Old 12-25-2007, 10:28 PM   #6121
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
ok with the ustc championships coming up i am haveing a hard time finding a setup that works for me. i am runnin a 13.5 stock rubber class on a high bite ozite. any help would be appreciated!
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 12-25-2007, 11:38 PM   #6122
Mike Haynes's Avatar
This is what i have so far from playing around with rubber, it is not perfect but should be a decent starting point, i'm pretty happy with it.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-27-2007, 04:08 AM   #6123
Originally Posted by Giorgio View Post
I was a good boy and a little early Santa, bring me the type R.
So I'm leaving my Cyclone to the Losi.
Some one will to help with the "Do and Don't Do"?
Racing mod, BL 4.5 or similar "hot" brushed.
Thanks in advance!
Ciao Giorgio.
Benvenuto nel Team Losi.
Se la cosa può interessarti, se non lo sai già, trovi anche il forum Automodelli.it (in italiano) dove si parla tra le altre anche della Losi JRXS -R.
Scusa l'intromissione ma non ho resistito quando ho visto un'utente Italiano.
Ciao Ciao
Belty Dog is offline   Reply With Quote
Old 12-27-2007, 11:01 AM   #6124
FARBES's Avatar
Send a message via AIM to FARBES
Andrew Gray, I notice you are more experince and expert knowledge about losi stuffs like this.
I ask you, one question, If i purchased the losi jrxs type r. so I can drive it on parking lot?
FARBES is offline   Reply With Quote
Old 12-27-2007, 09:40 PM   #6125
J@UNE's Avatar
Wow!!!
I just came back from the track. I was looking at Mike's setup and couldn't beleive he could have enough steering with 20/15 springs and a front sway bar... (I was running 17.5/15 no sway bar) My car was super smooth but not agressive/responsive enough to pass others in tigh turns.
I swiched from Jr links to STD links. The car had now so much sterring!!! the rear end was now loose wich never happen with my TypeR. So I went to stiffer front springs (20) and the .040 front swaybar. I also drop my dual rate. I manage to beat my best time by .2
The car is super fast but a little on the edge. Mike what should I do get a little more rear traction?
My setup is similar to your but I have .060 shims every where (roll center), .165 hex all around and the rear shock are in pos 2/outside.
When you say anti squat, is it like this??? (Front) _----\ (rear).
Thanks.
Jon
J@UNE is offline   Reply With Quote
Old 12-28-2007, 01:14 PM   #6126
jrr102486's Avatar
what gearing are u using?
Old 12-28-2007, 08:30 PM   #6127
Trader Rating: 21 (100%+)
Originally Posted by J@UNE View Post
Wow!!!
I personally know Mike and I know he TQ's at the track he races at. Mike is one of the best drivers around and knows the Type R inside out and backwards. He can look at it or just hear it and tell you what is wrong.
Since I bought my car Mike has helped me setup my car and I do okay for my age (58). I just wish I was as young as him so I could give him a run for his money. (Just joking Mike)
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 12-28-2007, 10:27 PM   #6128
J@UNE- I have the regular link on the front of my car...the sheet should have shown that...the rear hinge pin is low with the small blocks raised by a shim and the wide block flat on the chassis.(This will help it turn in)
I would widen the back to the .195 hex to make it a bit more stable, and you could also try putting the rear diff low. See how that works, my car is a tick pushy on the high bite i'm testing on, i could see it being looser on low bite. Today i moved the bar to the back and stood the front shock up to the outermost hole on the tower and that overall freed the car up, not sure how much bite your track has?
JRR i had a 128/33 for co27/komodo on a good size carpet track (90 ft straight tight infield)
lidebt Jus keep practicing, it will pay off buddy...thx for the props
Old 12-28-2007, 10:39 PM   #6129
J@UNE's Avatar
I guess my post wasn't clear. I realised that your setup was working after moving to the std links.
Thanks a bunch for the tips, I will test that!!! There is a big difference between the front high roll and rear low roll arm position... isn't it too much?
Old 12-28-2007, 10:44 PM   #6130
When we ran on blacktop this summer i went to high up front to stop it from pushing, this seems to work well on carpet also...it seems to keep the front flatter and makes it steer. Interestingly today i took the front bar off and picked up more of a push, my car was just adding body roll and not steering more, it seemed better with the front shocks up a hole on the tower, and the bar in the back to keep the rear from being so lazy.
I would say it isn't too much of a difference as long as it feels good, back on the mid motor car we ran high pins plus a bunch of shims up front and regular low in the back.
Old 12-28-2007, 10:50 PM   #6131
J@UNE's Avatar
Awesome thanks Mike!!
Old 12-28-2007, 11:19 PM   #6132
RobS's Avatar
Just ran my Type R for the first time today and it was awesome! I set TQ with a new track record and went on to win the main as well. However in practice I managed to absolutely shatter both my thrust bearings. I literally turned them both to sand. Has this happened to anybody before?
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 12-29-2007, 09:53 AM   #6133
J@UNE's Avatar
It happened to me too. I'm now using the Axiom trust... Never had to look at it since...
Old 12-29-2007, 12:18 PM   #6134
morris's Avatar
Trader Rating: 40 (100%+)
i have a question im sure was asked before as well.
next week here i will be going brushless.im going to be using the lrp sphere tc with a novak ss 13.5 motor.and it says in the book to mount the esc on the right side of chassi.im using the smallest spektrum rx.
will i also have to add weight to the left side with using the sphere on the right side?
i have seen pics of some cars having weight there and some cars dont.
lmk guys that are running them...thx
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-29-2007, 01:33 PM   #6135
Sigearhead's Avatar
Trader Rating: 68 (100%+)
I would still mount it on the left side. The servo sits towards the right and with the weight of the receiver on the right side it should keep the car fairly balanced. I would take that fan and heatsink off that sphere TC and stand it up on it's side. The fan and heatsink aren't really necessary, unless you're running a low wind modified outside. Your speedo shouldn't get very warm at all.
Sigearhead is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
