Old 06-10-2008, 08:08 AM   #7336
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by PDM View Post
I will check that. But I believe that is not the case.
No, it is not hard to tighten the spool every now and then, the problem is that if it needs tighten is because it is loose and it always get loose in the middle of a final
And a proper spool is so easy to do at the factory
Another question, I leave the thrust bearing in the spool, do you?
I like the slipper style spool (associated borrowed the idea for their tc5) i just don't know when it's too tight then i run the risk of stripping it. I guess i can just snug it or check it before the main.
I rebuilt my car w/ the 41 spool up front and 41 diff in the rear so i can use smaller pinions. I'll have to double check the rib on my 41 but i remember holding them side by side and they were the same size. I'll check again though doesn't hurt to be sure.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-10-2008, 08:23 AM   #7337
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Both Pullies are the same size. Check the way schreff said.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 06-10-2008, 12:16 PM   #7338
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
is anyone having a problem with the shocks leaking at the top?
I built the shocks with the bladders and it seams like the oil gets passed the bladders and leaks out at the top where the plastic and the meal meet.
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 06-10-2008, 12:21 PM   #7339
Yeti35's Avatar
You are the first one that has mentioned this. I have used these shocks on two of the first gen cars and I now have 3 Type R's and never seen this issue.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-10-2008, 12:33 PM   #7340
I have never seen that happen with the shocks. Its possible your tightening them too much. You dont have to hurt your hand tightening them.
Old 06-10-2008, 12:53 PM   #7341
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
Originally Posted by RussB View Post
are you running a short track or a long track? that gear ratio sounds crazy high at 6.71. i run a novak 10.5, standard size rotor, at 4.64 on a track with a long straight with a medium infield.
i was just running out in my employers parking lot. i had the same problem of the belt flipping with a 118/43 and a 13.5. just dont know whats causing my belt to "flip" on the rear diff.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 06-10-2008, 12:57 PM   #7342
well i guess i will have to see what i'm doing wrong
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 06-10-2008, 01:08 PM   #7343
RussB's Avatar
Send a message via MSN to RussB
PDM, regarding your spool problems... are you positive the spool is assembled just like a diff with the only exception being swapping the balls for the spool pads? It almost sounds like the thrust bearing may not be installed or greased or something.
also maybe try replacing the outdrive that the screw threads into.
RussB is offline   Reply With Quote
Old 06-10-2008, 01:13 PM   #7344
RussB's Avatar
metalracer, do you have the bladders in the correct way?
here's how i do my shocks... make sure the shaft is fully extended. fill with oil till the top is overflowing a little bit. let them sit for a bit for air bubbles to escape. set the bladder on the top of the oil. slowly compress the shock so that oil leaks out beneath the bladder. slowly extend the shock so the bladder sucks down to the shock body. assemble cap and tighten.
i've done them this way since losi changed shock designs. never had a leak or air bubbles.
Old 06-10-2008, 01:25 PM   #7345
thats what i was doing but i wasn't extending the shock to suck the bladder down. so i will try that and see if it works out THANKS.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 06-10-2008, 02:06 PM   #7346
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Hey Russ this is Dwight the Tamiya guy from this weekend. What is it about the Speed Passion ESC that you don't like. An anyone can chime in with there own experiences.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 06-10-2008, 03:03 PM   #7347
Send a message via AIM to UofAJoe
So I have been looking around for a better set up for carpet racing than the set up that comes in the box. Has anyone posted any of these? Is the set up that comes out of the box the best starting place for tight carpet tracks? The only reason i ask is because a friend of mine was helping me set up my car for the first time on his set up station and he was commenting on how soft my springs were, he's using some x-ray touring car. thanks a lot guys.
-Joey Hawkins
Systems Engineering
University of Arizona
UofAJoe is offline   Reply With Quote
Old 06-10-2008, 03:14 PM   #7348
Mike Haynes's Avatar
From the losi site grab the Schreffler vegas setup, most guys use some variation of that.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-10-2008, 03:29 PM   #7349
YmeBP's Avatar
www.petitrc.com slow but the best setup sheet site ever.
Old 06-10-2008, 10:11 PM   #7350
RussB's Avatar
i've never run the SP speedo or motor. all i've heard is second hand experiences that it's not as smooth as an LRP.
i currently run the novak speedo and it's a bit "abrupt" with the throttle response. i'm used to it.
for club racing, the best bet, like chassis, is to get something that's pretty common at your local track. that way you can get help or advice from others.
personally i prefer novak because of their support on here and that they have impeccible service. other brands that are imported can take longer for repairs.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
