Old 07-21-2008, 01:54 PM   #7681
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by yyhayyim View Post
with an RS in mix you'll be in A
You aren't kidding hahah, my car feels soooo much better w/ the tekin than w/ the gtb! It could be all in my head but somehow i doubt it. Either way i need a bit more wheel time to get into the a, i'm inconsistent now and that is killing me. This is only my second season back from a couple year break in racing so it will come back to me.
Do have suggestions for a 3.5 brushless (novak Light) w/ the tekin (rs pro) in the losi running lipo?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-21-2008, 02:03 PM   #7682
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Anyone have an extra Losi steel tray (LOSA4312) they want to sell or know of any shops with them in stock?
Thanks,
Ty
Ty is offline   Reply With Quote
Old 07-21-2008, 02:09 PM   #7683
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
gear it around 9.5FDR and with the tekin about 10 % - 12% timing
Old 07-21-2008, 02:25 PM   #7684
tim fry's Avatar
Originally Posted by L.Fairtrace View Post
If your rear end is loose go to the 4a link like everyone says and about 2.5mm uptravel front 2 rear.
17/15 springs on most tracks.
I've been running 3 degrees rear toe lately 1 on the chassis, 1 on the hub, 1 on the block.
Also overdrive.
45/40 oil.
High Front, Low rear roll center.
either 4 degree caster blocks or 6 degree blocks and 2 degrees of antidive.
I usually always run high front diff on rubbers, and low or high rear diff depending on the feel of the track.
I always run the long ackerman link on asphalt since I switched to it at the beginning of the year.
Cool thanks for that it gives me some options to try.
How does moving the rear link inwards generate more grip? I was always under the impression that a longer more outward link generated more roll and thus more rear traction. I'm not questioning your guidance just like to understand the reasons.
tim fry is offline   Reply With Quote
Old 07-21-2008, 02:30 PM   #7685
mtveten's Avatar
Trader Rating: 27 (100%+)
What ackerman position are you using for the steering posts?
I recently picked up a type R and so far have been please with its progress but I haven't quite gotten the initial turn on high to low speed entry or or transitional steering through s-turns I would like yet, any tips on how to improve the car in these areas would be appreciated.
So far I have found myself running high front w/low +030" rear roll centers, either 15 or 17.5lb springs and both ends, high front diff height with usually a high rear diff height & & overdrive spool. 1.25 deg camber on all corners with std fr link in #1 hole & rear link in 4/a, shocks all the way up in the front and all the way down in the rear, .40 bars front & back, 1.5deg rear toe with 2deg inboard and -.5 outer, arms back in the rear and centered in the front. 2.5mm uptravel in the rear, 1.5mm uptravel in the front, stk hexes, 35wt oil @ 50% rebound, 5mm height in the front & 5.5mm rear. ackerman is setup with posts forward, position 1 on the rack & knuckle w/ a .030 shim for bumpsteer.
In general the rear feels too planted at corner entry and onpower transitions and just pushes the front out of the corner. Weight is 50/50 front to back.
Mark
mtveten is offline   Reply With Quote
Old 07-22-2008, 03:42 PM   #7686
rcdougie's Avatar
Just listed a Type R on ebay if anyone is interested.
rcdougie is offline   Reply With Quote
Old 07-23-2008, 06:58 AM   #7687
YmeBP's Avatar
Mark
At the suggestion of racers from Jackson R/C raceway i switched the ball stud on the steering rack to the holes closest to the centerline of the car and BAAAAMMM! turn in!
Old 07-23-2008, 07:59 AM   #7688
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Where are you guys getting the .030 shims?
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 07-23-2008, 08:29 AM   #7689
Xpress's Avatar
.030" is @ .75 mm. TakeOff, 3Racing, Yokomo, and Kyosho each sell aluminum spacer in .25 and .50mm increments.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 07-23-2008, 09:49 AM   #7690
schreff's Avatar
Send a message via AIM to schreff
Losi part number A6215 (#4 washers) are the .030 washers or you could use any .75mm shim like Xpress said.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 07-23-2008, 09:54 AM   #7691
mtveten's Avatar
Already there and not only did it help increase steering throughout the corner it made it smoother as well.
I was thinking of thinking either lowering my front rc or raising the rear so that there was less or no stagger beetween them, has this been your experience? I also noticed they every setup I found uses the upper inner camber link position on the front wouldn't the increased camber gain by going to the lower hole make the front react faster?
The .030" ball stud washers are part # LOSA6215 for a pack of 10.
Mark
Old 07-23-2008, 09:58 AM   #7692
Uncle Cliffy's Avatar
Up for grabs: http://http://www.rctech.net/forum/s...d.php?t=233499
Uncle Cliffy is offline   Reply With Quote
Old 07-23-2008, 10:44 AM   #7693
YmeBP's Avatar
Mark
I haven't changed the front from stock yet. I have the front set like Fairtrace said, rear hingepin carriers high, front hinge pin carriers low gives you anti-dive (i think that is anti dive anyway hahah) other than that i have the rc low in the rear again the car was soooo dialed that it completely put my driving skills (or lack there of) on front street so i'm pretty much done tweeking the car until i start overdriving it again. My goal is to make the bottom middle of the "A" consistently by seasons end.
Old 07-23-2008, 11:18 AM   #7694
mtveten's Avatar
Are you running 6deg blocks then? with .030" equal to 1deg and a .110 diff between high and low carriers that would be approx 3.5deg antidive.
Mark
Old 07-23-2008, 12:00 PM   #7695
YmeBP's Avatar
Mark
I'm running 4degrees up front i'm going to try to go to 6 degrees if i feel the need. I don't have any spacers or shims.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
