Old 01-24-2008, 08:01 PM   #6331
El_Boricua's Avatar
Mike:
Can you post the setup you have for carpet/rubber?
thanks
Benson Rice
El_Boricua is offline   Reply With Quote
Old 01-24-2008, 08:03 PM   #6332
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
Originally Posted by Brian L View Post
Ditto. Although I got punted.
If there was a alum. diff hub, how many people would be intrested in it? I know a couple people that might be able to do it. I will talk to them and get a price. I was also trying to figure out how to make a one way up to use the long bones. I have a feeling it is going to be to much once it is figured out.
Good luck to everyone heading to the Birds. Wish I was going. Don't forget about the PM Schreff. I will be watching.
put me down for a diff hub
Old 01-24-2008, 08:04 PM   #6333
Super Moderator
Marcos.J's Avatar
Originally Posted by Applesauce View Post
Where can i find these?
try here http://www.petitrc.com/view_news.php?id=4620
Old 01-24-2008, 08:18 PM   #6334
mojoman's Avatar
Originally Posted by El_Boricua View Post
I'm in the process of getting the oneway. What seems to be the problem?
From what I have heard there isn't a problem with the one way. Everybody seems to like it. I'm just a stubborn guy who sees something that works and thinks no substitutes will do. As far as chassis flex I tried running the car on a high bite asphalt track with and without the chassis braces and found the car was much too unstable without the front braces, but I've always perfered a stiff setup whether on asphalt or carpet. I didn't mean to rock the boat. See everybody in Fla. in less then 4 days.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 01-24-2008, 09:30 PM   #6335
YmeBP's Avatar
Trader Rating: 32 (100%+)
I'd be interested in some, i use the walls like slot cars use the slot ;0
YmeBP is offline   Reply With Quote
Old 01-24-2008, 09:32 PM   #6336
There are guys saying that the car is good on low traction asphalt, how do you go about getting it to really grip up.
I started with the Todd setup everyone keeps quoting, but it had no bite in the corner.
Last meeting i did try going to an ultra soft spring on the front end, the Short Tamiya flouros, i think these are around 8lb, i am going to try softer on the rear also to see how it goes. The front end became much more darty and turn in was substantially better.
I am just thinking that the US version of low grip is far removed from the Aussise version of low grip.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-25-2008, 05:43 AM   #6337
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by schreff View Post
Amen brother.
Just look at my Vegas results. Those damn walls!
Wall's..Heck your the 1 that hit them looking at the food court line thinking of lunch....
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-25-2008, 06:26 AM   #6338
Yeti35's Avatar
Now that was funny I don't care who you are!! Remember Schreff, I am just agreeing, I did not say anything!!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 01-25-2008, 06:37 AM   #6339
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Keep in mind the T. Hodge set up for Reedy Race 2007 or ROaR 2007, is for med-high traction asphalt.
For low traction, just make the following changes:
35WT oil all around, or 30WT if its really dusty and untreated. Use the 15lb springs up front, with 12.5lbs in the rear. If you need a bit more front steering/bite upgrade to 15lbs springs in rear. Also use 5A for rear camber link position, or 4A if needed. Test with these changes and see what it does....it should be much better with these simple changes.
yyhayyim is offline   Reply With Quote
Old 01-25-2008, 07:12 AM   #6340
J@UNE's Avatar
Im running my xray oneway in the Losi since July. I'm racing on carpet every weeks without a single failure... And it spin like an xray too
I kept the multi diff function so it can be used as a spool or a locked one way... I posted it last summer but since we are talking about it
Xray cvd blades...
J@UNE is offline   Reply With Quote
Old 01-25-2008, 08:36 AM   #6341
Registered User
For what it's worth going back to the alloy parts ... the XRAY T2 front hubs do fit on the car with some minor modification. We were strapped for parts at a recent local race and Peter discovered that you can grind down the inside of the c-hub to clear the LCD and do some minor work to the bottom of it to clear the arm it will fit. I am running medium plastic XRAY hubs on my car because they have more give to them.
The same will work with the aluminum parts. You just can't run the steering knuckle as the depth is all wrong.
While I understand your guys standpoint of a stiff car being a better car, I also feel tuning with the softer plastic gives you a subtle change that is sometimes needed. Sort of like sway bars. But in the end, sometimes you run on a track that you cannot run stiff arms on and it would just be nice to survive a heat.
Desolas is offline   Reply With Quote
Old 01-25-2008, 08:46 AM   #6342
DITTO put me down for some diff hubs as well!
jeffb is offline   Reply With Quote
Old 01-25-2008, 09:40 AM   #6343
vabroom's Avatar
The one-way works great, you just have to be careful when you assembly it. The one-way bearings (little rods) that tend to fall out. Use a white towel and not those black pits mats everyone sells when assembling the one-way. So, if they do fall out you can easily find them.
vabroom is offline   Reply With Quote
Old 01-25-2008, 07:23 PM   #6344
Trader Rating: 114 (100%+)
Originally Posted by dfiantii View Post
Are you guys saying its not even worth it to buy a Losi Type R anymore? I was planning to buy one later on this year closer to the summer. If they are going to dump it then I might as well spend more for the Xray or Mi3 or even Tamiya 415
Um no way... not going to happen.
Losi is actually looking for more suggestions on updating the car. It runs so well, they really haven't received many complaints. If you have issues with the one-way, or other things about the car.. make sure you email LOSI with suggestions.
We just had 3 guys last weekend that purchased Xray 008 cars and just dumped them for JRXS-R.. they cannot get the 008 to rotate in the corners and that is easily accomplished with the JRXS.
Chris Furman is offline   Reply With Quote
Old 01-25-2008, 08:20 PM   #6345
jrxs-r's Avatar
How much grip does the rear end have?
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
