Old 06-05-2008, 10:03 AM   #7276
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Not that I do not trust anyone because I do. I buy alot of things off of eBay and the rctech for sale forum. This kit though I would prefer to buy it brand new and not take on anyone else's problems and gives me a chance to build the kit the way I want to from the ground up rather than have things like sealing the chasis and what not done for me already. Takes a bit of time but you learn more about your car in my opinion.
dfiantii is offline   Reply With Quote
Old 06-05-2008, 10:08 AM   #7277
YmeBP's Avatar
Trader Rating: 32 (100%+)
You are 100% correct haha i didn't tear down one of my cars and just put it on the track one of my toe blocks had a broken/stuck locater pin and it bent in an impact taking out the whole right front of the car with it. Taught me to tear a car down and replace anything that was defective.
One of these days i'll treat myself to a new kit, but for now i can only afford to go used, good thing is losi parts are cheap and plentiful.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-05-2008, 10:13 AM   #7278
dfiantii's Avatar
I like that I have good parts support in my area. The closest track to me is about 20 to 30 minutes away but its an awesome track. Just been to damn busy to get out there and I missed my chance to go see that Reedy Race at the same track. There will be other big races there though I am sure. I just picked up a new charger (Hyperion I606) and my patience helped me get a brand new Transponder on RCTECH for 85. So the deal are there. I had one question if anyone cares to answer. Is the layshaft from the JRXS interchangable with the Type r's and which is better to use? The stock layshaft or the thicker one from the original JRXS.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
Old 06-05-2008, 10:51 AM   #7279
Yeti35's Avatar
I swapped out the stock lay shafts for the one from the old car. It is a direct fit.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 06-05-2008, 11:15 AM   #7280
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by YmeBP View Post
Hey i just saw the post for the tc5 "slipper spool" looks like the one for the type r, wonder if their disks will fit?
http://www.redrc.net/2008/06/team-as...ormance-parts/
Might be a tuning aid?
If you don't tighten the snot out of losi one it will serve the same purpose.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-05-2008, 11:52 AM   #7281
YmeBP's Avatar
I've read that people w/ high winds (5.5 and lower) have issues w/ bending the stock type-r layshaft and stripping gears and they use the older car's layshaft to avoid that issue.
Old 06-05-2008, 12:30 PM   #7282
dfiantii's Avatar
Does anyone know where i can find a build forum for this car.
TLR 22 2.0
Old 06-05-2008, 12:35 PM   #7283
Yeti35's Avatar
I have stripped gears just running stock motors and it was mostly when running a oneway. I think from hitting a board while on throttle forcing the drivetrain to try to run backwards hense stripping the gear.
22 2.0
22T 2.0
Old 06-05-2008, 12:35 PM   #7284
Yeti35's Avatar
??? Any info you may need while building your Type R you can get from the people here.
22 2.0
22T 2.0
Old 06-05-2008, 12:51 PM   #7285
dfiantii's Avatar
Thank you for the Yeti. I knew i could ask questions during my build I was just wondering if there was one. It use to have one on rcuniverse but it disappeared.
TLR 22 2.0
Old 06-05-2008, 02:13 PM   #7286
RedRocketRacing's Avatar
This has to do with all the questions about loose on power off the corner that alot of people were complaining about last week.
Just to let other know. I was able to run my car last night with the spool in it and found that the spool would not stay tight. And as a result the car spun out under breaking and off the corner on power. Really had to baby the car around the track. I finally said F*** it and went Kinwald on it, Replaced the spool with a locked down diff. Went from the middle of the pack in the main to lapping the field for the win. Made a huge diffenace. Just thought I would throw that out there for everybody to see if anyone else has fought this.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 06-05-2008, 02:46 PM   #7287
Yeti35's Avatar
I have been running a spool in this car ever since I got it with no issue at all. Is it possible you have the outdrive stripped that it does not stay tight?
22 2.0
22T 2.0
Old 06-05-2008, 03:06 PM   #7288
Don't know, I am gonna get all new parts and build a new one and give it another shot. When I put the diff in I locked it down pretty tight, it acted just like the spool did. Not quite as quick but the steering off the corner was actually a little bit better.
RedRocket
NWIC 2008/09
Old 06-05-2008, 03:26 PM   #7289
crunchracer's Avatar
Thumbs up
I was running mine as well last night with RedRocket, but with a 6.5 mod. I found my spool did lossen up slightly like he did, but no where bad as his did.
Although we are running slightly diff setups, both cars are frigging FAST.
And just think I traded my Tamiya Mini M03R for my TypeR
www.FusionMotorsports.com
Team S.I.R
John's BSR Racing Tires
crunchracer is offline   Reply With Quote
Old 06-05-2008, 04:38 PM   #7290
MaxRain's Avatar
Default diff hub tip
For those who have wondered how to keep the diff hub tight, I did this.
Go to your local hardward store and pickup 4-40 machine screw nuts. Grind the ends enough in a circular pattern, insert into the diff hub and tighten.. Problem of loose hubs gone.. I was thinking of buying new hubs, but did this instead and my diffs don't get loose any more.
Gordon
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
