Old 08-06-2008, 06:29 PM   #7771
MikeMalinconico's Avatar
Does the smc (4000) lipo battery fit the steel tray.
Serpent america.
Brooklyn hobbies.
Speedzone batteries&motors.
MikeMalinconico is offline   Reply With Quote
Old 08-06-2008, 06:42 PM   #7772
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
thats some good info thanks
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 08-06-2008, 07:17 PM   #7773
Mike Haynes's Avatar
You will need to grind a little off the inside of the tray for it to fit right.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 08-06-2008, 07:55 PM   #7774
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
I'm almost ready to go all lipo, but i was wondering, what packs fit?
does someone have a list?
with preferably minor hand-fitting?
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 08-06-2008, 08:53 PM   #7775
MaxSp97's Avatar
No MODIFY need!
Fit like glove with Metal Lipo Tray.
Trakpower | # FPW TP49002S
Team Checkpoint | # TCPC3654 "made by Trakpower"
http://www.nexusracing.com/index.php...0e8b019f9ce888
My choice is Red color "Gold is too much for me".
Cal,
MaxSp97 is offline   Reply With Quote
Old 08-06-2008, 10:16 PM   #7776
Kajman's Avatar
Anyone ever tried to put A123 / LiFePo4 pack inside? 4 cells. I'm amazed by this chassis, want to buy it, but I use only a123 and liion packs which are little bigger than sub-s nimh.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 08-06-2008, 10:34 PM   #7777
Yeti35's Avatar
I can tell you the Orion 3600 will not fit w/o modification to the pack it's self. I was going to borrow some packs for IIC and am glad I tried it before I got there. So I just purchased some new Nimh packs for IIC and will convert to Lipo at a later date.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-07-2008, 04:52 AM   #7778
TaJoe5's Avatar
Send a message via AIM to TaJoe5
A little? I spent about 2 hrs on it. LOL
OHP Batteries and Motors, http://www.ohiohobbyplus.com/
Razor Graphix, Team Losi Type-R, Tamiya EVO-IV, CRC Gen X
TaJoe5 is offline   Reply With Quote
Old 08-07-2008, 04:55 AM   #7779
tim fry's Avatar
I'm trying to find some alternative ball cups as I find the standard ones rubbish. I have tried RPM as recommended but as I run the outer pick up on the hub at the rear the RPMs rub the wheel. Has anyone tried any others?
Tim
tim fry is offline   Reply With Quote
Old 08-07-2008, 05:18 AM   #7780
MikeXray's Avatar
Trader Rating: 73 (100%+)
I've done 3 of them already, the first one I spent way too much time on, the easiest and fastest way is to use a 4" cutoff wheel or a good grinding bit, just shave the edges of the inside of the tray down. The inside of the tray is radiused a little too tight for the pack, you just to grind that out.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-07-2008, 05:51 AM   #7781
Thanx Mike.Will the car be legal wt.with the steel tray and lipo.
Serpent america.
Brooklyn hobbies.
Old 08-07-2008, 06:02 AM   #7782
MikeXray's Avatar
With an SMC 4000, SP LPF, futaba faast receiver and JR8800s servo I needed, 35g on the left side for balance, and about 25g on the battery to make weight. I also recommend strapping the battery to the tray, I had one of mine end up in the belt.
Old 08-07-2008, 06:56 AM   #7783
YmeBP's Avatar
Trader Rating: 32 (100%+)
Tim
I picked up a tip from the Mike Haynes at 360, he puts very short screws and an o ring in the ball studs to keep them on the car in the event they pop off. I'll have to take a photo to show you. I lost the b-main because of that very same issue ;(. I touched the wall a leeeeetle too hard adn POP! off it came and there went my hopes and dreams of a b-main victory.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 08-07-2008, 10:56 AM   #7784
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
i know it was posted a while back and i just cant find it. someone was running an asphalt setup geared at 104/?? and i cant remember the motor, but i know it worked for whoever did it. any help would be appreciated
thanx
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 08-07-2008, 11:50 AM   #7785
John Tag's Avatar
Trader Rating: 42 (100%+)
thanx
Normally 104s are run with 17.5 motors. Most common pinion gear is 53 range.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
