Team Losi JRXS Type-R
#5806
http://i10.photobucket.com/albums/a1...g?t=1193146985
I would try this first. I'm not sure how it will be with a 10.5 but in 19t and 27t its great. If you lack a bit of back end traction raise the rear roll centre a tiny bit using some 0.75mm shims.
#5807
hey guys.i know i asked earlier but i really need a set-up using a front one-way for rubber tire on carpet.
i am currently using the book set-up.that is the page for page set-up which i think is the foam tire set-up.i used 1mm of droop in the front and 2 in the back. i am using 40 oil instead of 50 oil.
i am using cs-22 tire to make traction.has plenty of steering but was wanting to try a one-way to see how it works.
i will post a link to a track video and maybe you all can look at it and lmk if the track looks one-way friendly?
thx,
matt
thx,
matt
#5809
Tech Legend
Trader Rating: 51 (100%+)
thx,
matt
thx,
matt
#5811
i did try a set of cs-27 but the car was very pushy.i do have a set of rp-30 that are used but i didnt try them yet.as soon as i bought the cs-22 the car was awesome...was just wanting to try a set-up with the one-way to see if i can get better times.the fastest lap there was a 12.043 or something and mine was a 12.356 or something...the car is good now...like i said i just wanted to try a one-way to see if its faster...
#5814
I am guessing the tires he has on that setup are Jaco Greens. Reason being they were the control tire in LV for IIC. They work fine on carpet and in fact I think they are better then CS or RP imo. I have run CS 22's on carpet and they seem to do well. I ran a setup I got from Jason Schreffler for asphalt and the only change I made to it was the JR Link and one way. I used it with a spool on asphalt and it was stuck.
#5815
#5817
anyone????
recently I have broke a front right arm, so I have replaced them with older style graphite arms..... I have also fliped the suspension blocks as well (front+back)
but left the rear ones the same as it was.
has anyone left it that way and kept driving?
would it be better to order the newer style arms being more beefier now?
I have tried the "search botton" and haven't really found the direct answer...
thanx guys
thanx guys
#5818
#5820
Super Moderator
thanx guys
thanx guys
