Team Losi JRXS Type-R >
Like Tree52Likes
Old 03-16-2008, 06:29 PM
  #6796
tallyrc's Avatar
according to the manual a longer link creates more grip. b5/a5 is shorter than what i have? my droop is 3mm over ride height, but i'll check it again after i change the springs to 15 rear and 17 front and raising my rideheight..
tallyrc is offline
Old 03-16-2008, 06:32 PM
  #6797
John Tag's Avatar
Trader Rating: 42 (100%+)
My rear link is Outside hub near wheel and inside top near diff on tower..Longest I can get. I got that from Schreff and Larry on the rug and never went back.
John Tag is offline
Old 03-16-2008, 07:37 PM
  #6798
yyhayyim's Avatar
Trader Rating: 26 (100%+)
hmmmm...it seems like it depends on which side your looking at it
If you have 4B, then going to 5A or 5B should make the link longer, and thus give you increased rear traction.
camber link length from longest to shortest according to set up sheet pics on camber link location#
5B
5A
4B
4A
If you use the B hole location, it wont rotate as easy as with location A...with the 3 deg rear toe, 5A will get the car to rotate easier. If you use 2 deg rear toe, then 5B will work a bit smoother than 3 deg and 5B...but 4B and 4A will get you better rotation and make the front end hook up better and give you better steering.
Using 5B vs 5A, will get make the front push more on corner entry. If you work on the car and get it to have more steering to get fix the push you get with 5B, then the rear will want to break off power entering a sharp turn. 5A will get the car to whip around quicker without front push.
If you still want more rear traction, try 6A, instead of 5B...just stay away from the B hole for now...it will be usefull on open tracks or combined with other settings...but for now, the 6A, 5A, 4A locations will work better over all.
Hope to see the Type R soon!!
Later
Yohan
yyhayyim is offline
Old 03-16-2008, 08:05 PM
  #6799
tallyrc's Avatar
weird, on the manual the inner-most holes are 1, 4, and 7. 1 being the top and 7 being the lower.. i'm guessing tag is using 1B.. i apparently don't have a 17# so i went 15 rear and 20 front.. we'll see how that goes..
yohan when are you going to be running on wednesday night again? not sure when i can make it myself..
tallyrc is offline
Old 03-17-2008, 01:34 AM
  #6800
PDM
Try this. I was very fast at Coimbra with this setup. Long asphalt track with rubber tires.
tallyrc, by a quick look at your setup, you have to much static weight on the rear (you should aim at 50%-50%). That rear weight will make the car loose. (I am driving 52% at front and 48% at back)
You have thin oil at the front, that makes the car dive very fast at the front making the rear loose. You should make it heavier oil at the front to slow down the dive of the front.
PDM is offline
Old 03-17-2008, 06:59 AM
  #6801
yyhayyim's Avatar
I'll be at MDI wednesday afternoon. If you cant make it wednesday afternoon to MDI, maybe you can make it down to Coral Springs, FL track. We can be there any day during the week and practice from around 4-7:30pm.
About the links: I'm looking at the car as if the rear was facing me...it seems like you're looking at it from the front towards the rear, in essence we are talking about the same holes, but I'm using the names for the location from my perspective, which might not be right way
looking a the manual and looking at it from the front end towards the rear, now I see what your talking about, so your 4B, is actually the the longest link, and 4A would be the a bit shorter than that since you're using the inner hole on the hub. That would be equal to my rearward view of 6B or 6A
yyhayyim is offline
Old 03-17-2008, 01:17 PM
  #6802
Default Droop
HI All
My Type R is running with high roll centers front and rear, my next race is on a bumpy low traction asphalt track would it be best to set the Droop at 3mm or 5mm? and what noticeable differences would there be between the two?
Thanks guys for all your help
walden is offline
Old 03-18-2008, 04:30 AM
  #6803
Default Trakpower LiPo Top Deck Mod
Hi guys,
Just wanna share with you that the 4mm plugs in the Trakpower 4900 LiPo are placed narrower than the Orion 4800 Platinum pack which has no fitting problems. This does not allow the connectors to be pushed in properly without some grinding to the top deck. The photos are attached for easier reference.
For your information, I dipped the entire topdeck into a pail of water as well as the grinding stone (up till the collet). The graphite dust turned the water black within a few seconds and I flushed it down the floor trap with running water after i finshed dremelling. For the younger kids, please don't do this in your bedroom. Open air, or at least wear a mask. Drip superglue over the edging when the deck is dried.
File Type: doc
elijahbaley is offline
Old 03-18-2008, 01:01 PM
  #6804
jla8874's Avatar
Trader Rating: 23 (100%+)
Thats nice to know about the Trakpower. I was just about to buy that lipo, that might alter my decision. Several other people have mentioned owning that battery, but I don't recall anyone saying that the holes were too narrow.
jla8874 is offline
Old 03-18-2008, 02:30 PM
  #6805
Matt Howard's Avatar
The trakpower takes about a minute with a dremel and a grinding stone and it fits fine. I've run one since this fall with no fall off in performance at all.
Matt Howard is offline
Old 03-18-2008, 02:50 PM
  #6806
jla8874's Avatar
Good, because I had my mind set on the Trakpower anyhow.
jla8874 is offline
Old 03-18-2008, 03:11 PM
  #6807
yyhayyim's Avatar
I too run trackpowers...best packs I've had in a while. In less than a min they'll be working fine, like Matt pointed out. Great Packs indeeed:
yyhayyim is offline
Old 03-19-2008, 09:30 AM
  #6808
Xpress's Avatar
Which cells did you run at the nats?
Xpress is offline
Old 03-19-2008, 10:57 AM
  #6809
Express matched Ener-G cells. The Nimh cells still have a bit more voltage and at that level of racing you need everything you can get.
Old 03-19-2008, 11:50 AM
  #6810
Trader Rating: 208 (100%+)
Lipo is well off the pase at a National. At least in carpet. I ran a Core 5000 it ran well. But I did not have the pop out of the corners as the Sub-C cars. I ran 17.5 also. For club racing lipo is great. In mod lipo works better. Rick Howart was running a Reedy 5000 pack and made the A in mod and was fast.
dodgeguy is offline
