Old 05-08-2008, 09:33 PM   #7021
vabroom's Avatar
Don't have the sway bars in front of me, but I think they use 5-40.
vabroom is offline   Reply With Quote
Old 05-09-2008, 04:09 AM   #7022
jla8874's Avatar
Trader Rating: 23 (100%+)
5-40? Thats the same size set screws in my PRS pinions, I dont think they are that small. I could be wrong though.
jla8874 is offline   Reply With Quote
Old 05-09-2008, 05:41 AM   #7023
MikeXray's Avatar
Trader Rating: 73 (100%+)
they are smaller than a pinion grub screw, they are the same thread as the droop screws.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-09-2008, 05:45 AM   #7024
Mike Haynes's Avatar
Can someone please tell me what size set screws are in the swaybars? I have what I thought were some 4-40's, but they dont fit.
4-40
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-09-2008, 08:56 AM   #7025
jla8874's Avatar
Can someone please explain to me how the standard and offset rear hubs measure as far as setups. Like on Mike Hayness' Birds setup he said he used 3 degree rear toe with a 2 degree rear pivot and a standard hub. Doesnt the 2 degree rear pivot and the one degree built in equal to three? So what does the standard hub equal to? And the offset, what do they equal? Why would you use the stardard and offset instead of just 1/2, 0, 1,2?
Thank you!!!!!!!!!!!!!!!!
Old 05-09-2008, 09:04 PM   #7026
egalsim's Avatar
Trader Rating: 39 (100%+)
Anybody have a setup sheet for the Vintage Class?
egalsim is offline   Reply With Quote
Old 05-09-2008, 10:01 PM   #7027
mojoman's Avatar
Carpet or asphalt? High or low bite? Need some more info.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 05-09-2008, 10:05 PM   #7028
There is 1 degree of toe built into the chassis, so a 0 hub and 2 pivot will yield 3 degrees of toe.
Offset hubs make for a shorter rear arm, we really don't use this on the type r much.
Old 05-09-2008, 11:17 PM   #7029
egalsim's Avatar
Low bite asphalt with rubber and 200mm body. Thanks for the reply
Old 05-10-2008, 03:44 AM   #7030
jla8874's Avatar
I understand that part of it Mike. I guess I asked the question wrong. What I was getting at was, so in that setup of yours I described above, the only thing that can be surmised is that the standard hub equals 0 degree. So is the standard hub 0 degree, and if so, whats the difference between standard hub and a 0 degree hub? So you would have three degrees of rear toe either way with a standard or 0 degree hub and two degree rear pivot? Am I making sense or not?
Old 05-10-2008, 03:46 AM   #7031
Low bite asphalt with rubber setup http://www.petitrc.com/reglages/losi...on20070724.pdf
More medium bite asphalt with rubber setup http://www.petitrc.com/view_news.php?id=4620
Arn0 is offline   Reply With Quote
Old 05-10-2008, 06:07 AM   #7032
The standard rear hub is 0 degrees, its just a matter of what we call them.
Old 05-10-2008, 06:35 AM   #7033
jla8874's Avatar
Okay, thanks. That was just confusing me on the setup sheets why they had STD and 0 degree listed if they were the same.
Old 05-10-2008, 07:26 AM   #7034
egalsim's Avatar
Thanks Arn0!
Old 05-10-2008, 11:44 AM   #7035
tim fry's Avatar
Hi all
Has anyone got a decent picture of a GTB fitted to give me an idea of location and wiring.
tim fry is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
