Old 06-22-2008, 03:50 PM   #7426
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
Originally Posted by Al Sodano View Post
This question probably has been answered,just to lazy to check all the posts
What do you guys like for a lipo in the losi.I mean fit wise and access for the wiring.Thanks
core 5000 fits with no problems
Old 06-22-2008, 03:53 PM   #7427
schreff's Avatar
Send a message via AIM to schreff
Al, I'll answer this one for ya as I got to see Ronnie G and Mike Major run Lipo this past weekend. The TrackPower 4900mah 25C pack is awesome. It fits the car like a champ with no modifications to the car or pack casing. The CheckPoint 5400mah fits good too.
Also, the next run of Lipo trays should be done in about a week or 2. They were just going out for the black coating then have to come back for the Type R engraving.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 06-22-2008, 03:54 PM   #7428
schreff's Avatar
Originally Posted by EViLSouL View Post
There was some top secret testing going on at the Mushroombowl Speedway last night. Heres a sneak peak of what fuels Schreff.
I'm still waiting for my free gas!!! Worked great as a chassis protector.
-Jason Schreffler-
Old 06-22-2008, 03:57 PM   #7429
tim fry's Avatar
Hi all
Where is the best place to put the extra weight needed when running a Trakpower lipo. I need to add 150g
Tim
tim fry is offline   Reply With Quote
Old 06-22-2008, 03:59 PM   #7430
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Hey Al
Track power 4900's or the check point 4900's fit np and have awesome rip!!!
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 06-22-2008, 04:05 PM   #7431
EViLSouL's Avatar
Send a message via AIM to EViLSouL
Al,
I ran the Checkpoint 5400 with only one small modification. I had to dremel the top deck a little to make the bullet connectors to fit. Other then that the cells fit perfectly even with the shrink. I ran the weighted tray and Mr. VIP ran the stock plastic. Both cars had rip, Ron might have had more then me but his car became a skateboard so that slowed him down.
EViLSouL is offline   Reply With Quote
Old 06-22-2008, 04:19 PM   #7432
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
does any know what spur/pinion to start with the losi 17.5 brushless system?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 06-22-2008, 04:27 PM   #7433
Al,
No its a new car losi just released the Type Roller skate
Old 06-22-2008, 06:05 PM   #7434
BDK
Hey guys, my dad and I have started racing a few months ago, and we're ready to step up to a competative car. Does anyone here have any pro's and con's to till me about the car listed in this thread? Any help would be very much appreciated. Thanks.
BDK is offline   Reply With Quote
Old 06-22-2008, 06:13 PM   #7435
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
anyone have any tips on how to get the rear end to hook up I'm running on asphalt with rubber
edit:: it's on a low bit track
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 06-22-2008, 06:16 PM   #7436
YmeBP's Avatar
Trader Rating: 32 (100%+)
Another testament to the durability of the car, if i can strap it to my foot and do two laps and it still be in only a "few" peices then i'd say it's a winner!!
I saw a similar a-town stomp happen at the track down in MD, I wasn't quite sure what the car started out as but it ended up in about 14 pieces, the driver needed a dustpan to get it off the track.
i'm sorry about that, it was all nathan's fault ... or wait no scooby's fault ... hmm maybe darren's fault!! No it was dave's fault if he hadn't crashed i wouldn't have had to marshal, and i won't have mushed your car, i'll have to have a talk w/ him next weekend .
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-22-2008, 06:24 PM   #7437
YmeBP's Avatar
I'm hunting the same thing and so far this is what i've found:
Longer camber links calm the rear down on entry, outside hole on the top of the rear hub carriers and upper inside hole on the inner mount, but then i started having trouble center corner out.
Schreff suggested i move the ball stud to the inner hole on the hub carrier, and the inner middle mount, that stuck the car mid corner out like a champ, but now it gets nervous on entry.
I have 7mm ride hight, droop is set to 2mm above ride height, i have 40w oil all the way around, 15lbs springs in the front, 12.5 in the rear, front diff high, rear diff low, anti-squat in the front, low roll center in the rear. -1.75 camber in the rear and -1 in the front. 2 degree toe block and 1 degree hub carriers. I changed the jr links to reg camber links, and running 4 degrees of caster in the front c hub.
The funniest part about this is i ran my 10.5 car after the races and it was only slightly loose (because of the tires i was running i'm sure they were 6 run jaco blues), but the car was balanced over all and i could drive it wherever i wanted to. Similar setup as above w/ some exceptions, low roll center front and rear, 5mm ride height, and long camber links in the rear (outer hole on the hub carrier, and upper inner hole on the inner camber link mount).
Old 06-22-2008, 08:06 PM   #7438
yyhayyim's Avatar
Trader Rating: 26 (100%+)
7mm rear ride height? This is quite high...for outdoor asphalt it should be around 5mm- 5.5mm in most cases. Bring the rear ride height down to 5mm and you'll see much better results.
yyhayyim is offline   Reply With Quote
Old 06-22-2008, 08:11 PM   #7439
YmeBP's Avatar
The 'bowl has some pretty big bumps , my other car has 5mm and it bottoms quite a bit.
Old 06-22-2008, 08:41 PM   #7440
Yeti35's Avatar
Originally Posted by nitrobeast View Post
All 4 shocks are at 63.5mm. If i have this issue in the rear does it mean the tweak is coming from the front? When you say move them at the same time does that mean one goes up and one down until you get them the same?
thanks for the help
I would say the rear since you have them out of sync. You need to even the collars up and then set ride height trying to make sure you move both evenly so the whole car goes up the same. They may not end up being exactly the same due to maybe one spring being weaker then the other but should be pretty close. If the collars in the front are equal then those are fine.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
