Old 07-17-2008, 02:20 PM   #7651
tim fry's Avatar
Do you find running the JR link that it helps with rear end as it calms the front down then?
tim fry is offline   Reply With Quote
Old 07-17-2008, 03:06 PM   #7652
Yeti35's Avatar
All I can say is the setup on my car right now works for me. It is a colaboration of one of Shreffs setups with some changes made to it to work for me. Honestly there is not one setup for everyone. Driving styles play alot into a setup. I started out with a base setup and adjusted from there to suit me. Foam setup I have on my foam car I got from Schreff and that seems to work with no alteration. I could not use his rubber setup for asphalt completely since it made it too twitchy for me. He had regular links on his setup and I went to JR. That is only one of a few changes I made.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 07-17-2008, 03:14 PM   #7653
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Originally Posted by YmeBP View Post
Anyone using the JR z9100S servo? I'm thinking about getting one for my mod car and was curious if there are any fitment issues or if i should go w/ a low profile servo.
I run the "older" 9000s servo and there are no fitment issues.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 07-17-2008, 05:25 PM   #7654
RedRocketRacing's Avatar
Originally Posted by Yeti35 View Post
I personally run the JR link with rubber and regular with foam. So I guess I am kind of backwards from everyone here. I like the JR Link with rubber tires. Standard link was way too much steering for me.
I could understand that is the bite on your track high? Maybe I should try it again and see it it does settle the car down. We have a high traction asphalt and it might help for me to go back, there is another guy who does run it and he really likes it.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 07-17-2008, 06:29 PM   #7655
Yeti35's Avatar
RedRocket
No, if anything it is fairly low bite. I have a lot of other things going on to help out with that.
22 3.0SR
Old 07-17-2008, 07:00 PM   #7656
Just to let everybody know, I built a new spool useing all the actual spool parts (since I didn't for get them at home) and ran about 5 pack through the car and had no problems this time. Not sure why it didn't work before but with all new hardware and outdrives in it it was fine. So far.
RedRocket
NWIC 2008/09
Old 07-17-2008, 07:22 PM   #7657
YmeBP's Avatar
Trader Rating: 32 (100%+)
I didn't have enough steering w/ the jr link on my car but the track has a tight infield section, once i changed to reg links i got some of the steering back.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-18-2008, 06:08 AM   #7658
The Rev's Avatar
does anyone else have issues getting the diffs to be free without slipping? I can't get them right. A 1/4 turn too little, and they slip like crazy, and 1/4 more, and they stop diffin'. Im thinkin about the aluminum hub just to help the cause. I've removed the brass shim, otherwise they are stock. Any suggestions? I run a 3.5 w/ lipo, so they need to be goood.
Thanks!
The Rev is offline   Reply With Quote
Old 07-18-2008, 06:22 AM   #7659
Yeti35's Avatar
Thanks!
That brass shim was not a shim but meant to act as a slipper for applications such as yours. If you have not noticed the diff ring on that side is not keyed and will slip a little. Slippage was designed into those diffs so you are not tearing them up in Mod.
22 3.0SR
Old 07-18-2008, 07:34 AM   #7660
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
how many time to do break with your type R? and what part?
I'm running my type R for over 4-5 months now, 1 night a week (around 4-5 pack every night) with rubber, carpet and 13.5 BL.
I only broke around 5 ball cup (always the same) and I fix the problem with RMP ball cup and I broke one c-hub and one read hub.
that's it
previouly with my xray T2, I was breaking something every night
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 07-18-2008, 01:25 PM   #7661
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I don't break things often but when i do its normally a c-hub or a popped off ball end....
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 07-18-2008, 01:38 PM   #7662
don't brake many parts but the ball cups come off or split on a hit
Ben + Geoff Wal is offline   Reply With Quote
Old 07-18-2008, 02:07 PM   #7663
The Rev's Avatar
Yeti: thanks for the response. From my experience, slipping is what wears out diffs the quickest, so I'm unsure why slip would be designed into it? I talked with Matt howard at the nats, and he advised me to remove the shim. It helped, but not enough. I want to lock the thing so it does'nt slip. I'll try silicon carbide balls, by i'm thinkin it is the plastic hub that is flexing which is causing the diff to run tight and slip..? So anyway, are you saying that this diff slipping is a common problem (or not, depending on your view)..?
Thanks.
Old 07-18-2008, 03:17 PM   #7664
Yeti35's Avatar
Thanks.
This info actually came from Todd many post ago. He said they designed the slipper in to help out with Mod so it did not tear up diffs so much, but he also posted a procedure for setup of them too. I will have to see if I can find the post and get you a link to it. It is way back in this thread. From my understanding the diff that comes with the CR buggy and truck have this same feature built in. If you ever noticed the header cards for the diff rings say on them CR. I can't explain the reason how they came up with it, but that is why it is there. So the brass washer is not a shim, but more or less a slipper pad so to speak.
Ok, here is the link I found where Todd posted about the brass washer: Team Losi JRXS Type-R
22 3.0SR
Old 07-18-2008, 03:30 PM   #7665
b-man777's Avatar
Default losi at iic
hey all: Who will be on the losi team at the '08 iic race? Thanks
b-man777 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
