Old 04-21-2008, 10:11 PM   #6976
mojoman's Avatar
Originally Posted by jla8874 View Post
Can someone please help me out with gearing selection? I am running a gt 1.1 with a SP 17.5 when they come out. I already have pinions 47-56, but what size spurs will I need? If one could give me a range of about 5-8 spurs I will need so I can buy them I would appreciate it!
I run a 104/53 with the prs adapter and no problem with the mesh. I could probably go down to a 100 but haven't tried.
Originally Posted by KyLayfield View Post
No problem, .
You coming to Frederick this year?
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 04-22-2008, 05:18 AM   #6977
jla8874's Avatar
Trader Rating: 23 (100%+)
I forgot to mention I already have a PRS adapter and 100 and 108 spur, along with some bigger Losi's. I was just assuming a 17.5 would need rather large pinions when I bought mine. So, do you think I will need smaller than a 100t spur, or larger than a 56t pinion? I have looked, but there doesnt seem to be lot of 17.5 info out there yet.
jla8874 is offline   Reply With Quote
Old 04-22-2008, 05:55 AM   #6978
Mike Haynes's Avatar
I have been using a 108 spur for 17.5, you can mesh a 60 or slightly more, but there is usually no need for that much pinion....i have found 51 to 54 is plenty, depending on tire size.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-22-2008, 06:04 AM   #6979
jla8874's Avatar
Thanks Mike! Thats what I needed to know.
Old 04-23-2008, 03:59 PM   #6980
tim fry's Avatar
I'm sure this has been asked before but what does everyone do to get their car up to weight with a Lipo?
I have some trackpower 4900 batts and all ready to I'm 200g light!!
I have one of the metal lipo trays but its too thick and I dont want to grind the bulk head near the centre shaft.
Any ideas guys?
tim fry is offline   Reply With Quote
Old 04-23-2008, 05:57 PM   #6981
jla8874's Avatar
Do you have a Losi lipo tray or one of those steel plates? I have the Losi tray and a Trakpower 4900 and it fits fine. You just have to remove about 3/4" of the shrinkwrap in the back to clear the bulkhead and the pulleys.
Old 04-23-2008, 09:17 PM   #6982
iixliltonyx33's Avatar
Send a message via AIM to iixliltonyx33
maybe dremel the battery casing a little
Tony
Team Driver for TNT Racing and Scuba Steve Graphixs
360 rc speedway and hobbies, Willis Hobbies
iixliltonyx33 is offline   Reply With Quote
Old 04-24-2008, 02:03 PM   #6983
tim fry's Avatar
I did think about that but my club doesnt allow modification of lipos.
I suppose I could just add weight to the chassis it just seems a shame to mess up all the balance that the R has.
Old 04-24-2008, 04:16 PM   #6984
jla8874's Avatar
What about Lipo Lead? Im gonna get a #2 which is 2.2oz and just lay on top of my lipo. I heard you need to add weight to the top of lipos anyway on the Type R to help your roll center.
Old 04-25-2008, 01:25 PM   #6985
tim fry's Avatar
That looks ideal
Old 04-25-2008, 05:59 PM   #6986
jla8874's Avatar
Has anyone ever used short neck ball studs on the servo and steering linkage to level it out and keep it from wiping on the top chassis plate? And if so which ball studs did you use? The only Losi ones I see are these Ti ones.
Old 04-25-2008, 06:25 PM   #6987
Matt Howard's Avatar
yup, I used the losi short neck Ti ones to do it
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-26-2008, 04:01 AM   #6988
jla8874's Avatar
Thank you sir! Thats what Im going to do then.
Old 04-28-2008, 11:28 AM   #6989
Default Motor Fans for Brushless?
Just wondering how many of you out there run this car with the optional motor fans? Do you run them with brushless motors? If so... can you tell a difference? Can you actually push the motor more? Gear it higher?
What Fans work?
Thanks,
azrael_nite is offline   Reply With Quote
Old 04-28-2008, 03:11 PM   #6990
jla8874's Avatar
I bought these fans from Associated and they work really well. Dual 20mm's pre-wired so you just have to plug them in to your receiver. If you wanted to you could buy that fan kit and add a third, seems like overkill to me though. You can put dual 25mm's on the top if you choose, but you would have to wire them your self. Someone else might be able to speak as to how much performance you gain with them?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
