Old 12-16-2007, 02:21 PM   #6076
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
Originally Posted by tallyrc View Post
so i'm not the only one breaking C-hubs?
i broke a couple before i got the wide wheel hex's, if you dont want to get the hexes then try shaving some material off your axles, but if you do you cant widen it, but that is what fixed the breaking for me
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 12-16-2007, 02:28 PM   #6077
JKA
ditto
I cut my axles and haven't broken a part since.
JKA is offline   Reply With Quote
Old 12-16-2007, 06:56 PM   #6078
Send a message via MSN to missionhockey33
Default offset on hub carriers
hey guys i own a losi . i now see that losi have made different rear hub carriers. wat is the difference between the offsetted onesA9869 and the non offsetted A9866?
missionhockey33 is offline   Reply With Quote
Old 12-16-2007, 08:07 PM   #6079
tallyrc's Avatar
if i run the front wide that will take away steering though... right?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 12-16-2007, 08:11 PM   #6080
Matt Howard's Avatar
the offset rear hubs are used to "free up" the rear of the car when running foams on carpet. You use the inside hub mounting hole on the arm when using them since they offset the axle more to the outside.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-16-2007, 08:59 PM   #6081
thanks for reply. please define my the word "free up" and where thats happening.
Old 12-16-2007, 09:14 PM   #6082
basically you'll get a bit less rear traction
RCTech #361
Old 12-16-2007, 10:32 PM   #6083
syndr0me's Avatar
Trader Rating: 32 (100%+)
syndr0me is offline   Reply With Quote
Old 12-17-2007, 02:12 AM   #6084
PeteB's Avatar
I broke heaps of C hubs until I changed over to Alu C hubs.
http://www.asiatees.com/display.php?...l=XXX-S&pid=1#
They are 0deg, so to compensate, I run the front of the hinge pin in the high roll center position and the rear in the low roll center position.
This results in about 3deg caster and some kickup, which adds some rear traction.
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 12-19-2007, 03:05 PM   #6085
Capelracer's Avatar
Woohoo - took out my club's stock title for the year with the type R (well, a little help from the JRXS for the 1st couple of months) - that's 2 years in a row my Losi's have won
Capelracer is offline   Reply With Quote
Old 12-20-2007, 12:42 PM   #6086
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
are there any other manufacturer's spur gears that work with the type r? horizons eta is 12/24 but that means it will come off back order in like maybe june
looking for the 118 tooth spur. if anyone has an extra that they are willing to part with id be interested as well.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 12-20-2007, 12:54 PM   #6087
you can only use the losi spurs unless you get the PRS spurgear adaptor
RCTech #361
Old 12-20-2007, 12:59 PM   #6088
jrr102486's Avatar
how and where can i get it?
Old 12-20-2007, 01:05 PM   #6089
http://www.precisionracingsystems.com/products/18
RCTech #361
Old 12-20-2007, 02:24 PM   #6090
Giorgio's Avatar
I was a good boy and a little early Santa, bring me the type R.
So I'm leaving my Cyclone to the Losi.
Some one will to help with the "Do and Don't Do"?
Racing mod, BL 4.5 or similar "hot" brushed.
Thanks in advance!
Giorgio is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
