Old 05-27-2008, 12:51 PM   #7216
Matt Howard's Avatar
Originally Posted by STLNLST View Post
No...he's has one win and I have one win.
Nah, like I told you before, if I wasn't there your win doesn't count.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-27-2008, 02:51 PM   #7217
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
what is the rear end ratio of the trpye r with the 42t and the 41t pully?
i thought i read that it was 1.83 with the 42t pully but i'm not sure.
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 05-27-2008, 02:57 PM   #7218
RedRocketRacing's Avatar
Yes it is 1.83 42 tooth diff pulley and a 23 tooth layshaft pulley 42/23. If you go wiht 41 diff pulley than it is 41/23.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 05-27-2008, 03:23 PM   #7219
has anyone used a 17.5 in this car and what spur and pinion did you use? for rubber
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
Old 05-27-2008, 03:27 PM   #7220
Mike Haynes's Avatar
Do you mean for rubber? If so i run a 118 and 50 to 53 to start and go from there. You can mesh up to a 55 with a 118 without any dremeling to the motor mount.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-27-2008, 08:27 PM   #7221
STLNLST's Avatar
Trader Rating: 19 (100%+)
then niether does his
STLNLST is offline   Reply With Quote
Old 05-28-2008, 12:59 PM   #7222
Hi guys need some help i am having a brain fart today (no change there)
trying to set my car up to a very low bite track for this week as the last few weeks i have had NO rear grip atall so i am relocating some electrics from the front and center mounting them to see if i get any benafits so first i was wondering has anyone had any luck with mounting brushless down the center fo the chassis will this provide more rear grip ?
also when setting up the droop to a setup sheet how to you measure 3mm above ride high i am a little confused with this
thanks for any help
Losi JRXS Type R
Speed Passion
EP4600
B-Master is offline   Reply With Quote
Old 05-28-2008, 02:42 PM   #7223
thanks for any help
I run mine with 13.5 Brushless with receiver and speedo mounted on top down the center. I like it and it seems to have no ill effects on handling. I have the speedo mounted pretty much dead center of the car with the receiver mounted forward.
azrael_nite is offline   Reply With Quote
Old 05-28-2008, 03:02 PM   #7224
thanks bud i may just try center mounting it
anyone got any advice on measuring the ride hight its really confusing getting the 2mm above ride hight
Losi JRXS Type R
Speed Passion
EP4600
Old 05-28-2008, 03:45 PM   #7225
Yeti35's Avatar
Not confusing at all. To use your 2mm above ride height senario, you would have your ride height at say 5mm, droop would be 2 mm above that. What this means after you set ride height you put your gauge under the car and sit it on 7mm then adjust droop by raising the arm with the droop screw until you see daylight, then lower until you get tire contact. This is the way it was explained to me and also how I do it. If I am wrong I hope someone steps in to correct this.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 05-28-2008, 05:40 PM   #7226
that makes perfect sense thanks for the reply the drop on the setup sheets has always confused me i think i get it now
Losi JRXS Type R
Speed Passion
EP4600
Old 05-29-2008, 06:11 AM   #7227
YmeBP's Avatar
Trader Rating: 32 (100%+)
That is the way i was taught too
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-29-2008, 06:19 AM   #7228
Yeti35's Avatar
The other thing is if it does not say like 2mm above ride height and just says 2mm, you would need an actual droop gauge to set it then. The method above was arrived at so you do not have to remove the wheels everytime to set droop.
22 2.0
22T 2.0
Old 05-29-2008, 07:11 AM   #7229
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
I got my spur gear adaptor from Mike.
I will like to know what spur are you using? Xray, associated????. thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 05-29-2008, 07:55 AM   #7230
Yeti35's Avatar
Yes, you can use Xray, PRS and Kimbrough as far as I know. I use PRS and Xray myself.
22 2.0
22T 2.0
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
