Old 08-01-2008, 07:37 PM   #7726
YmeBP's Avatar
Trader Rating: 32 (100%+)
should i put diff lube on my spool diff rings?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 08-01-2008, 07:44 PM   #7727
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
No....
You coming to my race at T&L?
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 08-01-2008, 07:44 PM   #7728
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by Rdog View Post
Hey guys thinking about buying the type r but was wondering if losi was planning on releasing a new car anytime soon. Dont want to buy a new car only to have it outdated in 6 months. Thanks
No, a new car isn't coming out anytime soon from Losi. The Type R will be a 2 years old "publicly" in March '09. So no, it won't be outdated in 6 months.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 08-01-2008, 08:24 PM   #7729
Rdog's Avatar
Trader Rating: 83 (100%+)
Ok so what are some thing I need to know about the car before I buy? Special parts to buy? Good rubber tire set-up for med to high grip asphalt? Any info would be great thanks
Rdog is offline   Reply With Quote
Old 08-01-2008, 08:30 PM   #7730
mojoman's Avatar
Originally Posted by Yeti35 View Post
The spindles have been the same design since the XXX-S. Only difference is they went from Graphite to EA3. So if your shop has that stuff for the XXX-S or XXX-4, you can use those on your JRXS. Hinge pins from the JRXS and Type R should be the same. Only real difference is the arms since the Type R are longer.
Edit.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 08-01-2008, 08:42 PM   #7731
RussB's Avatar
Send a message via MSN to RussB
nothing from a xxx4 will fit the car other than screws and bearings.
the xxxs castor blocks are not chamfered to clear the springs. that was a running change made for the jrxs.
the xxxs steering knuckles don't have the extra ackerman hole, again, running change made for the jrxs.
RussB is offline   Reply With Quote
Old 08-01-2008, 08:53 PM   #7732
mojoman's Avatar
As far as I know all the old parts for the xxx-4 and xxx-s have been discontinued by losi and the original jrxs parts and p/n's were used in there place so yes those parts will fit the old jrxs even if they are the old p/n's. The newer p/n's are different because of the new material used in the mold.
Casey
Casey Castleman
Old 08-01-2008, 10:04 PM   #7733
Yeti35's Avatar
Originally Posted by mojoman View Post
Also the material. Graphite vs. EA3.
I think I did say that in my post.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-02-2008, 05:16 AM   #7734
mojoman's Avatar
Yea I realized that after I posted. Further more I checked losi parts house and apparently they still make the short knuckles for the xxx-s. The question was if the knuckles for the type r will fit on the old jrx-s and the answer is yes. Sorry for the confusion.
Casey
Casey Castleman
Old 08-02-2008, 06:49 AM   #7735
YmeBP's Avatar
Originally Posted by Ron Goetter View Post
No....
Where/when is it? If i don't have family stuff planned i'll be there w/ bells on!!
Old 08-02-2008, 06:54 AM   #7736
End of the season Bash at Trains and Lanes
Its looking like its going to be either the first or second sat in Sept...
Old 08-02-2008, 08:01 AM   #7737
schreff's Avatar
You can find several setups throughout this thread regarding asphalt setups. Search for posts from Larry Fairtrace as he has a heck of an asphalt setup this season. He's been basically unstoppable on rubber tires this summer.
As for special stuff needed for the car, I wouldn't say there's much. Outside of the kit, get the following for rubber tires...
-2 Sway Bar Kits (same front and rear)
-41 and 42 tooth spool pullies (both for tuning purposes)
-2 Sets of 15lb springs (kit comes with 30s and 17.5s)
-45wt and 40wt shock oils (kit comes with 50wt)
-1 degree rear hubs
-0 degree and 1 degree arm mounts (car comes with 2 degree rear mount)
-Extra set of turnbuckle, .380 ball studs, and ball cups to put a standard camber link up front (replacing the Jr link the car comes with)
-.165 and .195 aluminum hexes (comes with .165 plastic hexes, aluminum is much preferred)
That should do it as far as setup items you'll need. That'll cover you for both carpet and rubber tires. The only thing I didn't list is a 1 way front diff. You only really need that for rubber tire carpet racing. Asphalt is usually always a spool. If you do plan on running carpet with the car at some point, make sure you get some 6* caster blocks as the car comes with 4* blocks. Any other questions, we're here to help.
-Jason Schreffler-
Old 08-02-2008, 01:01 PM   #7738
Rdog's Avatar
-1 degree rear hubs
Thanks alot really appreciate it
Old 08-03-2008, 07:58 AM   #7739
tim fry's Avatar
Is there a better bumper available? My standard one has taken a battering.
tim fry is offline   Reply With Quote
Old 08-03-2008, 08:01 AM   #7740
Matt Howard's Avatar
I think it's parma that makes a stiffer foam bumper for the car, don't know the part # though.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
