Old 05-14-2008, 08:02 AM   #7051
YmeBP's Avatar
Trader Rating: 32 (100%+)
Default smc lipos and the type-r
Has anyone tried the smc 28c 5000 lipo's in the type-r? Do they fit w/ the wires the way they are, or do i have to modify the case?
Along the same lines, has anyone tried the checkpoint/trackpower lipo's in the type-r?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-14-2008, 08:12 AM   #7052
Mike Haynes's Avatar
The smc 5k is a very tight fit, you need to do some dremeling to the case near the rear bulkheads, or shave them....the 4k fit a lot easier.
I have seen trackpower used with just a very slight dremeling on the top deck where the plugs go in.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-14-2008, 08:13 AM   #7053
crunchracer's Avatar
Cool need help finding Spur Gear Adapter
Can anyone point to a source for the Spur Gear adpters for the JRXS R ?
www.FusionMotorsports.com
Team S.I.R
John's BSR Racing Tires
crunchracer is offline   Reply With Quote
Old 05-14-2008, 08:40 AM   #7054
How weird is that i was just about to ask the same question
B-Master is offline   Reply With Quote
Old 05-14-2008, 08:44 AM   #7055
YmeBP's Avatar
Thanks for the quick reply, trying to figure out which to go with. I like the idea of the checkpoint ones a little better as all i have to do is put some bullet connectors on my speedo and i'm good. The smc i think would involve a little more work, but they do have a higher c rating than the checkpoints. I'll see if i can borrow someone's checkpoint battery this weekend to see how they look.
Old 05-14-2008, 09:49 AM   #7056
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Dont bother using the SMC 5000 packs on the Type R...the SMC4000 will fit much better, but the problem will be the wires. You have to put the pack in facing down, and the wires coming out on the right side of the chassis.
The TrakPower 4900 25C packs are a much better fit and have better power than SMC 4000 packs.
yyhayyim is offline   Reply With Quote
Old 05-14-2008, 09:50 AM   #7057
yyhayyim's Avatar
Cool
http://www.precisionracingsystems.com/products/17
Old 05-14-2008, 10:27 AM   #7058
YmeBP's Avatar
would you suggest the trakpower's higher c rating over the checkpoint's higher mah rating seeing as they have the same basic form factor (and apparently the same cells).
Old 05-14-2008, 12:18 PM   #7059
jla8874's Avatar
Trader Rating: 23 (100%+)
PRS no longer makes the adapter. Go back 5 pages or so and I posted a link to an Asian retailer that had the spur gear adapter/spur gear combo still for sale. Red might have been the only color they had left. Use Google to translate. Theyre pretty much extinct at this point, so good luck finding one!
jla8874 is offline   Reply With Quote
Old 05-14-2008, 12:22 PM   #7060
yyhayyim's Avatar
Trakpower 4900mah 25C pack packs all the punch and power you need for 13.5 and 10.5, and really rips with MOD. It unloads 122amps, while the SMC4000 28c pack unloads 112amps. Trakpower 4900mah pack for the Losi Type R is a better choice power wise, plus its much more practical and cleaner set up, plus more run time.
The checkpoint 5400mah 20C can output 108amps, which is less than the SMC4000 and trakpower 4900 packs, which means in mod they will have a bit more punch and acceleration and get to top speed a bit quicker, assuming you're using the same motor...the rip and power of the trackpower is amazing...the trackpower will be a bit milder in accelerating and rip...but with the Checkpoint you get a bit better run time than with trackpower, and much better than SMC4000 pack, but that's about it.
For the price: the Trackpower is the better deal over all it seems like.
Old 05-14-2008, 12:24 PM   #7061
yyhayyim's Avatar
that really sucks...Why doesnt Losi make their won adapter, or make smaller Spur gears: 108,110,112, 116?
Old 05-14-2008, 12:28 PM   #7062
YmeBP's Avatar
Thanks for the insight, i'll go hunt down one of these trackpower packs.
Old 05-14-2008, 12:28 PM   #7063
jla8874's Avatar
+1 for the Trakpower 4900. You will have to enlarge the access holes slightly since they're closer together than a Platinum, and remove about 3/4" of shrink off the very back and you're good to go. About the Checkpoint/Trakpower 5400 though, wasn't it determined that they used cheaper Enerland cells in those and they were only 16C, not 20C? Thats why they offered anyone who bought one of those a 4900 at half price.
Old 05-14-2008, 12:29 PM   #7064
YmeBP's Avatar
A little off topic, but you have the best avatar i think i've seen in a really long time, even my wife did a doubletake .
Old 05-14-2008, 12:39 PM   #7065
jla8874's Avatar
Tell me about it. I find myself staring at it everyday!
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
