Old 07-10-2008, 11:24 PM   #7621
RussB's Avatar
Send a message via MSN to RussB
Originally Posted by dfiantii View Post
My Type R has finally arrived. Along with my esc.
so... are you gonna get that built in time to run the speedworld cup?
RussB is offline   Reply With Quote
Old 07-11-2008, 12:08 AM   #7622
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
I wish!!!!! My wife and I just bought a house so thats taking up ALL of my time. When is the race anyway? Maybe I will show up with my TT-01 and see what I can pull off in stock lol Probably last place
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 07-11-2008, 01:20 AM   #7623
PDM
About the spools.
I have been under the same problem, last nacional championship race I had to tight it every final.
I believe I must change the plastic parts and try again. The feeling i have is that if I hold the left wheel and the pulley and turn on the right wheel this will tight it, but that means that under braking turning to the left it will make the spool loose.
I will let you kown if I can go over this.
PDM is offline   Reply With Quote
Old 07-11-2008, 07:25 AM   #7624
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
congrat on your new car. i'm sure you will like it.
get a good setup and it will be very fun to drive.
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 07-11-2008, 08:29 AM   #7625
Yeti35's Avatar
Originally Posted by PDM View Post
About the spools.The feeling i have is that if I hold the left wheel and the pulley and turn on the right wheel this will tight it, but that means that under braking turning to the left it will make the spool loose.
I don't think that is a good way to tighten it. I stick a flat blade screw driver in the slot of the diff screw and tighten it that way. The way you discribed probably is not getting it tight enough.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 07-11-2008, 09:48 AM   #7626
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Ya your not really tightening it at all. that is just making the pulley slip. You have to hold the screw to tighten it properly.
If you replace the hub and tighten it well maybe even a little threadlock and your good to go for a long time.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 07-11-2008, 01:01 PM   #7627
Hi guys!
I've made a little shield to give a bit more protection to the esc. It's made out of a .030" lexan sheet.
Bye!
Fastfreddy74 is offline   Reply With Quote
Old 07-13-2008, 12:18 PM   #7628
tim fry's Avatar
Whats the best ball cups to use as I find the standard ones pop off a little too easy.
tim fry is offline   Reply With Quote
Old 07-13-2008, 09:23 PM   #7629
RedRocketRacing's Avatar
I am using RPM's they work pretty well and are readilty avaliable, you just have to shorten them a little bit to run the shorter link holes.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 07-13-2008, 11:49 PM   #7630
egalsim's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Fastfreddy74 View Post
Hi guys!
Bye!
What heatsink and fan combo is that on the motor?
egalsim is offline   Reply With Quote
Old 07-14-2008, 12:15 AM   #7631
It's from 3Racing http://www.3racing.hk/products.php?products_key=62
Old 07-15-2008, 05:59 AM   #7632
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
I just purchased a Type R and I will be running an LRP 17.5 brushless. I will be running on a medium sized carpet track with foam tires. Any recommendations on gearing and what size spur and pinion to purchase that will equal that ratio?
Thanks,
Ty
Ty is offline   Reply With Quote
Old 07-15-2008, 08:00 AM   #7633
egalsim's Avatar
Thanks man, that heatsink looks like it fits just right.
Old 07-15-2008, 08:25 AM   #7634
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Thanks,
Ty
I'm not sure if this will help but I run rubber on asphalt and I was told to use a 104 spur and a pinion in the mid 50's
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 07-15-2008, 09:34 AM   #7635
Trader Rating: 66 (100%+)
Send a message via AIM to joey
Thanks,
Ty
do you know the size of the track?
=Joe Wright=
joey is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
