Old 03-03-2008, 07:51 PM   #6661
jla8874's Avatar
Trader Rating: 23 (100%+)
Ok, so now that thats settled... So we now know that sometime in the future Losi will be making more trays. Good. It seems like more people than I thought are in need of one. So just how long did they make these things? Did those who didnt get one just pushed it off and said I'll get one sooner or later, then before they knew it they quit making them?
jla8874 is offline   Reply With Quote
Old 03-04-2008, 02:02 AM   #6662
Capelracer's Avatar
Originally Posted by jla8874 View Post
... they were way too expensive to make, and if they made any more they would have to charge twice as much for them.
So Horizon, charge double or whatever you gotta to make a dollar or two, just get them out!!
Capelracer is offline   Reply With Quote
Old 03-04-2008, 03:55 AM   #6663
jla8874's Avatar
I agree. I think they were about $20 before, I would pay twice that for one.
Old 03-04-2008, 05:50 AM   #6664
racingboy14's Avatar
Trader Rating: 25 (96%+)
Ideally, I would want it sunk in to a tray and snugged tight by the top chassis plate. If there were room, velcro maybe. At last resort strapping tape. Anything but black electrical tape.
Ok, Ill relay that to the guys making them. ( They are from my local track)
Bk Graphics Custom Painted Bodies
Email me at bkessie@woh.rr.com for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 03-04-2008, 09:52 AM   #6665
jla8874's Avatar
Cool.
Old 03-04-2008, 11:46 AM   #6666
TaJoe5's Avatar
Send a message via AIM to TaJoe5
+1 here
OHP Batteries and Motors, http://www.ohiohobbyplus.com/
Razor Graphix, Team Losi Type-R, Tamiya EVO-IV, CRC Gen X
TaJoe5 is offline   Reply With Quote
Old 03-04-2008, 12:07 PM   #6667
For those of you that want or are running lipos in your tryp r, What lipo are you running and does the lipo you are running have battery slot bumps on the bottom?
Old 03-04-2008, 12:23 PM   #6668
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
maxamps 6000 for now lookin into the new "roar spec" one tho. i use the flat tray and its a pretty tite fit with the layshat and the pulley.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 03-04-2008, 12:25 PM   #6669
Jerry P's Avatar
Trader Rating: 44 (100%+)
I'm running the Orion 4800 which is flat on the bottom. I use the stock Losi Lipo tray with it.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 03-04-2008, 12:26 PM   #6670
noline's Avatar
For the Losi JRXS Type R, I just picked up a Novak BL 10.5 and a 8.5 how would I gear these motors with a 118 spur... The track size is 100x45 I'll be running rubber tires on asphalt.
noline is offline   Reply With Quote
Old 03-04-2008, 12:35 PM   #6671
morris's Avatar
Trader Rating: 40 (100%+)
i have asked many questions like this myself and to be honest with you only peeps can recremend a starting point.for what i was told to run for a fdr i did.and to find out i was overgeared.i would ask anybody that usues the same bl motor..ask then what there fdr is.more than likely they have it figured out.go to gearchart.com and click on gearchart creator...do the numbers and compare gear ratio with what the other guys at your track run....this should help you ouit alot...i hope anyways...
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 03-04-2008, 03:15 PM   #6672
yyhayyim's Avatar
Trader Rating: 26 (100%+)
I run the TYpe R on asphalt...with Novak 10.5BL, with 118T Spur, you should try 42T Pinion, for 5.14 FDR as starting point...If you need try fitting a 43T Pinion for a bit more top end.
The best thing you can do is get the PRS gear adapter so you can use smaller tooth Spurs, like 108 and 110 Kimbrough/Robinson Spurs...or just get PRS Spur Gears 112T so you can get lower FDR.
yyhayyim is offline   Reply With Quote
Old 03-04-2008, 03:19 PM   #6673
yyhayyim's Avatar
I'm running the 25C Trackpower 4900...really good pack, or CORE5000 packs. Orion 4800 also fit; the Orion 3600 are too wide, and they rub on the pulleys and must be shaven down about 1mm on each side to clear the center pulleys
Old 03-04-2008, 03:44 PM   #6674
What would you guys remommed gearing a co27 for a high bite carpet track, right now my gearing is 108 spur and 42 pinion. it has great top end but is really slow off the line.
Old 03-04-2008, 03:49 PM   #6675
Mike Haynes's Avatar
Not sure what size track or tire, but for stock i have always been in the range of 128/34-38, sounds like you are rather over geared.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
