Old 06-09-2008, 04:12 PM   #7321
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Thumbs up
I'm running a sp v1 but I had some issues with it on sat. A couple of times it would not bind up so I had no throttle and it also shut off once and then just come back to life? other then that the sp has been a great speedo....
I'm sure they fixed those problems on the v2 but for the price of just the sp speedo I can have a losi combo kit
also What ever you order be sure to get the long sensor wire or You'll be sol when you go to put it in
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 06-09-2008, 04:51 PM   #7322
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Did you take your issue to the SP Forum those guys seem to be on top of things with product support. I have been reading about the SP from that forum. Practically every question gets answered. And they even tell you to ship itback so they can fix it. Wish they would impliment the computer update option though
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 06-09-2008, 04:58 PM   #7323
no I'm just planing on replacing it. I'll put it back in the 2wd buggy. It always worked good in it
Old 06-10-2008, 05:00 AM   #7324
PDM
I have been driving the Type-R for some months now and I like the car very much.
I bought the type-R because of its design in the first place. I thought I would need to have that car only to be possible to look at it at home. I am an architect and the "architecture" of the Type-R impressed me very, very much.
Could not be the perfection but for sure it is easy to make it perfect.
At the beginning my car seemed always loose, the rear always wanted to go faster than the front. Today I have the ideia that beside the question of the weight balance in the car being 50% at front and 50% at rear if the rear is loose 90% of the chances that the front spool is loose.
I can not keep it tight for long. every 4 or 5 packs it needs to be tight.
Is it not time for Losi to make a real spool locked from factory?
PDM is offline   Reply With Quote
Old 06-10-2008, 06:16 AM   #7325
your kidding right, that means losi would actually have to give a shit about the car.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-10-2008, 06:19 AM   #7326
YmeBP's Avatar
Trader Rating: 32 (100%+)
You know i'm a little upset about this too, mine keeps loosening up as well. Not sure what the market is for this car but how hard could it be to put a lock nut in the dam diff half. I was thinking of just heating up a nut w/ a blow torch and sinking it into the plastic hahaha.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-10-2008, 06:46 AM   #7327
Xpress's Avatar
Really, I am not trying to stir anything up, but are you sure you have the spool properly assembled? I built my car with a spool and have run it about every week for 4 or 5 months without the spool backing off at all.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-10-2008, 07:09 AM   #7328
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I Imagine alot of you having loose problems running a spool are running overdrive.
Losi mislabeled a bunch of their 42 tooth spool pulleys. If you purchased a 42tooth spool pulley in the last 5 months its very possible you eneded up with a 41 tooth in a 42 tooth package. Everyone check thier spool pulleys and get back to me.
Is it really that hard to tighten the spool up every 4 runs? It takes about 1 second to stick a screwdriver in there and twist a 1/4 turn?
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 06-10-2008, 07:23 AM   #7329
schreff's Avatar
Send a message via AIM to schreff
Just a quick FYI for people to tell what pulley they have...
The 42T pulleys have a rib along the side of the pulley. The 41s have a flat side. You'll see it when you look. There's also mention of it in the manual.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 06-10-2008, 07:28 AM   #7330
PDM
I will check that. But I believe that is not the case.
No, it is not hard to tighten the spool every now and then, the problem is that if it needs tighten is because it is loose and it always get loose in the middle of a final
And a proper spool is so easy to do at the factory
Another question, I leave the thrust bearing in the spool, do you?
Old 06-10-2008, 07:32 AM   #7331
Yeti35's Avatar
Thrust bearing is in my spools also. The reason they made the spool the way they did was so damage can be limited on a hard hit. A true locked diff will have no give obviously where as the one Losi puts out will have give to it in a hard hit.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-10-2008, 07:33 AM   #7332
You could just snug the spool up right before the final. I usually check eveything out before my main to make sure its good to go.
I dont think a "proper" spool is necessary. A mulitdiff weighs about 15lbs and is 60 dollars. Making a losi spool costs like 6 bucks and weights less than the regular diff.
I do leave the thrust bearing in. A little jb weld in the outdrive will hold it if your that worried about tightening the spool every run.
Old 06-10-2008, 07:33 AM   #7333
Xpress's Avatar
I wish this was posted a couple of months ago. Now I know why I have constantly been fighting with corner entry push followed by the shuffle on corner exit. I've been running with a 41 spool pulley for months.
-Espo
Old 06-10-2008, 07:36 AM   #7334
Yeti35's Avatar
I had Larry inform me of that a few weeks ago. Fortunately that was not my issue since I had my pulleys since the car came out.
22 2.0
22T 2.0
Old 06-10-2008, 07:43 AM   #7335
Mike Haynes's Avatar
If the spool keeps loosening up it is likely that the outdrive has been stripped out from being overtightened. Mine came loose after i titghtened it too much, put a new outdrive on, and it has been fine since, this is with running a 41 pulley on an indoor high bite track.
You could always just glue the whole thing together with an epoxy or ca glue.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
