Old 12-04-2007, 06:09 PM   #5986
Trader Rating: 114 (100%+)
Originally Posted by sportpak View Post
Thanks for the info. Mercon 3 sound good?
Perfect.
Chris Furman is offline   Reply With Quote
Old 12-05-2007, 08:31 AM   #5987
sportpak's Avatar
Trader Rating: 26 (100%+)
Does anyone know if it's possible to replace the one-way bearings in a one-way? I posted the other day that I had it sticking on one side. Well, when I pulled it apart to clean it, a few of the rollers came out. Basically the bearing broke. So now I would like to replace the bearing if I could. I only ran the thing two race days, I really don't want to have to buy a whole unit. If I can't replace the bearing, can I just buy the housing that has the the two one-way bearings installed?
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 12-05-2007, 08:38 AM   #5988
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I don't believe that you can replace the bearing or just the tube. But I have had the rollers come out before and put them back in no problem.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 12-05-2007, 12:47 PM   #5989
sportpak's Avatar
That sucks. I'll try putting them back in.
Old 12-06-2007, 07:19 AM   #5990
JCB
JCB's Avatar
Hey Guys,
Thinking of getting into this car... just curious as to when the production car was release? Would hate to buy it if something newer was coming out for 2008.
thank in advance,
JCB is offline   Reply With Quote
Old 12-06-2007, 07:38 AM   #5991
schreff's Avatar
Send a message via AIM to schreff
Juan, the car just came out in March. I don't think another new car will be coming out for a little while.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-06-2007, 08:57 AM   #5992
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'd be happy to see a sign that development on competitive racing sedans is ongoing within Losi. I'm hopeful that's the case, anyway.
syndr0me is offline   Reply With Quote
Old 12-06-2007, 09:11 AM   #5993
At this point I dont think we have reached the limits of this car. For example. At the last 2 "Big" races fast laps of the weekend were turned by the losi car in multiple classes. IIC about the top 10 fast laps in 19 turn were turned by losi cars, and in stock there were only 4 cars that turned 10.9s, 2 were losi's. At Cleveland Schreff turned the fastest laps in 19 turn and I turned some very fast laps also. In stock I had the fastest lap of the weekend eventhough I blew out shortly after.
Losi cars have had a chance to win both of those classes at both races, bad luck and good competition are the only thing holding this car back from its first big win.
Dumas is always top 5 in mod and would of probably Tqed the IIC if he wasn't held up by traffic.
As far as I can see there is little that you could change on this car to make it better. There are plenty of cookie cutter cars on the market. This is the newest design of all the touring cars. Any suggestions on changes that could help the handing of this car would be taken into consideration, I just dont have any at this point. I still think we are making it faster every race with what we have.
Old 12-06-2007, 09:41 AM   #5994
syndr0me's Avatar
Larry,
That's very good to hear. I have noticed the Losi cars always seem to have the fastest laps, which is encouraging. It sounds like you guys are working on refining the existing car to get the most out of it rather than moving on to something new immediately, like we see with many other companies.
Do you think the car would benefit at all from increased flex on rubber tires? I mean for club racing where the traction is modest, especially on spec tires. I've found the car a little harder to get stuck than others in the past that weren't so rigid. A lot of people using the car have very modest setup knowledge, myself included, so having a car that's easier to make drivable can be beneficial to the layman. The trend for rubber cars seems to be to soften them up, but the R is so different, I don't really know if you can carry those trends over or not.
Now that I've used the car for a while, I have very few gripes, and really do love it on foam tires. It's been a little tricky on rubber, but does much better when there's a little bit of traction. About the only thing I've had trouble with, is that the bones seem to bend much more easily than I'm used to. I know, quit hitting things... Also, the car seems to have developed some excessive slop, but parts are so cheap, $20 in plastic parts would resolve that entirely.
Old 12-06-2007, 09:51 AM   #5995
I have never liked to rely on fake flex traction on rubber tires. I have raced this car on rubber/asphalt many times and its always the best car on the track. I like to rely on suspension to do what its supposed to do. Formula 1 and nascar cars dont put a more flexible chassis on their cars on a lower bite track. I also dont think the car is overly rigid either. I think its a good mix of both.
Once we found a good setup for carpet it has worked everywhere we have gone. I ran the EXACT same setup at the IIC and Cleveland and they were much different layouts and different traction compounds.
I have not ever bent a dogbone on this car, nor have I ever seen one bend. I hit alot of stuff really hard and haven't seen it and now we have a lot of Losis running in the area. So I dont know what to tell you about that situation.
The slop is a little more noticable in this car than some other but parts are much cheaper and the slop is easily shimmed out. I carry a bunch of motor shims with me and the slop goes away.
As for rubber tire setups, I will be starting to run rubbers in prep for the birds starting next week and will have something solid hopefully soon. But I have driven a few on rubber tires on carpet and the car was good without much tinkering at all. I think I will be able to make this the best car I have driven on rubber carpet in no time.
Old 12-06-2007, 10:02 AM   #5996
syndr0me's Avatar
I'll have to reexamine the dogbone thing, then, I must being doing something wrong. I can't remember the last time I broke something on the car, but have bent bones pretty easily. We use wooden boards with narrow lanes, so it's not unheard of to smack a board with the side of the car if you push out a little bit. Maybe that's what's doing it. It certainly beats the hell out of hub bearings when that happens.
Anyway, thanks for the answers. I look forward to seeing how you guys do with the car on rubber tires at the 'birds.
Old 12-06-2007, 10:08 AM   #5997
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
I heard from Mike Haynes and Jason Schreffler say the same thing over the weekend at our last Trophy Race about there set-ups being real good everywhere they go..... I use the same set-up they use and run it at all the Northeast indoor tracks and find the car to be very easy to drive, with great rotation and plenty of steering......I find more people in my area switching to losi this winter.
The car is simply amazing on carpet and fun to drive on asphalt too.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 12-06-2007, 10:13 AM   #5998
syndr0me's Avatar
Is the magic setup you guys are using for foams online somewhere? Is it the one on the Losi site that Dumas used at IIC?
Old 12-06-2007, 10:15 AM   #5999
Mike Haynes's Avatar
It is on the Losi site under Schreffler.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-06-2007, 10:29 AM   #6000
syndr0me's Avatar
What an awful place for it! :-D
Thanks guys.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
