Old 12-06-2007, 10:32 AM   #6001
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
The only changes you might have to make for that setup on lower bite tracks is lower the front camber link and increase the camber to -2 in the front. That is all I have changed on my car in the last 5 months on carpet.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-06-2007, 12:45 PM   #6002
JKA
I switched to the Losi from an RDX, and started out with Schreffs setup on our lowbite carpet track. A few changes and I was running faster laps on my first night with the Losi than I ever ran with my RDX. I found though that the rear of the car needed changed.
Loving the Losi for sure though. Second weekend with the car this week... we'll see how it goes.
JKA is offline   Reply With Quote
Old 12-06-2007, 01:12 PM   #6003
JKA
Forgot to mention that the only problem I had was a couple broken c-hubs. I noticed that the axles are a bit long and grab the walls causing the breaks. Are you guys cutting the axles?
Old 12-06-2007, 01:25 PM   #6004
schreff's Avatar
Send a message via AIM to schreff
Yes, do cut your axles. Believe me, it's worth it. I threw away 2 legit chances of winning the stock and 19t mains at Vegas for being lazy and not cutting mine! Of course, I could have easily just not hit walls, but I was driving like an idiot.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-06-2007, 01:50 PM   #6005
markf3x's Avatar
Yeah, I break a C-hub once in a while. No fault of the car.. Just been driving a year and I'm a little on the aggressive side
I'm working on getting some aluminum 4 and 6 degree hubs (from a machinist that has done replacement hubs on plenty of other cars).
I'm sure I'll post pics them if/when I get them.
markf3x is offline   Reply With Quote
Old 12-06-2007, 01:58 PM   #6006
markf3x's Avatar
Hi All,
For our low traction carpet track, myself and alot of others prefer a real tight diff to a one-way or a spool..
Unfortunately, the threaded material on the diff is plastic and strips when I get it about the right tightness. Any ideas? or just get some 1,000,000 weight diff grease and go easy on the diff tightness...
Markf3x
Old 12-06-2007, 02:03 PM   #6007
Mike Haynes's Avatar
You can use brown grease, part number LOSA3012 and it will feel tight without cranking on it.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-06-2007, 02:04 PM   #6008
Originally Posted by markf3x View Post
Hi All,
Markf3x
Mark, Get some Losi brown grease, load it up on the diff balls, rings and thrust bearing. It will help, its very sticky and really slows down diff action. It's what we been running in the front diff for a while with foams. If you load it up and then tighten it pretty good it should be close to what you need.
Old 12-06-2007, 02:13 PM   #6009
JKA
Originally Posted by schreff View Post
... but I was driving like an idiot.
Then I should definitely cut my axles. lol
Good info guys. Thanks.
Old 12-06-2007, 02:13 PM   #6010
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Larry wasup Bro, ygpm question for ya
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 12-06-2007, 03:49 PM   #6011
morris's Avatar
Trader Rating: 40 (100%+)
i have been running the car rubber tire on carpet only changing the shock oil to 40 weight front and rear.and shortened the rear camber one hole.and 15 pound springs in the back.everything else is box stock set-up for foam tire.
i use rp 24 tire and the car is amazing...at the sametime time i am the only one running brushed so i lack on horsepower preiod....but as for set-up it works great....lois did a wonderfull job on this car no doubt.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-06-2007, 04:07 PM   #6012
Juan Valdez's Avatar
Since the subject of chassis flex has been mentioned...
Has anyone tried removing the 4 chassis post screws from the top deck of this car? Does it affect the chassis flex much? Did you experience tweak problems after doing this? I thought Todd Hodge had mentioned doing this back when the car came out, but can't remember for sure.
I'm curious about this as I removed the 4 chassis posts from the rear of my old front motor JRX-S and really liked the car after that. It just seemed to steer harder and have more rear grip at the same time. Just more grip overall. And the car remained really consistant and tweak free. I was considering trying it out on my Type R and was just curious if anyone else has and can share their results with the class. Thanks in advance!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05
Juan Valdez is offline   Reply With Quote
Old 12-06-2007, 06:57 PM   #6013
J@UNE's Avatar
I removed the rear post completely. Removing the screws does give more flex but I felt the the top deck was kind a stuck and wasn't flexing properly.
I had to make some brace so the battery brace can crew in...
J@UNE is offline   Reply With Quote
Old 12-06-2007, 07:03 PM   #6014
RussB's Avatar
Send a message via MSN to RussB
i tried removing the top deck screws for the battery posts running rubber asphalt. i prefer to make the car softer via setup rather than chassis flex. it just didn't feel as good as a rigid chassis did.
i do find that i have NEVER tweaked the chassis on this car, which is a first for me and 2 deck cars.
RussB is offline   Reply With Quote
Old 12-06-2007, 08:18 PM   #6015
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
You just need to remember to bring the lipo tray!!!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
