Old 07-04-2008, 09:07 AM   #7561
Yeti35's Avatar
Originally Posted by YmeBP View Post
is that rollout or pinion/spur?
That is FDR that Tag is running on his motor.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 07-04-2008, 06:24 PM   #7562
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
anybody using a 6 cell with deans plugs? need a picture on how to snake the wires around chassis.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 07-04-2008, 06:27 PM   #7563
YmeBP's Avatar
Trader Rating: 32 (100%+)
I used to, i used the same angles the manual recommends for the battery bars and made sure the wires were on the opposite side from the belts.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-07-2008, 01:17 AM   #7564
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
I got a losi brushless and i must say that that thing is smoother than my old novak GTX and the motor is absolutely BALISTIC when compared to my brushed checkpoint money motors.
I ran it at a 4.8 fdr with NIMH and rubber tires, but i do have one question,
how do you guys mount the esc in a fassion so it doesn't seem like it could easily fall off in a crash. I run it on the driver's side on its (the speed control's) side so that the wires are pointing towards the back of the car and the set LED's are pointing strait up. I've noticed that there not only is little real estate on the chassis to mount something, but the case is pretty thin as well, limiting the amount of tape you can use.
thanks guys.
-Kyle
P.S.- I TQ'ed and won the 10.5 class at my local track with it on its maiden voyage.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 07-07-2008, 07:32 AM   #7565
Yeti35's Avatar
I have mine mounted on the other side layin flat rather then on it's side. I have had no issues with it coming off the chassis. I even left the track Saturday with a nice tumble and it is still intact. I think the speedo is pretty smooth also. I only bought the speedo and run it with a Novak 13.5 Pro.
22 2.0
22T 2.0
Old 07-07-2008, 07:55 AM   #7566
YmeBP's Avatar
thanks guys.
-Kyle
Couple pages back there are some photo's with mounting options, i put them in one post here: Team Losi JRXS Type-R
I have 2 cars and i have them mounted both ways, flat and in the side and i think on the side is better it gives the speedo a more solid mounting and it keeps the weight closer to the center. I honestly am not that good to notice the weight part, but the i can attest to it being solid . I hit something so hard it bent a hingepin and cracked the chassis and the speedo didn't come off (mounted on it's side)
Old 07-07-2008, 08:24 AM   #7567
Send a message via AIM to A. Rhodes
I stepped on a type r so hard it bent a hingepin and cracked the chassis but the speedo didn't come off (mounted on it's side)
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 07-07-2008, 01:16 PM   #7568
what do you guys do with the lllloooonnnnngggg ass sensor wire?
i noticed in larry's car he didn't have the sensor wire on in the pic...
Old 07-07-2008, 01:30 PM   #7569
dawgmeat's Avatar
I'm in the market for a new car but and anyone confirm the rumor about the type-R being discontinued?
dawgmeat is offline   Reply With Quote
Old 07-07-2008, 01:33 PM   #7570
MikeXray's Avatar
Trader Rating: 72 (100%+)
I don't think they would have made a new batch of lipo trays if the car was planning to be discontinued anytime soon. I wouldn't be surprised if there isn't a successor to it.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-07-2008, 02:35 PM   #7571
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
pick yourself up an 200mm lrp sensor wire part #81910
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 07-07-2008, 03:56 PM   #7572
tim fry's Avatar
Hi all
I ran my car Sunday and I used the kit asphalt setting but I ran on carpet with rubber tyres. We were meant to run outdoors but good old English weather put a stop to that! The car had a ton of steering so I dialed that out but I found that on power the rear could sometimes break free. I was going to stand the rear shocks up a hole but in my last qualifier I clipped the barrier and pulled the thread out of one of the top links and didn't have a spare.
Should I stand the rear shocks up a bit or would you go up a spring rate??
tim fry is offline   Reply With Quote
Old 07-07-2008, 04:02 PM   #7573
going up a spring rate as well as lengthening your camber links will help a TON, also, you can add a touch more front downtravel to allow the front to lift more on power.
good luck
Old 07-07-2008, 04:05 PM   #7574
YmeBP's Avatar
Originally Posted by A. Rhodes View Post
I forgot to add that one too, doooooode, I godzilla smashed Ron's car and his speedo was still on the car , i honestly think if that thing were flat it wouldn't have survived. .
Old 07-07-2008, 04:08 PM   #7575
YmeBP's Avatar
Originally Posted by tim fry View Post
Hi all
Before you stand the shocks up, do what a_main_atendee sugegsted, lengthen the rear camber link, i'd start w/ the #4 hole on the inside (middle inner) and the B hole on the hub carrier and tune from there, you may have to move to the a hole on the hub carrier if you find that you come loose on sweepers or entries to turns.
I'm going to test out raising the rear roll center later this week, i'll try to report from the track how it does.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
