Old 04-13-2008, 03:16 PM   #6946
Chris,
I think your analysis is correct. Make sure to lube each ball thoroughly and set your diff so as not to slip. That should eliminate the problem.
Frank Connolly
Thugs Bunny is offline   Reply With Quote
Old 04-14-2008, 03:06 PM   #6947
jla8874's Avatar
Trader Rating: 23 (100%+)
Does anyone know a part number of some shims for the hinge pins? I'm trying to shim out some play in the arms and I cant find the right size. The hinge pins are 1/8", but I'm not finding shims that size. Thanks.
jla8874 is offline   Reply With Quote
Old 04-14-2008, 03:08 PM   #6948
Yeti35's Avatar
You mean these? http://www.losipartshouse.com/servle...n-CR%2C/Detail
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 04-14-2008, 03:10 PM   #6949
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Use motor shims
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 04-14-2008, 04:07 PM   #6950
JKA
Thugs - I have my leads from my SMC 4000 coming out of the right side of the car (away from the belts). The label of the battery is facing down, and it works fine.
JLA8874 - Like Fairtrace I also use motor shims. Works great.
I have a question? I'm running the JR links up front on carpet with foams. I'm using them because i can't get a regular link to work to save my life. At the finale at the gate I tried Schreff's setup and couldn't drive it to save my life. The front end was much to twitchy and I was traction rolling. I made a couple adjustments to limit camber gain and though it helped some the only way I could calm the front down enough to drive consistent laps was to go back to the JR links. What gives? I know I drive like a jackass most of the time, but I can build and setup a car and I copied Schreff's setup to a "T". Is that setup just REALLY aggressive? I even had the expo down like you guys stated... -20.
I wouldn't normally worry about it but I don't think my setup is a good setup as the front and rear way different and I think that though its easier to drive its not efficient and doesn't carry as much corner speed as it should.
JKA is offline   Reply With Quote
Old 04-14-2008, 05:21 PM   #6951
schreff's Avatar
Send a message via AIM to schreff
I would say yes, it is aggressive. I like a car that responds to instant wheel movement. At Vegas and the Birds... I too had a little trouble with tipping a little. It wasn't traction rolling, but rather picking rear wheels up. I only made 2 adjustments to fix that.
#1. Glue the edge of the front tire. I don't normally do the whole edge, but just the seem so the tire doesn't rip from side force. I do glue the whole edge if my tipping issue is a big problem. I do NOT glue the rears at all.
#2. Very simple... less front tire traction compound. At the Birds, I used a little less than half on the front tire. If I used more, it would be way too hard to drive. I used traction as a majority of my adjustment. It helped a ton using less. The car does still turn with less.
I know those are 2 very basic things, but simple is always best. You can see from my setup from Vegas and the Birds, there isn't a big difference. They were both Jack the Gripper races with similar style layouts. The Vegas setup was a little easier to drive, but steered less. At SnowBirds, we found more speed, but you had to be on the wheel.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 04-14-2008, 05:55 PM   #6952
Trader Rating: 193 (99%+)
Schreffs setup worked great for me at the Carpet Nationals. The only change I made was added camber gain upfront. The car was dialed. I did glue the front of the tires myself. And like Schreff I only used about 1/4 of traction on the front tire.
Schreff are you running at the Paved Nat's? And will you be making the trip to Jonesboro the following weekend? Hope to meet you sometime.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-14-2008, 07:49 PM   #6953
subaru73's Avatar
Trader Rating: 41 (100%+)
Default JRXS-R
Has any one tried to solder their batterys on the right side instead of the left side?I was looking at my car tonight and it looks like it might work.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 04-14-2008, 08:29 PM   #6954
mojoman's Avatar
I ran Schreffler's setup at the birds and changed a few things. Instead of magentas up front I used cyans, instead of one degree of toe in the rear three degrees calmed it way down, and I increased the amount of droop about .75mm. The car was glued but wasn't as twitchy as when I first set it down with the original setup.
Casey
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 04-14-2008, 09:34 PM   #6955
JKA
Thanks man!
Old 04-15-2008, 04:58 AM   #6956
jla8874's Avatar
I have those Yeti, I need the much thinner steel ones to make finer adjustments. I have a bag of the Losi ones, but the smallest in there is like 3/16". Guess I'll look for some motor shims. Thanks.
On a side note, has anyone seen these new carbon fiber INFUSED arms? I can see these catching on and becoming popular with other brands, especially if they're actually functional.
Old 04-20-2008, 03:53 PM   #6957
tim fry's Avatar
Hey guys I need a bit more rear end grip on corner exit. I'm running the Ripon setup for rubber and its nearly there just a little tail happy on exit. Any ideas?
tim fry is offline   Reply With Quote
Old 04-20-2008, 05:19 PM   #6958
Mike Haynes's Avatar
Hey Tim i'd try going to one softer spring or possibly take out some dual rate if you can afford it.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-20-2008, 08:37 PM   #6959
RussB's Avatar
Send a message via MSN to RussB
FYI - for anyone who prefers CVD's to the other style drive shafts, you can use the JRX-S or XXX-S stub axles with cyclone or TC3 shafts. i'm currently using the composite TC3 shafts and they work great. no binding, no rubbing.
RussB is offline   Reply With Quote
Old 04-20-2008, 08:39 PM   #6960
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Hey Russ were you out at speedworld on saturday?
dfiantii is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
