Old 05-10-2008, 12:47 PM   #7036
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by tim fry View Post
Hi all
Has anyone got a decent picture of a GTB fitted to give me an idea of location and wiring.
Old 05-11-2008, 08:22 AM   #7037
mojoman's Avatar
Originally Posted by egalsim View Post
Low bite asphalt with rubber and 200mm body. Thanks for the reply
If you use the kit setup with some minor adjustments on the springs you should be okay. I use a spool up front on low bite tracks (not a bunch of steering) the car seems to be planted more so than with a one way. Make sure your car rolls. A couple of things I changed from the kit setup is droop, I'm running 4mm over ride height in USVTA, I also changed the ride height to 5mm in the front and 5.5 in the rear. Setup the car so it rolls with your droop adjustments, spring weights and ride height.
Good Luck,
Casey
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 05-11-2008, 04:12 PM   #7038
jla8874's Avatar
Trader Rating: 23 (100%+)
Can someone please give me a tip on how to keep the screws on the bottom of the c-hubs from falling out? On my other car they're aluminum so I use Loctite, but it says in bold letters on the back do not use on plastic. Also, I cant find those shims or washers on the bottom of the c-hubs listed from Losi, do they sell them? I have been using those plastic spacers that come with the a-arms in their place. Thanks.
jla8874 is offline   Reply With Quote
Old 05-12-2008, 06:02 AM   #7039
todd8603's Avatar
Default Tamiya locktite
Tamiya threadlock is meant for plastic use
todd8603 is offline   Reply With Quote
Old 05-12-2008, 08:08 AM   #7040
MikeXray's Avatar
Trader Rating: 72 (100%+)
LOSA1233
If you're not using the right shim I'm sure this is causing the screw to loosen. They will tend to work out a little, but if its happening often with the right shims, then you need new knuckles.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-12-2008, 08:40 AM   #7041
Hi i was wondering if anyone could advise me on gearing i have just bought a speed passion GT and i am running 64dp gearing on my car i am racing on a low traction aspult track running CS27 track is twisty with some nice strights.
i was just wondering what gearing setup would you start off with IE. 32P/128S
Many thanks
B-Master is offline   Reply With Quote
Old 05-12-2008, 08:54 AM   #7042
Mike Haynes's Avatar
What kind of motor...turn?
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-12-2008, 10:24 AM   #7043
jla8874's Avatar
Tamiya threadlock is what I'll try then. I was using those a-arm spacers on both sides, I just cant seem to get the right amount of tension on the screws. Too tight, they bind up the steering, too loose and they fall out.
Old 05-12-2008, 11:21 AM   #7044
MikeXray's Avatar
that's because they don't have a shoulder for the knuckle to ride on, you need the right bushings.
Old 05-12-2008, 11:50 AM   #7045
Yeti35's Avatar
Do you have these in the C hub? http://www.losipartshouse.com/servle...X-dsh-S/Detail referring to the black collars in the picture with the screws and ballstuds. It these are missing then that is part of your problem.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 05-12-2008, 12:47 PM   #7046
YmeBP's Avatar
Trader Rating: 32 (100%+)
I have the same problem the previous poster has, i try to stay on top of the c-hub screws and i use a drop of ca in the c-hub threads (i mean just like a tiny drop w/ one of those little pipette things) to keep things in place.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-12-2008, 12:54 PM   #7047
Many thanks
sorry i should have said i am running a 13.5t motor
Old 05-12-2008, 04:47 PM   #7048
RevXS's Avatar
Originally Posted by Spillertwo
Does anybody here know if Kimbrough spur gears fit on the JRXS cars ?
Only if you buy a PRS spur gear adaptor, otherwise only Losi spurs will fit.
Does anyone know what other brand spurs will fit on the PRS spur adaptor,IE Kawada etc....Emailed the company and they wernt 100% sure what would fit on it
RevXS is offline   Reply With Quote
Old 05-12-2008, 05:13 PM   #7049
B-master i would start around 118/43 which is 5.0 or a 39ish mm rollout...gear up from there to get more top end if you can without running the motor too hot.
Rev xs i have seen people use kimbourgh, prs, xray, or rw gears with no issues...you just have to make sure you use a short screw so it doesn't put pressure on the lay shaft and bind the drive line up.
Old 05-12-2008, 09:14 PM   #7050
jla8874's Avatar
4-40 x 1/4" aluminum buttonhead screws is what PRS puts in them. Any longer and the spur will start to push away from the adapter because the screws are hitting the pulley and putting force on the spur.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
