Old 11-03-2007, 06:47 PM   #5851
Trader Rating: 32 (100%+)
Send a message via AIM to Sean R
I totally dominated a CVD with the one-way installed and was wondering if the original JRXS driveshaft is the same as the one included in the one-way package. Thanks guys!
Sean R is offline   Reply With Quote
Old 11-03-2007, 07:53 PM   #5852
Yeti35's Avatar
It is the same since the one way is the same one with just the bearings flipped to work with the Type R.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 11-03-2007, 08:57 PM   #5853
http://www3.towerhobbies.com/cgi-bin...?&I=LXPUW1&P=7
Fit or not for TYPE R
xtaiji is offline   Reply With Quote
Old 11-04-2007, 06:05 AM   #5854
sportpak's Avatar
Trader Rating: 26 (100%+)
I just ordered the oneway kit. I have to change the drives shafts because the oneway is a different width? I was hoping for an easy swap back and forth. Am I right, or smoking crack?? Thanks.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 11-04-2007, 08:02 AM   #5855
you have to swap axles. It's a pain but you get used to it. best thing to do is to get another eccentric holder and bearings as well as a LCD "rebuild" kit and axles. That way you just have to tear down the front end and swap everything instead of having to tear down the eccentric holders and axles too.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 11-04-2007, 08:04 AM   #5856
Yeti35's Avatar
It is an easy swap if you build the CVD's up with their own axels and just keep the LCD's together with the kit. No, they did not make this a simple swap but at least they are giving you the CVD shafts with the oneway. That will get you part way there.
22 2.0
22T 2.0
Old 11-04-2007, 08:56 AM   #5857
sportpak's Avatar
Thanks guys. I'll have to check my inventory. It makes sense to have another set of Lcds made up.
Old 11-04-2007, 09:07 AM   #5858
Send a message via AIM to ERTRACHTER
i've ran the type r since may and i don't see a need for the one way except for rubber tire carpet every asphalt track i race at i have plenty of steering with my spool and the car is really good now just my opinion
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Old 11-04-2007, 09:09 AM   #5859
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I agree 100 percent with you Jason. One way is only necessary in stock or 19 on rubber carpet. Spool is the way to go on asphalt.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-04-2007, 10:15 AM   #5860
sportpak's Avatar
I race stock rubber tire on carpet. I ran ok last week at the Halloween Classic. Not having a oneway I think was killing me. I just didn't quite have the corner speed.
Old 11-04-2007, 12:15 PM   #5861
markf3x's Avatar
Can't find little instruction slip for my one-way, now that I'm actually putting it together...
It's all pretty obvious except for the single large silver shim/spacer..
Where does it go? Between hub thingy and pulley?
Checked LOSI site and there's no copy of the instuctions there..
Thanks in advance for response,
Mark
markf3x is offline   Reply With Quote
Old 11-04-2007, 12:48 PM   #5862
Trader Rating: 45 (100%+)
If anyone is looking for a Type-R...Excellent condition!
http://rctech.net/forum/showthread.php?t=188360
Apex is offline   Reply With Quote
Old 11-04-2007, 01:48 PM   #5863
sportpak's Avatar
Mark
You can go to Horizonhobby.com and find the instructions in the description of the part. Look up the part and look for the pdf file.
Ben
Old 11-04-2007, 02:07 PM   #5864
J@UNE's Avatar
Originally Posted by morris View Post
you guys still having probs with running a one-way in the car ans stripping spur gears?
Not since I used the JRX-s (Not typeR) layshaft
J@UNE is offline   Reply With Quote
Old 11-04-2007, 07:25 PM   #5865
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
if anybody is interested
http://www.rctech.net/forum/showthre...25#post3831625
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
