Old 12-09-2007, 09:12 AM   #6031
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Ivy, LOSA3329 is the 42T Spool Pulley & Plate: JRX-S Type R. Get that take out the Regular pulley and balls and put the new spool pulley in and crank it down. There you go.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 12-09-2007, 09:17 AM   #6032
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by J@UNE View Post
I have like 2.5 mm of droop (mesured like JKA). I'm now running 17.5 Front and 15 rear springs. Thats how my car perform the best on our med traction track. With softer spring my car was rolling to much an felt like it has less corner speed. Again this is with a stock motor...
im running also a stock motor.i run the foam tire set-up with the 40 oil all around vs the 50.and a rear camber link change to a shorter position.
i got like 35 pound spring in front and 15 rear.
i measure droop by screwing the droop screws all the way out.then i do ride height.which i am at 5mm.the once i do that i set the chassi on the 6mm spot on the gage.screw the droop screw down till the tire lifts off the table.then back it back down till it touches.
is this the way you all do it?
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-09-2007, 09:30 AM   #6033
JKA
Thats the same droop measurement as mine. 1mm is probably not enough. I'm running 2mm front and rear.
JKA is offline   Reply With Quote
Old 12-09-2007, 09:34 AM   #6034
morris's Avatar
ok kool-i will try running 2mm front and rear and go from there.i will get back to you at the end of the week and let you know how it worked.
Old 12-09-2007, 11:19 AM   #6035
mike ivy's Avatar
Trader Rating: 50 (100%+)
Yo Larry, Cool Thanks for the info Bro
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-09-2007, 12:44 PM   #6036
markf3x's Avatar
Default Rubber tire Carpet setup
At the track this weekend I had my woobie rubber tire setup (favorite one) that seems to always work real well.
They ran an abnormally high number of foam tire heats and it brought the traction WAY up (it's normally med-low grip for carpter).. I was traction rolling like crazy. Athough I had a lot of steering, it was not overwhelming.
Question: What is the best way to adjust for traction rolling... harder tires? stiffer springs? lower roll center? Sway bars? other? When I mean best, I mean one that tends to be the fastest setup(if their is one).. If not, the easiest one to change back later...
My regular setup is: (near identical to a couple floating around on this thread)
Stiff front diff (not spool)
15 lb springs all around
.165 hexes front, .225 hexes rear (pushes alot without this)
ride height front: 5.0 rear 5.5
Sorex 24's
Low roll center
LiPO weighted top and bottom to simulate Ni-MH.
13.5 motor
Current tuning options:
I carry assortment of springs.
I carry Sorex 24's, CS-27's, RP30's
Sway bars
I know the big racers out their deal with widely varying tracks all the time. Pretty much all my racing is at the local track, so rarely do I encounter conditions to far from the norm...
Your comments are appreciated.
markf3x
markf3x is offline   Reply With Quote
Old 12-09-2007, 01:42 PM   #6037
sportpak's Avatar
Trader Rating: 26 (100%+)
You could try a light to medium sway bar on the rear to free the car up a touch. I usually run the front roll center as high as I can. Since it wasn't a normal track condition, I'd try some of the cheap and dirty adjustments first. That way you won't have to re-invent your setup, only to switch it all back the following week.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 12-09-2007, 01:48 PM   #6038
When the bite is high running your rear that much wider than the front will make the car traction roll. I would try to even up the width some. You can get the car to turn without that much differentiation of widths.
Old 12-09-2007, 03:41 PM   #6039
markf3x's Avatar
ahh... good point... I'll give that a try and it's a quick adjustment..
markf3x
Old 12-09-2007, 04:07 PM   #6040
morris's Avatar
WOULDNT THE SWAY BAR ON THE REAR OF THE CAR CAUSE MORE STEERING?
Old 12-09-2007, 05:57 PM   #6041
sportpak's Avatar
If he's traction rolling, that tells me he's transfering a lot of weight and planting hard enough to traction roll. A sway bar might help slow or reduce it enough to get him through the corner.
Old 12-09-2007, 08:16 PM   #6042
mojoman's Avatar
If anyone has a steel lipo tray they want to part with pm me.
Thanks,
Casey
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 12-10-2007, 08:00 AM   #6043
markf3x's Avatar
Thanks for the suggestions.
The car's current setup (low-med grip) is really well balanced and planted in the corners (you'll hear tires squeel on the carpet in many of the corners). Adding a sway bar front and back might work, but one in just the rear would be awful (I think it would swap ends in a corner really fast).
I'll play around with track width first (widen front/narrow rear). It makes sense.... try riding a tricycle into a hard corner on a grippy surface
Hopefully, when I find the track width sweet spot (that keeps me right side up) it won't of given up too much steering or to much of that firmly planted feeling.
ps- How many of my LOSI brotheren are attending snowbirds in FL or Nats in Omaha? I'm looking to make Omaha my first big race (bummer, sounds like no rubber!) and maybe go to watch at snowbirds.. Would love to race at Snowbirds, but timing is awful for my work.
Cheers,
Markf3x
Old 12-10-2007, 09:11 AM   #6044
sportpak's Avatar
Thanks,
Casey
Someone told me they discontinued it because of tweak issues. Anyone else hear this?
Old 12-10-2007, 09:13 AM   #6045
sportpak's Avatar
If you run the light bar, it will free you up just a touch.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
