Old 08-13-2008, 09:04 AM   #7831
RaceAce701's Avatar
Trader Rating: 84 (99%+)
thanks
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-13-2008, 05:59 PM   #7832
Does anyone having problem with the steel tray not fit into the chassis? I couldn't able to install the steel tray into the chassis even with no battery on it.
ioxqq is offline   Reply With Quote
Old 08-13-2008, 06:15 PM   #7833
YmeBP's Avatar
Trader Rating: 32 (100%+)
I did i whipped out the handy dandy file and made the armpits a little deeper to make it fit nicely.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 08-14-2008, 04:01 AM   #7834
nitrobeast's Avatar
Trader Rating: 41 (100%+)
What he said..
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-15-2008, 07:37 PM   #7835
MaxRain's Avatar
Default Orion platinum two
has anyone purchased the Orion platinum Two 5000 mAh for their type R?
I am asking as I have placed my order with RCMart, who is selling them for 85.90 each plus the usual shipping..
As far as I know these will fit the type R and are slightly lighter than the orion 4800 with the extra mAh. 137mm x 45mm x 24mm
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 08-15-2008, 09:23 PM   #7836
Andy Crosson's Avatar
I hope so...
www.hobbyplexraceway.com
Ken's Graf/x | Stickit1
Team Losi Racing | Spektrum | ORCA | Tekin
2011 8-Hour & 2010 2.4-Hour Trans-Am Enduro Champions: Me, Wilcox, Hatcher, Romanik
Andy Crosson is offline   Reply With Quote
Old 08-15-2008, 11:14 PM   #7837
big_boss's Avatar
The 5000 "two" fits the type R.
I ran it yesterday at our track , seems fine to me.
Losi 8ight brushless, Losi xxxt-cr, Losi jrxs type R, Losi street weapon,
Rc10T1 rebuilt, Rc10 "worlds" .Xray T2, Atlas YM-34, Losi XX pro SE
TRC Predator Lynx 2. Tenth Technology super touring, Predator X-10, X-11.
Losi Micro-T, Losi Mini-T, Rc18T, Xray M18
Schumacher Fireblade Evo. All Electric
big_boss is offline   Reply With Quote
Old 08-16-2008, 02:20 AM   #7838
cclifton's Avatar
Send a message via MSN to cclifton
Hi there,
I have been trying to compile some information through this forum for my new car and still have a couple questions maybe you guys can answer. I am trying to make the switch from Xray to my new JRX-S Type R.
First, we are running a new spec type class on carpet with Jaco green rubber tires and I am really trying to find a good starting point for a setup and was wondering if someone can help with with that. We are running a 17.5/Stock class.
Second, we are able to run a couple different lipo packs and I was wondering if anyone has had trouble fitting them in there car. I lipos include orion 3800 30C, IP3800, and the SMC packs.
Thank you
Chris
cclifton is offline   Reply With Quote
Old 08-16-2008, 05:37 AM   #7839
Yeti35's Avatar
Originally Posted by cclifton View Post
Hi there,
Thank you
Chris
I can tell you for sure the Orion 3800 does not fit unless you want to mod the pack or the car to make it fit. Not worth it in my opinion. I have no experience with the IP pack. I think the SMC packs fit with no issues.
You can try setups from here: http://www.petitrc.com/view_news.php?id=4620 and I would recommend starting with the Schreffler Express 2007 setup. It is for medium bite and should work pretty well.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-16-2008, 06:50 AM   #7840
YmeBP's Avatar
Hi there,
Thank you
Chris
With the jaco greens i'd pay careful attention to camber settings front and rear. They have a shorter sidewall and don't flex as mush as some other brands of tires (hold tires side by side you'll see what i mean), so if you don't increase camber to accomodate that you'll be riding on the sidewall of your tire allot.
Good thing to keep an eye out for is if the jop of the "J" in jaco on the side wall starts to look weird or wear, increase camber by .25* or .5* increments until the wear stops. You can also look over the profile of the tire, holding it up so that it kinda looks like this |-------| you want the dashed part in the middle to be wearing evenly, if you get a coned tire or you see that there is no wear on the inside of your tire |___/----| kinda like that or /___/----|you need to increase camber as well (you can tell ascii art was not my calling).
The other big tuning aids that i've gotten help with being a crappy driver and even worse at tuning is the ackerman position on the steering cross bar, move your ball studs to the inside hole.
The last big tuning aid is rear camber link hole, there is a set of posts in this thread that go into detail about how and what they do search for "rear camber link", schreffler gives a great explaination of how and why (has a ton to do w/ camber gain) and mike haynes, ron goeter, larry fairtrace, mike major all showed me more about how to use that tunig aid to get the rear stuck!! so start out w/ the inner camber link in hole #4, and the outer camber link in the outer hole (farthest away from the center line of the car i think it's A but not sure) if you want more on power rear traction move that to the inner position (b) there are also things you can do w/ #4 washers under the camber links and ball studs but they are for after you make the major basic changes and need a little more of this or that.
The losi community is very helpful, every track i visit that has losi drivers they are always very willing to help a new or struggling driver (you can tell I got tons of help ahahaha) so seek one out.
Old 08-17-2008, 01:21 PM   #7841
JRXS_chris's Avatar
Hey folk, just after a little bit of help. I can't seem to scrub off the understeer that my chassis is generating on fast corners, ie coming off the straight or entering the straight. I've tried loads of tweaks and none seem to be doing the trick, any ideas?
(outdoor, tarmac/asphalt, medium grip, 5 cell brushless 3.5t, Sorex 32s)
Cheers guys!
JRXS_chris is offline   Reply With Quote
Old 08-17-2008, 03:26 PM   #7842
TJames987's Avatar
Trader Rating: 10 (92%+)
I Just raced at a parking lot race and the car would not hookup at all it was VERY loose in the rear and very difficult to drive. I have a front-oneway in the front now and the tracktion is medium to low; would anyone suggest a front spool instead to gain more traction?
TJames987 is offline   Reply With Quote
Old 08-17-2008, 05:03 PM   #7843
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Cheers guys!
Try using the inner holes on the steering Ackerman plate.
I would defiantly run the spool over the oneway.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 08-17-2008, 07:06 PM   #7844
MaxRain's Avatar
did you have to make any mods to the top deck.. ie dremel?
Facebook: CARCAR
Old 08-17-2008, 09:58 PM   #7845
Rdog's Avatar
Trader Rating: 83 (100%+)
Hey guys just got my losi r put together and was wonder about the spool mainly the correct way to install it. Do you still use the thrust bearing and spring? Thanks any any help i can get.
Rdog is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
