Old 09-15-2008, 02:52 PM   #8026
Mike Haynes's Avatar
For rear toe i pretty much always use 3 for rubber, and 2 for foam. With regards to altering the rubber car, usually just changing front drive (1-way or spool), front hex, the ackerman hole on the steering rack, or the number of shims on the rear camber link is all it takes to make the car work on whatever track i've run at.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-15-2008, 03:11 PM   #8027
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Does anyone know what the smallest spur is that I can use on the type r with a 17.5? I will be using the prs adapter
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 09-15-2008, 03:16 PM   #8028
Depending on the size pinion you will be running, i would say between 100 and 104.
Old 09-15-2008, 03:38 PM   #8029
yeah i'm going to have to go with a lower spur like in the 80's i was going to us a 104 but i couldn't get the pinions to go with it. so has any one tryed using like a 88t spur
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 09-15-2008, 07:19 PM   #8030
You will not be able to mesh any pinion with that to get the ratios you will be after, MAYBE you could get away with a 96 when using foam tires, but that would be pushing it.
Old 09-15-2008, 08:20 PM   #8031
MikeXray's Avatar
Trader Rating: 72 (100%+)
Do you not want to buy pinions? for foam 13.5 you'd only need high 40s with a 108 spur.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-15-2008, 10:39 PM   #8032
i have all the pinions for a 13.5 i just need them for a 17.5
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 09-16-2008, 10:25 PM   #8033
I run a 78 / 37 with my 17.5 works well and is competitive on the track I run at.
miku is offline   Reply With Quote
Old 09-17-2008, 05:15 AM   #8034
Send a message via MSN to nelarozi
Did anyone tried the Ceramic Bearing Kit form speedzoneusa? (http://www.speedzoneusa.com/estore/i...roducts_id=195)
nelarozi is offline   Reply With Quote
Old 09-17-2008, 06:58 AM   #8035
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
The best bearings in the world!!......... Period!
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 09-17-2008, 07:34 AM   #8036
YmeBP's Avatar
Trader Rating: 32 (100%+)
I have 3 sets for my losi cars and i second what Alex said, they are also very inexpensive. The guy at speedzone is a good guy and will help you if you have issues.
My drive train is extremely free, they've lasted and it shaved quite a few grams from total weight.
One and only downside: he doesn't have a kit for my son's tc4 or the xray m18 yet .
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-17-2008, 07:34 AM   #8037
I orderd ceramic diff ball few day ago, i hope they will be better than original
Old 09-17-2008, 12:39 PM   #8038
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Can anyone tell me if this lipo fits the Type R without modification. It is my first lipo battery purchase.
Team Orion Carbon 3200mAh LiPo Battery Pack
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 09-17-2008, 12:44 PM   #8039
Yeti35's Avatar
If you can find the measurements for it and a 3600 you may be able to tell from that. If it is as wide as a 3600, you will have to mod the car to make fit.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-17-2008, 12:49 PM   #8040
That will fit with no problem.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
