Old 12-29-2007, 08:19 PM   #6136
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Sigearhead View Post
I would still mount it on the left side. The servo sits towards the right and with the weight of the receiver on the right side it should keep the car fairly balanced. I would take that fan and heatsink off that sphere TC and stand it up on it's side. The fan and heatsink aren't really necessary, unless you're running a low wind modified outside. Your speedo shouldn't get very warm at all.
oh yea...?
anybody else doing it like this as well?
i dont have the sphere in hand to look at it.but is it a hard task to take the fan off?
looks like i will be running the orion vortex 13.5..
lmk guys,
thx again..............
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-29-2007, 08:24 PM   #6137
Matt Howard's Avatar
you pretty much need to mount any brushless esc on the right side. You will need to add weight to the left side to get it balanced left/right. If you mount it on the left side you have all the wires from the esc on that side as well instead of going across the chassis if it was on the right side. Also, since the belt is on the left side you can get the esc closer to the center with it being on the right side.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-29-2007, 08:37 PM   #6138
morris's Avatar
yea i here ya there.im now using an lrp q2 and have it mounted like on the box.i just wasnt sure about taking the fan off the sphere and mounting it on its side in the same location.
how much weight you adding to compinsate for the rx?
Old 12-29-2007, 08:39 PM   #6139
I "think" I have 1 1/2 oz on the left side to combat the enormity that is the novak GTB
RCTech #361
Old 12-29-2007, 08:41 PM   #6140
morris's Avatar
ic....the sphere tc is smaller than the gtb correct
Old 12-29-2007, 08:49 PM   #6141
I haven't weighed both of them so I don't know which one is heavier, I "think" the GTB is a bit heavier but I don't have any numbers to back it up.
RCTech #361
Old 12-29-2007, 08:56 PM   #6142
J@UNE's Avatar
When I ran the GTB, I placed it on the right and extend the caps wire to have it mounted on the left with the receiver. Took off the fan and didn't need much more weight to be well balanced.
I mount the mamba on the left as the belt go below the "circuit board".
J@UNE is offline   Reply With Quote
Old 12-29-2007, 09:13 PM   #6143
morris's Avatar
well maybe is what i will do is just add like a little and do from there....
unless anyone in here in running the sphere and can help me out...
Old 01-01-2008, 02:27 AM   #6144
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Thumbs up
HAPPY NEW YEAR TO THE LOSI FORUM.
dfiantii is offline   Reply With Quote
Old 01-01-2008, 06:59 AM   #6145
mojoman's Avatar
Originally Posted by RobS View Post
Just ran my Type R for the first time today and it was awesome! I set TQ with a new track record and went on to win the main as well. However in practice I managed to absolutely shatter both my thrust bearings. I literally turned them both to sand. Has this happened to anybody before?
Hey Rob try the Mc Master thrust bearing part#7806K53 at this link http://www.mcmaster.com/
Peace,
Casey
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 01-01-2008, 08:17 AM   #6146
RCGaryK's Avatar
http://www.losi.com/ProdInfo/Files/T...etup_Dumas.pdf
http://www.losi.com/ProdInfo/Files/T...up_Schreff.pdf
Here's the two most copied setups for the type R for foam carpet racing
Ok, here's a question....
I was going to use one of these two setups when I was building my Type R and it doesn't indicate whether to use any kick or squat with the suspension mounts. Are the hinge pins to be level front to back?
RCGaryK is offline   Reply With Quote
Old 01-01-2008, 08:21 AM   #6147
Xpress's Avatar
Can anybody provide me with a part number for the "tall" ballstuds that are used in the rear hubs and for the front kingpin?
What is the difference in height between the tall and standard ballstud?
Xpress is offline   Reply With Quote
Old 01-01-2008, 08:22 AM   #6148
yep, pins are level front and back for these setups
RCTech #361
Old 01-01-2008, 08:27 AM   #6149
the kit ballstuds are the "tall" or standard ones, Losi sells shorter ones. Here's the page on Losi's site listing all of them, the "short neck" ones are the ones your after if you want a shorter one compared to the kit ones
http://www.losi.com/Search/Default.a...rm=ball%20stud
RCTech #361
Old 01-01-2008, 08:30 AM   #6150
RCGaryK's Avatar
Really? That's kinda odd but if it works, what the hell, right?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
