Old 05-21-2008, 12:08 AM   #7186
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
The LCDs are one of my favorite features of the car.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-21-2008, 03:35 PM   #7187
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Hey Larry,
Any news on any new update to the car being worked on?
yyhayyim is offline   Reply With Quote
Old 05-21-2008, 06:10 PM   #7188
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Cough Cough.. Hi
OUT
Keith Billanti is offline   Reply With Quote
Old 05-21-2008, 06:52 PM   #7189
Trader Rating: 65 (100%+)
Send a message via AIM to joey
heres a pic of my car with a bl setup on it and SMC lipo
=Joe Wright=
joey is offline   Reply With Quote
Old 05-21-2008, 07:18 PM   #7190
Yeti35's Avatar
Originally Posted by Keith Billanti View Post
Cough Cough.. Hi
Where did you come from?
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 05-21-2008, 07:52 PM   #7191
jla8874's Avatar
joey, that looks sharp! what springs are you using, and how long of a sensor harness did it take to do that? also, take a pic of the other side if you dont mind. im thinking of turning all of my solder posts the other way around and going with that layout.
jla8874 is offline   Reply With Quote
Old 05-21-2008, 08:03 PM   #7192
those are yellow tamiya springs, there not gonna work with the setup i have on the car, i just put them on to take a pic of the wiring i have on it..
ill try to get another pic tomorrow when i get a chance, and for wiring harness thats the longest one orion makes..
=Joe Wright=
Old 05-22-2008, 02:02 PM   #7193
Iv been around. I look in from time to time... Might have to grab that new exceleron system and try out these new fangled batteries.... looks like a hoot..
OUT
Old 05-22-2008, 02:31 PM   #7194
tim fry's Avatar
Originally Posted by B-Master View Post
I am unsure if this will help anyone but when i treated my self to a brushless setup this week i found it extremly hard to work out where to put everything after lets of messing about and testing diffrent layouts i think i have found one that works
can anyone pick any faults in this layout as i dont want my speedo to get damaged on any impact .. thanks
PS. i woudl liek to thank jal874 for his help via PM regarding how best to layout the speed passion brushless
First off i needed to change the way the battery bars were positioned on my batterys these angles fit very well the - is just behind the sput and the + just behind the reciver
Top view
side view
hopefully this will help some people out with how best to layout there brushless ?
*Edit*
maximebeauvais there are some great setups on this site hope it helps
http://team-spoon.bravehost.com/#tl
This post was very helpfull thank you.
Best wiring layout I've seen
tim fry is offline   Reply With Quote
Old 05-22-2008, 06:04 PM   #7195
Trader Rating: 25 (100%+)
I tried to mount the speedo on both sides of the chassis. I also tried mounting it on the side and flat. The car wieghts 5247. No matter what side you mount the speedo on, that side is going to be the heavy one. The weight difference does not effect the car handling. I can not justify adding the weight for balance.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 05-23-2008, 06:22 AM   #7196
@ tim fry i am glad the pics helped you out and thanks for the complament
Losi JRXS Type R
Speed Passion
EP4600
B-Master is offline   Reply With Quote
Old 05-23-2008, 06:28 AM   #7197
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
Since I got my car, I was running a diff and the car was great (track around 90X45, carpet and rubber tire, 13.5 BL motor and lipo)
Last night I installed a one-way (dam losi and one-way, took me more then 1 hour to install).
OMG!!! Same setup but with a one-way and ouch, the car was going everywhere. Very hard to control, the rear was going left and right…etc.
Question 1: is it harder to run with a one-way? I guess yes
Question 2: is it really faster to drive with a one-way (our track/rubber tire). After 2 batt, I was just not able to drive it (setting maybe) and I was still faster with a diff then oneway (9.7 sec diff VS 9.9 sec with oneway)
I have copied around 6-7 setup sheet but it all pretty different and only 1 was running a oneway. Someone else have a setup sheet with carpet/13.5/rubber/oneay??
thanks
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 05-23-2008, 06:45 AM   #7198
Matt Howard's Avatar
one-ways require a very smooth throttle finger getting both on and off power. It takes some getting used to but either a oneway or spool is usually faster with rubber tires on any surface. If you can't get the hang of the oneway, get a spool pulley and build up a spool for the front. If you're used to running the diff in front, the spool should suit your driving style better.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-23-2008, 08:22 AM   #7199
jla8874's Avatar
For anyone who is off put by the gold of the Trakpower 4900, Team Checkpoint now sells the same lipo. These are 25C whereas the 5400 is only 16C.
Old 05-23-2008, 06:28 PM   #7200
jla8874's Avatar
I thought I would give a quick little review of Lipo Lead. Bottom line, I think it works. I'm not really experienced enough to notice minute changes on the car, but I could definitely tell the car felt more planted after I put this on. The car was way less skwerly and way more predictable. It felt like it reacted a tad bit slower due to the added weight I'm sure. Guys at my track run Schuies and Xrays with lipos and only about an ounce to an ounce and a half of weight, but I dont think the Losi was meant to drive that light like I was trying to do.
If you want to buy some the #2 is the only one that will fit. The #4 is too thick. You have to remove the battery foam and its a perfect fit. Also, Team Fusion gives you more than what you pay for. They throw in some end cuts of other thicknesses. I went Fry's and got some 1 1/2" black shrink so it would hide the lead(still need to shrink it).
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
