 09-17-2008, 01:26 PM   #8043
dfiantii's Avatar
With out modification?
Old 09-17-2008, 06:10 PM   #8044
mojoman's Avatar
Originally Posted by rcracingkid View Post
For rear toe i pretty much always use 3 for rubber, and 2 for foam. With regards to altering the rubber car, usually just changing front drive (1-way or spool), front hex, the ackerman hole on the steering rack, or the number of shims on the rear camber link is all it takes to make the car work on whatever track i've run at.
As you might be aware Mike the Coliseum is unique, and running 17.5 no matter what changes I make regarding linkage and camber the car is still too stuck! Reducing the rear toe has been my solution to free up the back end in this respect and only at the "C"
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 09-17-2008, 06:34 PM   #8045
Mike Haynes's Avatar
Casey, yea i could see that working there possibly, i only ran a type r there once, and i had 3 of toe...maybe less would have helped out. This summer i ran on the indoor paved track at 360 up here, similar condition but a bit less grip then the c, my carpet setup was awesome with just going to a high rear diff and narrow front hexes...i would think its worth a try there also.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-17-2008, 07:54 PM   #8046
YmeBP's Avatar
Trader Rating: 32 (100%+)
without mods, that is what i run in my type-r's, checkpoint 5400's.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-17-2008, 09:13 PM   #8047
808TXT1's Avatar
Where is a good place to get the PRS adapter to run my BL 17.5?
808TXT1 is offline   Reply With Quote
Old 09-17-2008, 10:06 PM   #8048
Trader Rating: 17 (100%+)
I thought they quick production on the Orion 3200 and are now making the 3400... which I believe has the same dimensions as the 3200. I am about to buy the orions but I have not gotten confirmation that it fits the Type r without modification.
seabass2500 is offline   Reply With Quote
Old 09-17-2008, 10:10 PM   #8049
rocketron's Avatar
have any of you used the Losi Hardcase Lipo's
they fit and the 500mah is ROAR approved and there is a new 4400 30C now available
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 09-18-2008, 06:03 AM   #8050
Jerry P's Avatar
Trader Rating: 44 (100%+)
Go to the source.. http://www.precisionracingsystems.com/
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 09-18-2008, 06:52 AM   #8051
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
I bought the PRS Spur adapter and the center shaft binds like crazy. I even sanded down the layshaft spacers, but it still binds. What am I doing wrong here?
Ty is offline   Reply With Quote
Old 09-18-2008, 06:55 AM   #8052
YmeBP's Avatar
Where does it bind, can you take a photo? Do you have the stock screws in it?
Old 09-18-2008, 06:59 AM   #8053
Xpress's Avatar
I had to sand down the inside of the passenger side pulley and also shave down the pegs that key into the aluminum adapter. The pegs are thicker than the adapter flange and when you tighten the gear it spreads the two apart. It's kind of hard to explain, but pretty easy to see when you are looking at the assembly. I would suggest taking the belts off the car and keep shaving material off until the layshaft spins freely. If you are fighting to get the e-clip on the layshaft you have not taken enough material off.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 09-18-2008, 07:07 AM   #8054
Yeti35's Avatar
Quality must not be as good on the newer ones from the original ones. I remember having to sand down the key pin but other then that mine work fine.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-18-2008, 07:11 AM   #8055
Ty
Ty's Avatar
I will sand down the pulley, the pegs and also the inside of the adapter on the pin side tonight and I will update. I will also sand down the screws too and they are too long as well. Thanks guys for the ideas and I will post again. And yes, it is one of the new ones as everyone at the track that has the old ones do not have any problems.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
