Old 01-10-2008, 02:40 PM   #6241
Trader Rating: 21 (100%+)
Does the spool pulley have the holes for diff balls? If the pulley has it, then it is the wrong one. It should have a solid piece over the holes.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 01-12-2008, 10:31 PM   #6242
MaxRain's Avatar
Default torque screwdrivers
Does anyone use these to precisely set your diffs after rebuilds?
I know that some suggest the feel, but wouldn't it be easier to set it using the screwdriver?
Looking for feedback.
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 01-13-2008, 06:28 PM   #6243
Default Snappy Rear End
Hiya all,
I'm a racer in Singapore presently running the R for the last year and a half in mod asphalt. This year's race series has a 23turn handout motor instead of the mod class. And there's no weight limit anymore. I have a problem with a snappy rear end.
Mod setup : Front 15lbs 40wt, spool, .04" roll bar. Rear 12.5lbs 40wt, .06" roll bar. LRP SphereComp on 6.5 turn brushless with IB4200 batteries and Sorex 40R all round. Weight around 1500g
23T Stock : Front 17.5lbs,spool .04" roll bar. Rear 12.5lbs 40wt, .06"roll bar. LRP SphereComp on Xenon 23turn with Orion 4800 Lipo. Weight 1340g
The car suffers from on power oversteering. When I squeeze, the rear wants to switch places with the front. I have tamed it by lowering the punch control on the LRP, adding a harder spring. Losing both front and rear roll bars had no difference so i put them back.
I need someone to critique my thoughts below.
1) I'm guessing with the drastic weight loss from the Lipo, the car has less tendency to want roll through corners. Will softer 10.5lbs springs all round help? I prefer soft cars as i find them easier to drive fast.
2) Max out the droop in front, this allows the weight to transfer rearward and sit the car down on corner exit.
3) Stock motors have alot of engine drag brake when I release the trigger, mainly due to the bushings. Move all static weight to the front.
Hope you guys can help me out here.
elijahbaley is offline   Reply With Quote
Old 01-13-2008, 07:08 PM   #6244
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
Originally Posted by elijahbaley View Post
Hiya all,
whats your rollcenter set at?(front and rear)camber links? whats your whole set up?
Old 01-13-2008, 07:33 PM   #6245
The Rev's Avatar
it's probably due to having too much weight in the rear from the motor. not too much you can do other then ballast the front with lead. The r is somewhat known for being less then ideal on asphalt as is, so when you take even more weight out of the front, it gets tail happy due to the motor swinging the rear around.
also, you could try stiffer rear springs to make the snap more predictable, and lower the rear roll center.
The Rev is offline   Reply With Quote
Old 01-13-2008, 07:51 PM   #6246
syndr0me's Avatar
Trader Rating: 32 (100%+)
When I used my R underweight (with LiPo) it cornered like a 1/12th scale. It was also the most twitchy, ridiculously unpredictable thing I'd ever driven. I'm guessing there's quite a bit of setup changes that would need to happen to really take advantage of a lighter car.
syndr0me is offline   Reply With Quote
Old 01-13-2008, 07:52 PM   #6247
Front : Inner suspension pin full low. JR link. Spring at #2 middle. Upper camber link #3 longest and most angled down.
Rear : Inner suspension pin full low, arms forward for shorter wheelbase. Upper camber link #4A
Hope this helps
Old 01-13-2008, 08:22 PM   #6248
Trader Rating: 27 (100%+)
whats the scoop with the steel lipo tray? I need one and cant find it
convikt is offline   Reply With Quote
Old 01-13-2008, 08:33 PM   #6249
Yeti35's Avatar
No longer in production from what I heard.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 01-13-2008, 08:40 PM   #6250
thats crazy. Doesnt losi see a demand for these things? Thats right, they got more ready-to-runs to make. Thanks for the reply though
Old 01-13-2008, 08:44 PM   #6251
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
there has been rumor floating aroound that they will do another, but not sure when
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 01-13-2008, 10:53 PM   #6252
Thanks alot. I never thought going harder in the rear. I'll give that a try.
Old 01-13-2008, 11:06 PM   #6253
Sigearhead's Avatar
Trader Rating: 68 (100%+)
In regards to the steel lipo battery tray...
I have a guy making some and I will try and see if there is enough interest. PM me if you want one so I can get an idea of how many and see what price I can sell them for. It's not something that is easy to make so I'm guessing in the area of $35 shipped.
Sigearhead is offline   Reply With Quote
Old 01-15-2008, 07:28 AM   #6254
FARBES's Avatar
Send a message via AIM to FARBES
Hi, there is hope for someone can answermy question:
In eventually, If i wanted to upgrade the tech chassis. So I would buy JRXS Type R kit. But I am very concerning that Horizon Hobby will stop to contuining make the LOSI JRXS type R kits in future, is that true?
1/10 TC scale: JRX-R (X2) & Hot Bodies Cyclone S. Hi-End TX: 3PKS w/2.4GHz FASST.
FARBES is offline   Reply With Quote
Old 01-15-2008, 07:31 AM   #6255
Sigearhead's Avatar
Near future...No....They still make parts for the XXX-S G+ if that tells you anything.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
