Team Losi JRXS Type-R
#5791
when are they going to be releasing the 17.5 motor....
the guys i race with are using the 13.5...is this why they are a little faster than me.
i meen dont get me wrong im faster thsn some guys there but its my driving not speed...but the guys that are running with my skill level are faster a little bit.
#5792
i also recall seing a set-up for rubber tire on carpet a few pages or so back.it wasnt tags set-up but it was another one.i just bought a one-way for the car and i need to build it yet.but i am looking for a set-up for a medium bight track.i am currently using cs-22 to make the car aggresive.
lmk
lmk
#5793
Tech Legend
Trader Rating: 51 (100%+)
#5797
where is the best place to order parts from??
#5799
Hi all,
Is the only difference between:
FR Spindle & carrier, Graphite (LOSA9755-LOSA9759)
and
FR Spindle Carriers, EA3: X-S (LOSA9760-LOSA9765)
the material??? or are they not the same molds/shape??
I'd been racing rubber tire/ carpet and love my JRXS-R (actually, I have 2 now)
I'm trying my hand at foam tire/carpet and have broken a couple of C's and would like to try the graphite ones if they're the same..
I know... I shouldn't hit the boards... But, until that day comes, I need the strongest ones I can find.
ps- With the new brew of A-arms, I haven't broken on in 3 months.
Cheers,
Mark
and
Cheers,
Mark
#5801
Kave, use the sames ones as the kit has in the rear.
I use graphite knuckles and caster blocks with the ea3 arm....if you break it will almost always be a caster block. Using a ea3 c carrier will will usually leave the knucle to break....If you use all ea3 its hard to say what will go.
Make sure to trim down the excess past the nut on the axle and it will dramatically reduce breakage since there is less to catch on a barrier.
#5802
good rubber tire on carpet set up
i'm looking for a good rubber tire on carpet set up for 10.5. thanks.
#5804
Hey rosko,
Give me a call.....
Give me a call.....
#5805
http://i10.photobucket.com/albums/a1...g?t=1193146985
I would try this first. I'm not sure how it will be with a 10.5 but in 19t and 27t its great. If you lack a bit of back end traction raise the rear roll centre a tiny bit using some 0.75mm shims.
