Old 03-11-2008, 03:11 PM   #6751
Send a message via MSN to nelarozi
Can anybody recommend me a good lipo battery for running TC Modified with 3.5 / 3.0 LRP Brushless motor. With 3.5 motor i could just barely run 5min with LRP 5000mAh pack. So i was looking at Maxamps 8000 7.4V. I am mostly concern about the quality because LRP batteries were very bad. Does any body use maxapms and could tell me about the quality or recommend other brand of lipo.
nelarozi is offline   Reply With Quote
Old 03-11-2008, 04:49 PM   #6752
Nelarozi,
I have started to run the SMC 28c 5000 and so far been pleased with the results. It is a VERY TIGHT fit in the R but will fit. I can't say anything one way or the other about runtime as I never even get close to the bottom of the tank, but I would think better cells will provide more usable energy. I will say that I find it hard to believe you will find a bigger lipo that will fit. The SMC uses literally every bit of space under the deck to fit and in fact only fits one way thanks to a taper in the battery case.
Frank Connolly
Thugs Bunny is offline   Reply With Quote
Old 03-11-2008, 05:36 PM   #6753
hobbipro's Avatar
Trader Rating: 21 (100%+)
Well after a few emails to losi about the steel lipo tray, got an answer back. They are indeed making them again, and expected to be back in stores in 6-8 weeks. No information on price was given, but this is good news indeed!
hobbipro is offline   Reply With Quote
Old 03-11-2008, 05:39 PM   #6754
vabroom's Avatar
Frank,
Since some of the lipos are a tight fit or very tight fit, is there a chance the lipos will tweak the chassis? Being a tight fit and putting pressure on the battery plate (downward) and on the top chassis plate (upward) won't these cause tweak on the car. Just me thinking too much but wondering if anyone notice this when changing batteries (the battery would not be in the exact position each battery change).
vabroom is offline   Reply With Quote
Old 03-11-2008, 06:14 PM   #6755
jla8874's Avatar
Trader Rating: 23 (100%+)
Nice work hobbipro! Now lets hope they dont delay the things for forever like Losi is famous for doing.
jla8874 is offline   Reply With Quote
Old 03-11-2008, 06:33 PM   #6756
vabroom,
while I suppose tweak is possible it would seem to me to be in the vertical arch plane and therefore very unlikely. I would think that a very tight fit would in fact aid in the prevention of tweak in the torsional plane(twisting). Granted the greater strength would be more likely to hold a tweak once developed but I would think it would prevent its occurrence in the first place. I guess it's a catch-22. I'll say I haven't noticed any issues that would imply tweak from the new batteries.
Frank Connolly
Old 03-11-2008, 06:58 PM   #6757
jla8874's Avatar
Can someone please tell me if this is advantageous or should I switch it back?
The guy I bought my type r from has taken off the upper arms and in their place he has put a steering tierod type link. It looks much more simple, and its probably a little lighter, but should I put the upper arms back on? Is there a specific reason to do this?
Old 03-11-2008, 09:16 PM   #6758
mojoman's Avatar
By upper arms I'm assuming you mean camber links? If that is the case many people have said they get more steering using the traditional ball cup and ball stud vs. the jr link. Personally I have found a very insignificant difference. I use the jr link on my asphalt car and an associated ball cup on my carpet car. The only reason I do this is due to the fact that with my carpet setup I need that little bit of steering in the car as most do with foams (point and shoot), on asphalt things are more fluid and you either have the steering in your car or you need a new setup.
On another note, but in the same vein. I have never been longing for steering with this car no matter what surface or amount of traction on the track. 100% better than the original, but I'm sure that I'm preaching to the choir. Thanks to the r&d team and all the drivers that helped or are currently helping to make a super product!!
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 03-12-2008, 04:27 AM   #6759
jla8874's Avatar
Thats it mojo. It was the JR link I was referring to, compared to the upper arms. I'm starting out racing foams on carpet, so I am debating as to whether to put the upper arms back on. I think the best thing for me to do is to drive it like it is, then put the upper arms back on that way I can see for myself the differences between them.
Old 03-12-2008, 04:34 AM   #6760
Matt Howard's Avatar
For me, the JR link lacks a bit of initial steering but has alot of mid and exit corner steering. Also seems to keep the car "flatter" in the corner. The standard link gives me a bit more initial steering but not as much mid and exit corner steering as the JR link. Try both and see what you like better.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-12-2008, 08:18 AM   #6761
jla8874's Avatar
Good idea Matt. Are you running a brushless setup? If so, whatcha got?
Old 03-12-2008, 11:28 AM   #6762
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
what positon are you guy running the diffs on asphalt with rubber tires?
metalracer2 is offline   Reply With Quote
Old 03-12-2008, 11:40 AM   #6763
John Tag's Avatar
Trader Rating: 42 (100%+)
I run both High...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-12-2008, 12:41 PM   #6764
TaJoe5's Avatar
Send a message via AIM to TaJoe5
MOJO this is your time to shine lol
Joe
OHP Batteries and Motors, http://www.ohiohobbyplus.com/
Razor Graphix, Team Losi Type-R, Tamiya EVO-IV, CRC Gen X
TaJoe5 is offline   Reply With Quote
Old 03-13-2008, 08:34 AM   #6765
What about MaxAmps 6000mah 7.4, they are smaller than my LIPO 5000 mah pack, but i wonder what the quality is like because with lrp 5000mah i can only get 2800mAh at 15A discharge. Does anybody have an information how much can the MP 6000mah putout. And another question, what kind of balancing connector is compatable with polyquest connector?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
