Old 09-05-2008, 01:02 PM   #7951
J@UNE's Avatar
IMO they are both as good.
I went with the losi when I switched to lipos. I couldnt stand having that many weights on the righ side of my T2...
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 09-05-2008, 04:12 PM   #7952
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Hey guys im trying to gear up for a race this weekend and lost one of the c-hub bushings. all local sources are out of stock, anyone know of a different brand that will for sure fit? they are the bushing that slide into the c-hub from the inside before you put in the steering hub.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 09-05-2008, 06:12 PM   #7953
Kropy's Avatar
Send a message via AIM to Kropy
Try AE Bushings
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 09-05-2008, 06:50 PM   #7954
turtlebmx's Avatar
Trader Rating: 31 (100%+)
hey yeti what size track are you on? i run on a small carpet track and the gearing chart isnt even close. I'm right around 2.5. i think i'm at a 118/47.
turtlebmx is offline   Reply With Quote
Old 09-05-2008, 09:00 PM   #7955
Yeti35's Avatar
I personally have never run a 17.5 but it is the recommended starting point for FDR for that motor at 3.5. I would have to guess if you need to change gearing you will have to purchase a PRS adapter and get smaller spur gears. I am not saying it is the perfect gearing, just the starting point.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-06-2008, 03:13 AM   #7956
Originally Posted by gfarb View Post
Looking to get back into the hobby after a 2 year break, I’m considering this car and aTC5R. My plans are to run 13.5, lipo, rubber tires, on carpet. I’m really looking to get a car that I don’t have to spend to much money on to be competitive. What are your thoughts???
So what would I need to get this car working on carpet? Also could someone post a good starting point for a setup.
gfarb is offline   Reply With Quote
Old 09-06-2008, 06:25 AM   #7957
Yeti35's Avatar
Are you gonna run foam or rubber? If it is rubber go back a page or two and you can get Mike Haynes's setup from IIC this year. He TQ'd and won 13.5 rubber with that setup and I ran it as well at IIC. It is very drivable and worked well on high bite carpet.
For foam you can try this setup: http://www.petitrc.com/reglages/losi...IC20070930.pdf I ran this at IIC as well this year and again very driveable.
22 2.0
22T 2.0
Old 09-06-2008, 10:16 PM   #7958
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I just purchased the Type R and was excited to build it, when I got to the rear section (Bag C) there was 2 identical hindge pin blocks. It is mis-packaged, so my building came to a halt Now I have to wait till Monday to order a set, Rant over
bigkoitat is offline   Reply With Quote
Old 09-06-2008, 10:25 PM   #7959
Yeti35's Avatar
Don't pay for them, contact Horizon and get them replaced.
22 2.0
22T 2.0
Old 09-07-2008, 03:52 AM   #7960
tim fry's Avatar
I've got a problem with one of my wheel hexes. No matter what wheel I put on it the wheel wobbles slightly. It also means I get different camber readings depending on where its sitting. Should I just get a replacement or some alloy ones? If so what part number are the standard alloy hexes?
tim fry is offline   Reply With Quote
Old 09-07-2008, 05:45 AM   #7961
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I would switch to the alloy ones.
Heres a link
http://www.losipartshouse.com/servle...w-(STK)/Detail
Also depending on what you are running you may want to try .195s all around for foam or .195s in the rear and .165s in the front for rubber.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 09-07-2008, 01:40 PM   #7962
had a the same problem with my car and found that the only way to get rid of the problem was to fit some jrxs axil shims behind the hex pins as thay are a few thou thicker than the "r" shims and this will take up the slack wear the
axils go through the bearings
Ben + Geoff Wal is offline   Reply With Quote
Old 09-07-2008, 01:46 PM   #7963
just wondering if your out there mike haynes if you could let me know what your "up travel limters" where set to as no one seems to mention these and i find them a very powerfull adjustment
Old 09-07-2008, 02:21 PM   #7964
tim fry's Avatar
I have already tried this but it was no better. I just think the hex is distorted. I will give it another go though
Old 09-07-2008, 03:44 PM   #7965
Yeti35's Avatar
I can't recall presonally ever using them myself and never seen reference to them in setups.
22 2.0
22T 2.0
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
