Old 06-05-2008, 04:39 PM   #7291
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by RedRocketRacing View Post
This has to do with all the questions about loose on power off the corner that alot of people were complaining about last week.
Just to let other know. I was able to run my car last night with the spool in it and found that the spool would not stay tight. And as a result the car spun out under breaking and off the corner on power. Really had to baby the car around the track. I finally said F*** it and went Kinwald on it, Replaced the spool with a locked down diff. Went from the middle of the pack in the main to lapping the field for the win. Made a huge diffenace. Just thought I would throw that out there for everybody to see if anyone else has fought this.
RedRocket
I'll have to rebuild mine before i take it out, does loctite work on the plastic diff half?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-06-2008, 08:40 AM   #7292
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i bought a used prs spur addapter and it came with 114 and a 116 spur
has anyone tryed using these spur with a 13.5, i was just wondering if i could get the right gearing to fit in the car with these spurs.
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 06-06-2008, 08:47 AM   #7293
Yeti35's Avatar
I am using I think the 116, but could not tell you at the moment what pinion since I am at work and car is at home. I know I am pretty close to the Novak recommended 4.5 FDR.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 06-06-2008, 09:07 AM   #7294
Trader Rating: 30 (100%+)
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 06-06-2008, 09:15 AM   #7295
Originally Posted by dfiantii View Post
Is it true that the thrust bearings from the Corally Phi or Xray T2 work better than the stock Type R thrust bearing?
Yes is true.
But the best and cheap thing you can do is build one by yourself.
Simply use the stok washer that come whit Type R but replace the 6 stok balls 1/16" whith 10 ceramic balls 1/16"
Ciao Ciao
Belty Dog is offline   Reply With Quote
Old 06-06-2008, 09:15 AM   #7296
John Tag's Avatar
Trader Rating: 42 (100%+)
Start with a 44x114 and go from there with rubber tires..I run 43-45X111 on most all tracks..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 06-06-2008, 09:55 AM   #7297
i forgot to say i will be using rubber tires.....
thanks for the info
also what would be the better spur to run? lets say i can get the right gearing with a 114 and a 116. just wondering what the difference would be.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 06-06-2008, 10:06 AM   #7298
John Tag's Avatar
No diffrence.....
Old 06-07-2008, 02:58 PM   #7299
racingboy14's Avatar
Trader Rating: 25 (96%+)
I need som ehelp figuring out what gearing to run. I am running ona a tight apsaslt track and I need more off the line speed. I am running a losi 118 tooth spur and the stock pullies and rubber tires, and a 27 turn stock motor. Any suggestions on a pinion\ spur combo? I need off the line speed badly.
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 06-07-2008, 03:25 PM   #7300
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Hey all,
since it is finally summer time (schools out, YAY!!!) , i had time to completely dissable my car and clean everything that gets ignored even after weekly routine maintenence.
What i found was astonishing,
After every run i check to see if my chassis is tweak free, i set my ride height, droop, check for excess play, etc, etc.
When recently i had my car in kit form (from near complete dissasembly) i checked to see if my chassis was strait, as it was spot on, and i did the same with the top deck,
here's the problem though,
After i got everything assembled, i check to see if my chassis was still perfectly flat, it wasn't.
i thought, no big deal, i'll just loosen the top deck and tighten it down when the chassis is perfectly flat,
it didn't work.
What i came to realise was that the standoffs (or chassis supports, as losi calls them) were bent, ALL OF THEM
I was pretty upset considering they are near to 20 bucks for two.
I do consider myself as a pretty good driver, and i can't remember the last time i broke something.
So is it just me? They are the same exact ones i got with the kit nearly a touch more than a year ago (though this isn't my first complete teardown of the car)
or are these things pretty frigile?
I can bend them easily with some pliers, it seems too easy in fact.
Has anybody ever had this problem? are there any stronger peices for the car?
Sorry for the rant, and thanks for your time.
-Kyle
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 06-07-2008, 04:51 PM   #7301
mojoman's Avatar
For 27 turn stock I always ran a 128 spur. Need a little more info for gearing though. Length of the straight and what stock motor.
Casey
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 06-07-2008, 05:39 PM   #7302
RedRocketRacing's Avatar
I have wondered why my car does not stay straight, I run rubber tires and have just removed the top screws from the standoffs so that I don't get the tweak. I did notice that they didn't line up real well with the top deck or the battery cover plate. I am going to check them next time I am at the track. I hate having a tweaked car that you cannot fiind why.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 06-07-2008, 06:27 PM   #7303
John Tag's Avatar
Most track..118X33 will do ya fine..Be sure to run a CO27 in stock..
Old 06-07-2008, 07:24 PM   #7304
thank you! One more thing, to get better of the line speed which way would I go on the pinion bigger or smaller? I can never remember.
Old 06-07-2008, 07:37 PM   #7305
Matt Howard's Avatar
smaller pinion=more torque and less top speed. larger pinion is less torque, higher topspeed
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
