Old 02-13-2008, 12:36 PM   #6511
Trader Rating: 195 (99%+)
It is probably his driving style Sounds like you have a spool now.
Favian are you driving the Losi now? I have 1 on the way to run. I am going to run some foam indoors then rubber in the summer. This car seems to be the best for both rubber and foam.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-13-2008, 06:14 PM   #6512
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Reznor88 View Post
I'm running rubber tire / carpet - iassume the ONE WAY is the way to go.....
Anyone experience any negative side effects with regards to broken spures or other parts when using the ONE WAY?
Thanks!
doug,
did you go back to trying the one-way...?
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 02-13-2008, 08:25 PM   #6513
timmay70's Avatar
Can someone please tell me what balls are used with the captured rod ends (losa6017). None of the retailers cross-reference what ball to use with this rod end. I figured all the Losi gurus would know.. TIA
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 02-14-2008, 03:39 AM   #6514
Matt Howard's Avatar
http://www.losi.com/Products/Default...rodID=LOSA6026
any standard 4-40 ball end will work with the captured rod ends. LOSA6009 are the the ends used on the shocktowers for the camber links, they work as well.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-14-2008, 03:48 AM   #6515
JRXS_chris's Avatar
I've had a couple of spurs go since using a one way, rather that than damaging anything else tho!
JRXS_chris is offline   Reply With Quote
Old 02-14-2008, 07:27 AM   #6516
timmay70's Avatar
So if I understand this correctly, these are meant to replace the standard ball cups...
Thanks, much appreciated.
ROAR #105242
Old 02-14-2008, 10:46 AM   #6517
Yeti35's Avatar
Replace the stock layshaft with this one and you should not have anymore issues. http://www.losipartshouse.com/servle...aft-Set/Detail It is the one from the old car and no modification is needed, just replace the current one with this one.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 02-14-2008, 11:04 AM   #6518
i'm looking at Schreffler's setup from the snowbirds, i'm confused on the rear pivot, he has both 0 and 1 degree selected... which one is it or does he mean 2 deg
abiye is offline   Reply With Quote
Old 02-14-2008, 11:25 AM   #6519
John Tag's Avatar
Trader Rating: 42 (100%+)
Im sure Jason had the 0* mount with 1 deg rear hubs in rear for 2* total...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 02-14-2008, 11:52 AM   #6520
schreff's Avatar
Send a message via AIM to schreff
You are correct sir.
I fixed the mistake on the sheet too.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-14-2008, 07:45 PM   #6521
Could some one please let me know what is the tooth number of the pulley and the internal ratio? thanks
ioxqq is offline   Reply With Quote
Old 02-14-2008, 07:46 PM   #6522
Mike Haynes's Avatar
If you use the 42tooth pully it is a 1.83 internal.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-14-2008, 07:50 PM   #6523
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
23t
Old 02-14-2008, 10:07 PM   #6524
RussB's Avatar
Send a message via MSN to RussB
so... any way to fit the orion 3600 into the car WITHOUT modifying the case? seems that any modifications to the hard case makes the pack non-compliant with roar rules and not allowed.
RussB is offline   Reply With Quote
Old 02-14-2008, 11:33 PM   #6525
When I looked at getting the 3600 into the car it seemed that pretty drastic changes were needed to fit it in without modding the case. It seemed any potential benefit gained by the pack was quickly lost by the change in car geometry. You had to either spread the top shaft or raise the top shaft, neither were attractive.
Frank Connolly
Thugs Bunny is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
