Old 06-22-2008, 08:59 PM   #7441
Yeti35's Avatar
Originally Posted by metalracer2 View Post
anyone have any tips on how to get the rear end to hook up I'm running on asphalt with rubber
edit:: it's on a low bit track
I currently am running 35 wt in the rear with a 15 spring, longest camber link I can get 4/B. Washer under the ballstud on the hub, running .040 sways front and rear. 2/outside on the shock position, .165 hex in the rear .195 in the front, 45 wt oil front and a 17 spring. 5mm ride height with droop 2 above, high roll center front low rear, diff high in front and rear, low roll center rear. 1.5 camber front and rear, shock postition 2 on the front tower and I run the JR link low with a washer under the ball stud on the spindle. I got this info from Larry when I was having such a hard time getting my car to hook up. It worked awesome for me on Saturday with it allowing me to get faster every round I ran. 20 laps first heat, 21 second which I set TQ with, then 22 laps in the main and beat my TQ. I was running low to mid 14 second laps on the layout we had which was only a little bit slower then what the guys running 10.5 were doing. So I was quite happy with how it worked out.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-22-2008, 10:38 PM   #7442
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
Originally Posted by YmeBP View Post
I'm hunting the same thing and so far this is what i've found:
Longer camber links calm the rear down on entry, outside hole on the top of the rear hub carriers and upper inside hole on the inner mount, but then i started having trouble center corner out.
Schreff suggested i move the ball stud to the inner hole on the hub carrier, and the inner middle mount, that stuck the car mid corner out like a champ, but now it gets nervous on entry.
I have 7mm ride hight, droop is set to 2mm above ride height, i have 40w oil all the way around, 15lbs springs in the front, 12.5 in the rear, front diff high, rear diff low, anti-squat in the front, low roll center in the rear. -1.75 camber in the rear and -1 in the front. 2 degree toe block and 1 degree hub carriers. I changed the jr links to reg camber links, and running 4 degrees of caster in the front c hub.
The funniest part about this is i ran my 10.5 car after the races and it was only slightly loose (because of the tires i was running i'm sure they were 6 run jaco blues), but the car was balanced over all and i could drive it wherever i wanted to. Similar setup as above w/ some exceptions, low roll center front and rear, 5mm ride height, and long camber links in the rear (outer hole on the hub carrier, and upper inner hole on the inner camber link mount).
cool thanks for the help guys
i will try both set ups next weekend.
this weekend i tq and ended up 2nd so next weekend i hope to have tq and finish first
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 06-22-2008, 11:08 PM   #7443
RussB's Avatar
Send a message via MSN to RussB
anyone got a losi steel lipo tray they would be willing to sell? i am having a heck of a time finding one and it sounds like the won't be out in time for the 8th annual speedworld cup.
RussB is offline   Reply With Quote
Old 06-22-2008, 11:17 PM   #7444
Xpress's Avatar
The trays are out I got mine from Horizon last week. Too bad the darn thing does not fit in the chassis. Why does everything invole breaking out the Dremel tool?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-23-2008, 04:33 AM   #7445
YmeBP's Avatar
Trader Rating: 32 (100%+)
I would say the rear since you have them out of sync. You need to even the collars up and then set ride height trying to make sure you move both evenly so the whole car goes up the same. They may not end up being exactly the same due to maybe one spring being weaker then the other but should be pretty close. If the collars in the front are equal then those are fine.
Thanks for the tips!!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-23-2008, 06:04 AM   #7446
EViLSouL's Avatar
Send a message via AIM to EViLSouL
Yours needed to be Dremeled? Mine was alittle snug but fit pretty much perfectly.
EViLSouL is offline   Reply With Quote
Old 06-23-2008, 06:26 AM   #7447
Yeti35's Avatar
No problem at all. This seems to be the year when I finally start to understand all the little things such as that and what effect it has. Shame I could not learn that a few years ago.
22 2.0
22T 2.0
Old 06-23-2008, 06:32 AM   #7448
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Al Sodano View Post
This question probably has been answered,just to lazy to check all the posts
What do you guys like for a lipo in the losi.I mean fit wise and access for the wiring.Thanks
On Saturday I tried one of Rudy's smc 4000 in the losi and it fit with no problem. He was using it in his xray and took it out for me to try.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-23-2008, 09:34 AM   #7449
Originally Posted by bigb11 View Post
does any know what spur/pinion to start with the losi 17.5 brushless system?
yeha i also would like to know what spur and pinion u guys are running
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 06-23-2008, 09:45 AM   #7450
Trader Rating: 21 (100%+)
Default spur/pinion
108/ low 50's
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 06-23-2008, 01:17 PM   #7451
tim fry's Avatar
Hi all
Where is the best place to put the extra weight needed when running a Trakpower lipo. I need to add 150g but theres not a lot of room left with myu GTB fitted so was wondering if there is any tips for weight placement.
Tim
tim fry is offline   Reply With Quote
Old 06-23-2008, 01:55 PM   #7452
RedRocketRacing's Avatar
Most guys are running the steel lipo tray to add there weight. Since you are loosing weight in the battery location the best thing to do it to put it back in the battery location. and or right down the middle. Try to keep a weight bias in the ballpark of 50/50. I try to run about 45F/55R. I don't run lipos however. You will probably have to add some to the reciever side of you car to ballance the GTB. I believe taht alot of guys run a little wight in the rear of the car to, maybe 21g. That is what I have, with 49g on the reciver side. Hope this helps.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 06-23-2008, 03:22 PM   #7453
tim fry's Avatar
Cool thanks for that. Are the Lipo trays counter sunk like the plastic ones so that they hold the lipo or are they just flat plates?
Tim
Old 06-23-2008, 03:32 PM   #7454
Yeti35's Avatar
Tim
Just like the plastic ones, but only metal and heavier.
22 2.0
22T 2.0
Old 06-23-2008, 03:43 PM   #7455
tim fry's Avatar
Excellent. Where is the best place to get one as here in the uk Horizon dont do them
Tim
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
