Old 12-21-2007, 11:48 AM   #6091
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
Originally Posted by Matt Howard View Post
thanx for the info. that helps alot!
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 12-21-2007, 12:42 PM   #6092
jrr102486's Avatar
hey i just got looking at the tc5 ft spur gear hub (asc31154). i know it would be a sin to put an a$$ociated part on a losi but does anyone think it would work?
Old 12-21-2007, 02:18 PM   #6093
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I highly doubt that the tc5 spur gear hub will work. I don't know I haven't seen one but its a completely different design.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-21-2007, 02:50 PM   #6094
Send a message via MSN to missionhockey33
has anyone tried tc5 rear hubs onto the losi?
missionhockey33 is offline   Reply With Quote
Old 12-21-2007, 02:51 PM   #6095
schreff's Avatar
Send a message via AIM to schreff
Also keep in mind that basically every part on the TC5 is now metric as opposed to everything being standard on the Losi. I doubt very much so that it's going to fit.
There's nothing wrong with the stock spurs either. They last just as long as any other spur out there. Since they're on backorder, just get yourself a PRS gear adapter. You can't go wrong with that.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-21-2007, 11:46 PM   #6096
RobS's Avatar
Well I finally got my Type R today, and have to say I am very impressed! I've been mostly an Xray guy in the past, but had the original JRXS back in the day. However I didn't not have any luck with that car. The parts quality of the Type R was excellent, and the build up of the car was very enjoyable. I've always been known for having the worst diffs imaginable, but these ones went together pretty smoothly. The only issue I had with the car was changing camber on the front when using the JR link, its a little tricky bit I'll get used to it. Other then that I can't wait to hit the track with it!
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 12-22-2007, 09:21 AM   #6097
Yeti35's Avatar
You can always do what I did, change out the set screw with a turn buckle.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 12-22-2007, 10:12 AM   #6098
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
DENNIS STORTI is offline   Reply With Quote
Old 12-22-2007, 08:24 PM   #6099
Xpress's Avatar
Does anybody know where I can find 20mm fans? The smallest I have been able to find is 25mm.
Xpress is offline   Reply With Quote
Old 12-22-2007, 08:41 PM   #6100
RobS's Avatar
Thats what I figured, might just do that...
Rob Say
Old 12-22-2007, 08:43 PM   #6101
Matt Howard's Avatar
AE made a dual fan setup for their TC4 that uses the 20mm fans, that's what I used
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-22-2007, 10:13 PM   #6102
Mike Haynes's Avatar
I use the novak 25mm ones, the fit onto the bulkheads perfectly.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-23-2007, 04:22 PM   #6103
syndr0me's Avatar
Trader Rating: 32 (100%+)
I didn't have the parts to run my rubber tire car this weekend, so I spent the night building up my R for foams with Schreff's setup. Even on a green layout, it worked remarkably well. I have two questions, though:
1. I couldn't make the rear camber links as long as they are on the setup with the stock tie rods. Did you add longer rods? If so, which ones? Mine kept pulling out of the threads, so I ended up moving it to the middle hole on the rear shock tower.
2. What would I need to change to keep the roll center (or whatever) the same while running smaller tires? I've had really bad luck with the new larger wheel tires, especially the Pro 53's. I'm gonna go back to regular wheels, even if I'm a tad slower.
I've kind of shifted to rubber tire lately, and after today, realized it was the right choice for me. Foam tires just stress me out, and aren't as fun to drive. But, in the US, you never know where the competition is going to be, so it's good to be ready for foams if need be. I'm definitely going to keep the R around for that, the car felt dialed today, better than ever before. Thanks Schreff and Larry for all your hard work.
syndr0me is offline   Reply With Quote
Old 12-23-2007, 05:10 PM   #6104
Yeti35's Avatar
You only have to replace one of the ballcups, specifically the one that would connect to the shock tower. I just used some off road ones I had in my box but you could use any brand as long as they are longer then the stock ones. Schreff told be about that when I put the setup on my car for IIC. Once you replace the one ball cup you will be able to get the adjustment you need w/o any problems.
22 2.0
22T 2.0
Old 12-23-2007, 05:17 PM   #6105
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Or u can get a 1 inch turnbuckle and us the stock ends
http://www.lunsfordracing.com/mm5/me...egory_Code=3MM
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
