Old 06-10-2008, 10:49 PM   #7351
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
I think I am going to buck the trend again RussB and go with the SpeedPassion. Were already bucking the trend going with the Type R which is no copycat like the others.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 06-11-2008, 03:10 AM   #7352
PDM
Originally Posted by RussB View Post
PDM, regarding your spool problems... are you positive the spool is assembled just like a diff with the only exception being swapping the balls for the spool pads? It almost sounds like the thrust bearing may not be installed or greased or something.
also maybe try replacing the outdrive that the screw threads into.
I will change the outdrive and see what happens.
Thanks, everybody.
PDM is offline   Reply With Quote
Old 06-11-2008, 06:31 PM   #7353
RussB's Avatar
Send a message via MSN to RussB
sure, why not? i really don't think that these differences in feel are the things that are going to cause club racers to win or loose races. at my level, it's all about not hitting stuff
RussB is offline   Reply With Quote
Old 06-11-2008, 06:39 PM   #7354
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Got my car in today and have a problem with the shocks. With the piston on the shaft it doesn't move freely once its in the shock? I don't think the shaft is bent. It seems like the piston is too thick? Anyone else have a problem like this?
thanks
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-11-2008, 06:54 PM   #7355
Mike Haynes's Avatar
thanks
If you look closely, there is likely a little bit of the mold flashing on the sides of the piston, roll it on a piece of sandpaper until it travels freely.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-12-2008, 03:26 AM   #7356
nitrobeast's Avatar
Thats what I did after i posted this and it worked great!! One more thing. Do you have a good way of making the camber link move freely on the ball? One of them doesnt allow the arm to drop on its own. If I take the link off the arm move fine.
Rui Goncalves
Old 06-12-2008, 03:31 AM   #7357
Matt Howard's Avatar
squeeze it slightly with a pair of pliers, test it and squeeze a bit more if it's still not loose. If that doesn't work I would inspect the ball itself to make sure there are no burrs or rough spots on it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-15-2008, 04:15 PM   #7358
Send a message via AIM to UofAJoe
Are spur gears universal or do i need to order specific jrx type r spur gears made by losi...? What gears have people been running on stock carpet?
-Joey Hawkins
Systems Engineering
University of Arizona
UofAJoe is offline   Reply With Quote
Old 06-15-2008, 04:23 PM   #7359
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
If you want to run standard spurs you have to by a prs adapter otherwise stock is all you can run...
http://www.precisionracingsystems.com/products/18
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 06-15-2008, 05:48 PM   #7360
YmeBP's Avatar
Trader Rating: 32 (100%+)
O.k. I have some proof the new arms are a bizzilion times stronger than the older arms.. ladies and gents i present to you ... a VERY bent hingepin hehe.
I gotta tell you i've hit tons of things w/ the old arms never bent anything these new arms ... bent the hinge pin AND cracked the chassis. Now granted i hit something pretty dam hard.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-15-2008, 08:01 PM   #7361
RussB's Avatar
damn.
that's the kind of crash that would take ANY car out of comission.
the only parts i break in a bad crash are castor blocks and/or steering knuckles. but that's cuz i've got about a billion graphite ones left over from my jrxs days so i just use those.
Old 06-15-2008, 08:49 PM   #7362
RedRocketRacing's Avatar
What is amazing is that the piece of the arm is still on the pin. WOW, did you get a number of the freight train that you ran into?
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 06-15-2008, 10:55 PM   #7363
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
wow thats crazy
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 06-16-2008, 02:27 AM   #7364
sportpak's Avatar
Trader Rating: 26 (100%+)
Mod kills.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 06-16-2008, 04:50 AM   #7365
nitrobeast's Avatar
To use the spool instead of the diff up front, is this all you need?
Team Losi 42T Spool Pulley & Plate: JRX-S (LOSA3329)
Rui Goncalves
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
