Old 02-05-2008, 09:15 PM   #6436
Yeti35's Avatar
Originally Posted by T. Hodge View Post
YOUR MY F'N HERO!
Wow, two post in less then a month, Todd really has not forgotten about us here!! Todd, keep production rolling on this car, I think you are in for some more wins!!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 02-06-2008, 04:24 AM   #6437
mojoman's Avatar
Originally Posted by yyhayyim View Post
Well, my Type R's have been great so far...so far for the tight and technical 140X70ft outdoor asphalt track its been very smooth and easy to drive using T. Hodge's Reedy 2007 race set up...but it needs to be much more aggressive. I need it to rotate quickly and turn left to right much faster- it needs to be more reactive...tried some of Schreffs set up for the Jackson race, but I still dont get the reaction I'm looking for...I have tried different shock oils and spring combinations, roll centers, camber link, sway bars, JR-Link and standard, but it just doesnt seem to get them car to become so agressive that you actually need to calm it down...that's what i'm looking for...I'd like for it to be reactive anough that I'll need to actually tone it down a bit...Any suggestions?
Currently using:
Ride height: 5mm FR, 5.5R
High ROll centers all around- have tried High front, and low rear also
Shocks- 45W 15lb front, 40wt 12lb Rear with 2 o-rings
1.5 camber all around
4 deg caster
2 deg rear toe in
diff position: front high, rear low
Front Spool
Camber link: front-#3, with standard link, and rear: 5A
swaybars: Front .40, rear .30
Tires- Jaco Rubberz (Greens:Med firm)
Mazda Speed 6 body
I can think of a few things. Raise both diffs to the high position that'll make your car more aggressive. Change your body type to a dna 2 that will give your car a tad more steering. Lastly (most importantly) get the one way for the front.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 02-06-2008, 10:01 PM   #6438
syndr0me's Avatar
Trader Rating: 32 (100%+)
Sorry for that chassis stupidity in the other thread Schreff. I wanted to apologize there but it got locked. I think what you did at Snowbirds is one of the great R/C stories I've seen so far. I didn't see that post from BMI or I never would have brought it up. That whole thing was lame from the beginning.
syndr0me is offline   Reply With Quote
Old 02-06-2008, 10:27 PM   #6439
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
oops
metalracer2 is offline   Reply With Quote
Old 02-07-2008, 08:34 AM   #6440
John Tag's Avatar
Trader Rating: 42 (100%+)
Anybody here have any photos of there Type-R with a LRP speedo "Neatly" mounted..I'm looking for some ideas......
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 02-07-2008, 09:11 AM   #6441
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
here you go i hope is neat enough
Old 02-07-2008, 10:28 PM   #6442
Alright Im new to this car and am looking for a good mod setup for carpet...any suggestions? I already got Schreff's setup for 19 turn just havent made it to te track yet.
Gitsum is offline   Reply With Quote
Old 02-07-2008, 11:29 PM   #6443
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
if you are running on a jack track i use dumas's setup for mod and it works pretty good....havent actually changed anything from it
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 02-08-2008, 11:10 AM   #6444
J@UNE's Avatar
Looking at Shreff's setup, Do you think that runing the rear link in the 4/B position with the 3mm shim would be similar to 7B and about 1mm shim?
Also I know it was posted before but can't find it, What's the difference between short and std/longneck ballstud. If I want to duplicate shreff's setup, should I use 2.5 mm shim with the longneck?
Thanx
J@UNE is offline   Reply With Quote
Old 02-08-2008, 11:37 AM   #6445
schreff's Avatar
Send a message via AIM to schreff
Thanx
Let me see if I can help you out here...
Moving the link to 7/B, regardless of shimming on the hub, is a big difference from 4/B. That is more of a complete roll center change. In essence, you are lowering the whole link. That "raises" the rear roll center since you are moving the link closer to the lower pivot point. The link will also end up being a little shorter which will be more camber change. That might be something advantageous to rubber, but not to the foam setup Larry and I have created.
The difference in standard neck ballstud to shortneck ballstud is .030". That's roughly .75mm. So 2.5mm plus a standard ball stud will be taller than a 3mm/shortneck stud.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-08-2008, 12:23 PM   #6446
J@UNE's Avatar
Awesome!!! Thanks a bunch
Old 02-08-2008, 03:25 PM   #6447
Thx Jason for posting your set up
Congrats on the multiple wins at the birds
Could you pleased explain what affect your are looking for with the steering
are you looking to get bump steer or take it out
thx
Lou
look is offline   Reply With Quote
Old 02-08-2008, 05:15 PM   #6448
Kropy's Avatar
Send a message via AIM to Kropy
Schreff ~ What do you prefer Charmin or Cottonelle?
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 02-08-2008, 10:59 PM   #6449
Default Smaller Pulleys
Anyone run the 41T pulleys front and back. The manual recommends not to, but it drops the internal ratio from 1.83 to ~1.7 are there any advantages to this in 19t brushed or 10.5, 13.5 brushless??
Electro-MAX RC is offline   Reply With Quote
Old 02-09-2008, 04:27 PM   #6450
RussB's Avatar
Send a message via MSN to RussB
doing that may make it easier to gear motors like a 13.5 with the big rotor and a 17.5.
which lipo packs fit the type-r better with the plastic tray? orion 3600 or orion platinum?
RussB is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
