Old 08-18-2008, 06:13 AM   #7846
Yeti35's Avatar
Originally Posted by Rdog View Post
Hey guys just got my losi r put together and was wonder about the spool mainly the correct way to install it. Do you still use the thrust bearing and spring? Thanks any any help i can get.
Yes, you still use the thrust bearing and the spring. It goes together like the diff except you lock it down for no movement at all. Don't go too nuts on tightening it or you can strip the outdrive.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-19-2008, 10:16 AM   #7847
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Any tips for freeing up the tie rod ends? I tried to install the rpm ones and they are very tight..
thanks
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-19-2008, 10:42 AM   #7848
Yeti35's Avatar
thanks
I just use the ones that came with the car and never had a tightness issue at all. I do have standard long ball cups on the rear of my car to get a long camber link but I am using the Losi grey ball cups for that. I just have those in my box from my offroad stuff. They are not tight on the ballstud either.
22 3.0SR
Old 08-19-2008, 11:35 AM   #7849
J@UNE's Avatar
Default For RPMs ball studs,
Once they are poped on, use some plyer to squish them over the ball stud...
I usualy do that 3-4 times and they become free enough.
J@UNE is offline   Reply With Quote
Old 08-19-2008, 02:49 PM   #7850
nitrobeast's Avatar
I have those too but wanted to try the rpm ones.
I will give that a try
Rui Goncalves
Old 08-20-2008, 07:12 PM   #7851
MaxRain's Avatar
do you know what the part number is on those ball cups?
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 08-20-2008, 08:33 PM   #7852
vabroom's Avatar
Here all the Losi's ball cups:
http://www.losipartshouse.com/servlet/Categories
Sorry no dimensions.
vabroom is offline   Reply With Quote
Old 08-20-2008, 09:35 PM   #7853
Yeti35's Avatar
Here is the stock kit ones: http://www.losipartshouse.com/servle...aptured/Detail
Here is the ones I used for the long camber link in the rear: http://www.losipartshouse.com/servle...id-Ball/Detail
I was not sure which ones you were asking about.
22 3.0SR
Old 08-22-2008, 07:32 AM   #7854
MaxRain's Avatar
the part # 6016 is what I was looking for. I too have tried making the link longer with the standard size cups that come with the kit, but I find that if you hit the wall it is a little fragile. The inside part of the cup doesn't seem to hold well. Largely due to the titanium rod beeing a little on the short side.
Facebook: CARCAR
Old 08-22-2008, 08:58 AM   #7855
schreff's Avatar
Send a message via AIM to schreff
Guys... just a quick FYI...
When Larry and I switched to using the long link in the rear, as in hole 4 on the tower and B on the hub, we replaced the small titanium tierod with a 1" Lunsford tierod. The 1" tierod is thicker and longer eliminating ball cup issues. Ever since switching to that, we never broke another rear ball cup or even had them pop off. For anyone running a longer rear link, get yourself a pair of the 1" lunsfords.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 08-22-2008, 10:50 AM   #7856
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Schreff,
Is the 1" exact length enough for that or will I need 1.125 or 1.25 or will those be too long? Thanks for the suggestion as I have had that problem and this will solve it.
Ty is offline   Reply With Quote
Old 08-22-2008, 11:49 AM   #7857
schreff's Avatar
Originally Posted by Ty View Post
Schreff,
Ty,
1" is the exact length of the tierod that we are using.
-Jason Schreffler-
Old 08-22-2008, 06:39 PM   #7858
MaxRain's Avatar
Originally Posted by schreff View Post
Ty,
Schreff, thanks for the tip.. I was thinking of doing something like this also, as I was looking at an associated tierod, length was 0.825".
Seeing that you use the 1", I will make my way and pick a set up.
Also, for those who are curious, I got my Platinum Two's today.. Fit in the Type R with no mods, using both the plastic lipo tray and with the losi weighted lipo tray.
Will post picks later..
Facebook: CARCAR
Old 08-23-2008, 04:51 AM   #7859
JRXS_chris's Avatar
Default An experiment...
In a quest for a little more tarmac capability I am conducting a little test next time out.
Them posts on the top deck are maintaining masses of chassis stiffness but this eliminates some of the tuning potential that the Xrays, Hotbodies etc can offer with regards to flex. Sooo off they come!
I had to dig around my parts box to see what I could use instead of the posts to keep the battery plate securely fastened. After a few minutes thinking and tinkering I found that some old XXXS shock towers would do the trick. I hacksawed off the camber link mounting holes and screwed them onto the chassis, the holes are perfectly placed.
You can see in the image what I have removed.
This is what the chassis looks like with them in place
(Apologies for the blur! Taken on my mobile!)
With the new bits on the chassis still resists tweak but offers a lot more flex.
Lets see how it goes!
JRXS_chris is offline   Reply With Quote
Old 08-23-2008, 05:58 AM   #7860
Yeti35's Avatar
Are you running in a low bite situation in that you felt you needed flex for traction? I run on low bite as well but have a setup on the car that is planted and my post are still in the car. I think you need to look at your setup more rather then messing with chassis tweak by removing the post. There is no reason to remove them to get the car to handle. I am sure Schreff and Fairtrace would back me on this. Since they don't feel it is necessary to remove them either.
22 3.0SR
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
