Old 03-21-2008, 09:54 AM   #6811
Xpress's Avatar
Matt,
Were you running a production speedo? Your thoughts on it? When you have time can you share a setup sheet?
Thanks,
Brian
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-21-2008, 10:07 AM   #6812
Matt Howard's Avatar
I am running a pre-production losi sensored esc but I just updated the firmware to the production specs this morning so for all intensive purposes, I now have a production one. It's going to come with both a setting card and a USB cable with software to make more adjustments via a PC. It feels so much more linear than any other brushless esc I've run so far, you guys will love it.
Here's my setup from the nats.
front
20lb spring, 57 pistons, 45 wt oil, middle hole on tower
.05 sway bar
high roll center blocks
regular castor link, used inside upper hole on shock tower and short ballend on castor block
arms spaced in the middle
4 deg castor
inside hole used on the steering link (makes the steering turnbuckles longer)
5 1/2 mm ride height, 1.5mm droop
rear
12.5lb spring, 55 piston, 35 wt oil, middle hole on tower
arms spaced to the rear
3 deg toe in
low roll center blocks
inside hole on hub for camber link, inside middle on tower
5 1/2mm ride height, 2mm droop
PF Mazda 6 used
If I forgot anything just let me know
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-21-2008, 10:18 AM   #6813
Xpress's Avatar
When running LiPO's have you tried running the car light and compared it to running the car legal weight? I have been having trouble keeping the front faster than the rear and am starting to think it has to do with my car being so light.
-Espo
Old 03-21-2008, 10:52 AM   #6814
Trader Rating: 198 (100%+)
Looks like Losi has listened to us lipo guys.
http://www.losi.com/Search/Default.a...rm=lipo%20tray
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-21-2008, 11:09 AM   #6815
front
.05 sway bar
4 deg castor
rear
3 deg toe in
PF Mazda 6 used
Is there any info on the Losi site? All I have found is the sensorless esc. Have you had a chance to run the senorless esc?
www.donatelife.net
Old 03-21-2008, 11:59 AM   #6816
I've only run the sensored version, gotta have that fine control for onroad info should be coming pretty soon, it has all the adjustments you could ever want
RCTech #361
Old 03-21-2008, 12:03 PM   #6817
RCGaryK's Avatar
front
.05 sway bar
4 deg castor
rear
3 deg toe in
PF Mazda 6 used
Diffs high or low?
Any orings on top of the bladders?
When you say "regular" ball end link on the front, that's removing the JR link?
RCGaryK is offline   Reply With Quote
Old 03-21-2008, 01:39 PM   #6818
Originally Posted by RCGaryK View Post
Diffs high or low?
I knew I would forget something
diff high in front and back
regular link in front, AKA not the JR link
nothing above the shock bladders
RCTech #361
Old 03-21-2008, 02:17 PM   #6819
RCGaryK's Avatar
you're fired
Old 03-21-2008, 02:30 PM   #6820
you're fired
that's fine, you still can't have my steel lipo tray
RCTech #361
Old 03-21-2008, 03:06 PM   #6821
RussB's Avatar
Send a message via MSN to RussB
that's how i've been running mine. i'm running super light springs, like 10lb rear and 12.5lb fronts. i run at speedworld, so it's asphalt / rubber tires. i'll get a good feel for the new surface tomorrow, but i'm expecting my setup to be fine.
RussB is offline   Reply With Quote
Old 03-21-2008, 04:01 PM   #6822
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Russ, when did Speedworld open up again or is this weekend the start. I might try to shoot up there tomorrow if I have the time to take my lowely TT01 out for a spin and see what the Type R can do.
dfiantii is offline   Reply With Quote
Old 03-21-2008, 05:49 PM   #6823
MaxSp97's Avatar
Smile
I can't wait to remove all the lead weights on my R.
Thanks for the info.
Calvin
MaxSp97 is offline   Reply With Quote
Old 03-21-2008, 08:33 PM   #6824
FARBES's Avatar
Send a message via AIM to FARBES
Yeah, I visited speedworld's site saying:
SpeedWorld Sat. 1/10-1/12 Electric Race Day
SpeedWorld Raceway & Hobbies -- Electric RC Racing at its Finest. Electric racing is back, come out and join your competitors in some racing competition. Gates open @ 8:00am. Racing starts at 11:15. More details go to the menu bar on the left side for rules on classes.
SOURCE <<~Click
1/10 TC scale: JRX-R (X2) & Hot Bodies Cyclone S. Hi-End TX: 3PKS w/2.4GHz FASST.
FARBES is offline   Reply With Quote
Old 03-21-2008, 09:34 PM   #6825
RussB's Avatar
billy has posted on rcracing.com that gates open at 9. i talked to him earlier and he confirmed 9.
guess he's letting us sleep in
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
