Old 02-22-2008, 08:33 PM   #6586
MaxRain's Avatar
Default bearings
has anyone purchased bearins from avidrc.com?
I am thinking of buying the revolution series bearings that has one rubber shield on one side and a metal shield on the other.
http://www.avidrc.com/shop/?action=c...y&id=1&subid=2
Gordon
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://youtu.be/owXBpsQkyjE
Facebook: CARCAR
MaxRain is online now   Reply With Quote
Old 02-22-2008, 09:40 PM   #6587
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
got some n my 8th scale. work good.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 02-22-2008, 10:11 PM   #6588
Yeti35's Avatar
Avid is all I buy. You can't beat the price.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 02-23-2008, 04:22 AM   #6589
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Originally Posted by J@UNE View Post
Hey Guys,
I'm running a setup similar to Shreff but with Jaco DP, 17Lbs rear springs, .225 fr and .165 rear hex.
My car tries to lift on high traction corners... What should I do to make it flat... I remember runing anti-dive on my FK05
thx
Are you glueing the front tires? Are you running a swaybar?
Sigearhead is offline   Reply With Quote
Old 02-23-2008, 07:32 AM   #6590
Mike Haynes's Avatar
Hey Guys,
thx
I would go to the .195 rear hex, and maybe take out a little droop from the back.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-23-2008, 08:39 AM   #6591
rcarmchl's Avatar
Trader Rating: 15 (100%+)
yes..great bearings, they are fast and easy to deal with.
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 02-23-2008, 10:04 PM   #6592
Trader Rating: 193 (99%+)
I have noticed looking at a few setup sheets that some guys are running a little toe out. Anyone want to expand as to why?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-24-2008, 07:53 AM   #6593
mojoman's Avatar
Hey Guys,
thx
I tried schreffs setup with jacos as well. I couldn't do a thing to get the car hooked. As soon as I put parmas on it was on rails. Try magentas up front and cyans in the rear.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 02-24-2008, 11:30 AM   #6594
Spillertwo's Avatar
Hello guys,
Just finished building my JRXS Type R and have some questions about it:
+ i notice there is some horizontal play in the lower suspension arms on the long hinge pins. Does everybody shim this out or is it supposed to be like that ?
+ the wheel axles stick out quite a bit after you put on the wheelnut. Does everybody sand them down so they are flat with the wheelnut ?
One bad thing about my kit. It has 1 shock shaft that is not 27 mm long but only 23.4 mm. So i can not finish the car.
To finish my story here are two pics of my car :-)
Spillertwo is offline   Reply With Quote
Old 02-24-2008, 01:50 PM   #6595
mojoman's Avatar
Yes shim out your hinge pins and your kingpins if necessary.
I would grind (sanding will take forever) those axles down not doing so has caused many drivers some big finishes!
Casey Castleman
Old 02-24-2008, 07:16 PM   #6596
RCGaryK's Avatar
Hey guys. Been running stock with my Type R and have been very happy with it. In trying to get ready for the Carpet Nats I started Playing with a 17.5 today. Great punch but no top end. I'm figuring I'm still too undergeared. I think the tallest I was able to get in the car was a 118/47 or 48. I can't move the motor any further back so I am debating about picking up a PRS spur gear adaptor and dropping down to a 110 or so. Anyone else run a 17.5 as of yet in the Type R? Matt, since the race is going to be at your home track do you have any gearing suggestions?
RCGaryK is offline   Reply With Quote
Old 02-24-2008, 07:24 PM   #6597
Matt Howard's Avatar
Get the PRS adaptor to be able to run smaller spurs, that's the only way to hit the gearing you'll need with the 17.5. I'm running 13.5 rubber so i'm not alot of help with the exact gearing you'll need but you better have some big pinions I switched over to the PRS adaptor tonight so I have some more gearing leverage if I need it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-24-2008, 07:28 PM   #6598
I have been runing rubber tire with a 17.5, and found a 104 to 108 spur was best to get high rollouts...depending on track size u will need between 45 and 50 with that spur sizze.
Old 02-24-2008, 08:01 PM   #6599
RCGaryK's Avatar
Thanks guys. I'm used to running the Tamiya GT3/Mabuchi class so I have up to 51T pinions. I'll have to see if I can't get my hands on that adapter somewhere
Old 02-24-2008, 08:46 PM   #6600
Trader Rating: 22 (100%+)
gives a little more steering upon corner entry
"I can't be any clearer, on how crystal clear I am being"
convikt is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
